Question about Craftsman Convertible 14" Gas Line Trimmer
Rope on Craftsman Convertible weedeater wont rewind.
    President:
  • Craftsman Master
  • 1,545 Answers
Remove the tube that holds the flex-drive shaft from the front of the motor cover. Remove the throttle cable from the carburetor. Mark and unplug any wires for the on/off switch if possible. Now if you have pulled the driveshaft tube out of the way, the clutch drum is up next. Inside it, screwed into the very end of the engine's crankshaft is a Torx #25 screw. Before you loosen it, ou will have to lock up the engine. Remove the spark plug. Pull on the starter until the piston is down, then insert a length of clean, soft rope into the engine. The engine will come up and compress the rope, thus locking it in place to allow clutch drum and clutch removal. Loosen the T-25 screw inside the drum.. It probably won't come completely out...it is made this way. Next, remove the clutch. It is screwed onto a small threaded section of the crankshaft Removal is counterclockwise.. It will be pretty tight. To help, apply peneterating oil. Whack the ears of the clutch near the center with a dull flat-blade chisel and hammer unless there are bolts. then use wrench. It will turn counterclockwise for removal and there will probably be a removal direction arrow on it's face. After getting that off, remove the Torx screws holding the cover to the engine. The starter unit should be mounted inside as it mates with the top of the flywheel to start the motor. Remember to preload tension (5-7 turns) on the starter unit. Make sure the handle is installed. Jam the unit with a screwdriver or something so you can insert and tie off the new rope. Then remove jam device and let recoil pull your new rope into place. Reassemble and you are done. Disassembly requires Torx head drivers ranging from T-15 to T-25. Here are more details involving the starter/recoil assembly.
With the starter/recoil unit OFF the machine, with no rope in it, and no tension on it.....grasp the little nylon hub and turn it (clockwise is I recall) round and round 6-7 times until you feel the recoil spring get nice and tight...DO NOT LET GO OF IT!...hold it in place and then JAM the starter/recoil unit in place (still tight) inside it's housing by either clamping it with a tool like vise grips or by sticking a screwdriver thru it and thru the vents in the cover. If you have ANOTHER person to help you...one of you hold it in place....and make sure it is lined up to where you can NOW insert the new lenth of pull rope. Always use new rope....Feed the end thru the hole in the recoil unit and tie it off, by wrapping it around itself outside the nylon hub and then screw the little self-tapping set screw back in holding the rope down. OK...then feed the opposite end into the hole in the front engine cover and attatch the T pull handle....Now mind you, you are still jammming or holding the recoil in place against the spring!...Now, unclamp it or unjam it and slowly let the recoil pull the NEW rope you just installed back onto the pulley. Make sure it is fastened well on top of the pulley around the nylon hub and also fastened well onto the T pull handle. That is it. Then reconnect your wires, put your throttle cable back thru the engine cover and reinstall the Torx screws in the cover.
Posted on May 27, 2011
Starter rope won't pull on my Craftsman rotary mower model 917.4787A.
the cable may be stuck or you may have to take the top off and rewind the rope.
Nov 05, 2016 | Garden
When I pull start rope on my Craftsman 32cc 4 cycle weedeater . . . engine does not turn over . . . when I let go of the rope and it retracts . . . what is wrong?
There are 2 dogs or fingers that expand out to grab the flywheel when the rope is pulled They are sticking and can not expand or slide out. Remove the recoil unit and free them up When the recoil unit is off pull the rope and watch the action
Jun 08, 2015 | Craftsman Garden
How do I replace 590787 rewind starter on craftsman snowblower?
ARE YOU REPLACING WHOLE THING OR JUST THE ROPE?
if replacing whole thing just unbolt the 4 nuts
Oct 17, 2014 | Garden
Starter rope won't retract
You have to wind the spring as tight as you can before you put the rope on. Then allow the spring to unwind, pulling the rope onto the spool. Be very careful when you take it apart. Good luck...Lee
May 29, 2010 | Craftsman 22" Rear Bag Rear Propelled High...
How to install pull rope on Craftsman 917.37717 lawn mower
First, this is best done with two people, unless you have 4 hands. Second, with rope pull cover off the mower and laying on table with rope pulley up so you can see it, remove all the old rope. Next, measure 8 foot of new rope.
Now, line up the holes where rope will go thru the cover and into pulley, now with someone holding the cover, rotate rope pulley 6 complete turns, now hold pulley there, while putting new rope thru the rope openings in rope pulley and outer cover. Tie knot on end by rope pulley and have who ever was holding cover and other end of rope, slowly release the rope so it rewinds, install rope handle and walla, your done. 5 minute job, depending on how much coffee you drink. Hope this helped you.
May 28, 2010 | Craftsman Garden
Starter rope pulled out and wont retract on craftsman trimmer/edger 32cc convertible incredi-pull
remove the starter cover and try to wind the starter rope manuly. the rope may have to be replaced if worn or broke..
Oct 22, 2009 | Craftsman Garden
Pull rope does not return
Unless the rope has broken, you dont need to replace it. The problem is probably the rewind spring. It is located under the starter pulley (the one the rope is in). The best thing to do is pull the unit apart and see if you can see if maybe there is something holding the rope up. The spring is a little dangerous to replace. If you go for it, be careful....Lee
Sep 03, 2009 | Garden
WeedEater Edger PE550 Starter Rope will not recoil
Order a new recoil spring from your suppier. It comes wound up. Remove the old part first usually four screws on the outside. Make sure the rope is fully wound then insert the new spring and reassamble. If it becomes unwound by mistake its a labourious job to rewind but can be done.
Aug 29, 2009 | Echo 30.1CC Chainsaw With a 14 In.bar and...
Craftsman weedwacker 358.791070 suddenly stopped
could have been caused by any number of thing's,
take the recoil assembly off and try pulling the rope out while holding the center of the rope spool just enuff to prevent it from popping out in case there's nothing holding it there.
rewinding the rope is alot easier than rewinding the recoil spring Trust Me.. lol
Jul 31, 2009 | Garden
Craftsman Convertible 14" Gas Line Trimmer Logo
249 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
