Anonymous Posted on May 27, 2011
Looking for a replacement AKG VR12 vacuum tube replacement ..orginal ....6072A
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jun 15, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
217
Points
Anonymous
Level 3:
  • Master 2,418 Answers
  • Posted on May 27, 2011
Anonymous
Master
Level 3:
Answers
2418
Questions
0
Helped
812118
Points
6999
You can also use a JJ ECC83s tube, ou can use a 12AY& EH. The GE JAN 6072A Is a direct replacement for your MIC. Find your new tube at http://www.tubedepot.com, or even Amazon. Hope this helps Fix Ya up.
1helpful
I have a AKG T912 Head phone how i can re charge it
Hi,thanks for posting your Question.
You can only charge the AKG T912 Head phone with its cradle...
Use the link to get a replacement..
http://www.listeningpost.co.nz/Brands/AKG/Listening-Post-Christchurch-AKG-K912-Wireless-Headphones__I.13996__N.27183__C.27343
Hope it helped.
Need a new "guitar bug"(wireless
It looks like you are after the AKG GB 40 guitarbug
They appear to be a discontinued item in a lot of places
This list several place that say they have them, one for $29.95
www.thefind.com/electronics/browse-akg-gb40-guitar-transmitter
Also
fatheadmusic.co.uk/product/2367/akg-gb40-guitar-bug
or
www.proaudiosuppliers.com/akg-gb-40.html
When I turn on my SolidTube and let it warm up for a couple of minutes it sounds great. After like 20-30 minutes or so the volume fades. You can still hear it, but barely audible. I've tried put put in a...
I would be inclined check your +48v phantom power supply to make sure the correct voltage is coming out and to check your cable. Failing that, if you have changed the tube once I'd be inclined to contact AKG Directly via email to find a service center or get furthur advice.
I have three working AKG C1000S. They all need grills. Who can I trust to service or sell grills?
AKG sells the replacement screen and tube assembly direct from AKG Acoustics, U.S.
+1 818-920-3237
[email protected]
They are expensive, $80.00 each.
5helpful
2answers
How to adjust frequency on transmit??? Galaxy
hELLO THERE
hERE IS SOME MODIFICATIONS FOR THIS RADIO
Galaxy Mods DX 2527 - VR 1....AM/FM S-Meter, VR 2....SSB S-Meter, VR 3....SSB Squelch Range, VR 4....AM/FM Squelch Range, VR 7....SSB Carrier Balance, VR 8....RF Meter, VR11...Driver Bias, VR12...SSB ALC, VR13...Hi Power, VR14...AMC, VR15...AM Low Power, VR16...SSB Low Power, VC 1....10.240, VC 2....10.240. DX 2517- VR 1....AM/FM S-Meter, VR 2....SSB S-Meter, VR 3....SSB Squelch Range, VR 4....AM/FM Squelch Range, VR 5....FM Deviation, VR 6....SSB Carrier Balance, VR 7....TX Offset, VR 8....CW Beep Level, VR 9....RF Meter, VR10...Final Bias, VR11...Final Bias, VR12...Driver Bias, VR13...SSB ALC, VR14...AM/FM High Power, VR15...AM Modulation Meter, VR16...AM Modulation, VR17...SSB Power, VR18...AM/FM Low Power, VR601..13.8 Volt Power Supply. DX 22B- VR 1....AM/FM S-Meter, VR 2....SSB S-Meter, VR 3....SSB Squelch Range, VR 4....AM/FM Squelch Range, VR 7....SSB Carrier Balance, VR 8....RF Meter, VR11...Driver Bias, VR12...SSB ALC, VR13...High Power, VR14...AMC, VR15...AM Low Power, VR16...SSB Low Power, VR21...TX Offset, VC 1....10.240, VC 2....10.240. DX 11B- VR 1....AM/FM S-Meter, VR 2....SSB/CW S-Meter, VR 3....SSB Squelch Range, VR 4....AM/FM Squelch Range, VR 5.....FM Deviation, VR 7....SSB Carrier Balance, VR 8....RF Meter, VR10...Final Bias, VR11...Driver Bias, VR12...SSB ALC, VR13...AM/FM High Power, VR14...AM Modulation, VR16...CW Tone Level, VR20...Final Bias, VR21...TX Offset, VR601..13.8 Volt Power Supply, VR803..AM/FM Low Power. DX 77HML, DX 88HL, and DX 99V- VR 1....AM/FM S-Meter, VR 2....SSB S-Meter, VR 3....SSB Squelch Range, VR 4....AM/FM Squelch Range, VR 5.....FM Deviation, VR 7....SSB Carrier Balance, VR 8....RF Meter, VR10...Final Bias, VR11...Driver Bias, VR12...SSB ALC, VR13...AM/FM High Power, VR14...AM Modulation, VR16...AM/FM Low Power, VR20...Final Bias, VR21...TX Offset.
Unmarked VR in R189..AM/FM Medium Power for DX 77HML only. DX 33HML, DX 44V, DX 55V, DX 66V, and DX 73V- VR 1....AM/FM S-Meter, VR 4....AM/FM Squelch Range, VR 5.....FM Deviation, VR 8....RF Meter, VR12...Low Power AM Modulation, VR13...AM/FM High Power, VR14...High Power AM Modulation, VR16...AM/FM Low Power.
Unmarked VR in R188..AM/FM Medium Power (DX 33HML only)
Unmarked VR in C139..Med Power AM modulation (DX 33HML only) DX 949,DX 959- VR 1....AM S-Meter, VR 2....SSB S-Meter, VR 3....SSB Squelch Range, VR 4....AM Squelch Range, VR 6.....SSB Carrier Balance, VR 7....TX Offset, VR 9....RF Meter, VR10...Final Bias, VR12...Driver Bias, VR13...SSB ALC, VR14...AM High Power, VR15...AM Modulation Meter, VR16...AM Modulation, VR17...SSB Power, VR18...AM Low Power, VC1....10.240. DX 2517 and DX 2527-
Symptom:Buzzing or motorboating sound in either the transmit or receive.
Problem: TR602 is oscillating
Cure: Replace C602 with a .01uF cap {Cap is located in the power supply board}.
RG 66,99,DX2517 Replace Q54 2SB754 60watt 7A with a higher power 2SB817 100 Watt 12A. Derating of this component will cool operation, provide better voltage stability,decrease wobble, allow voltage increase to 14.5 volts comfortably. (replace 10 volt caps in this section of the radio to a minimum of 16 volts before increasing supply voltage to this level)and provide faster swing rise time, Replace Q37 2SA473 to a 2SA1012-0 or ECG153 this will improve the clarity and volume of the modulation and it will also run a lot cooler.
Akg c1000s replacement grille
Maybe you could find a local music store that repairs equipment to replace the grill. Sometimes you can find parts on websites like Ebay.
2helpful
Plastic housing on c419 broken
Sorry that the parts list is in German, but at least you can look at the visual, see how they are put together and order the parts. Although this microphone has been discontinued, parts should still be available from AKG.
See the pdf file at the following link:
www.akg.com/mediendatenbank2/psfile/datei/47/C4184055d1f88cd3f.pdf
You will also find the email address and phone number of the American distributor. You can also visit akg's website at:
http://www.akg.com/
If my assistance helps you solve your problem, I'd appreciate your rating. Thanks for using Fixya.com
 Grubhead
Grubhead
SmartAviator
SmartAviator
