Question about Whirlpool Duet 7.0 Cu. Ft. Super Capacity Plus Electric Dryer
What does F35 code mean? - Whirlpool Duet 7.0 Cu. Ft. Super Capacity Plus Electric Dryer
  • Whirlpool Master
  • 1,902 Answers
Hello & Welcome to FixYa
F35 error means that there is some sort of issue with the steamer electronic board and analog pressure sensor has gone bad. Check that the hose is firmly attached with the washer and is not blocked. You can also check the water level pressure switch operation. Please get back to me if you have any other questions.
Kevin
Posted on May 27, 2011
What is the solution of error35 in w455h washing machine
Hi! If you mean error F35, this error code indicates an analog pressure sensor error. This sensor is the component that detects water level in the washer tub.
F35 error code can be caused by a problem with the air pressure tube between the bottom of the washer tub and the analog pressure sensor.
Apr 27, 2017 | Washing Machines
We are getting a code; F35...do you know what it could mean?
Hello
Kevin
Nov 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F35 failure code
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.*(*&^
Jul 16, 2010 | Kenmore Elite 45986 Front Load Washer
WHAT DOES F35 CODE MEAN
F35 is the pressure switch which is located under the top panel on the back right. It may be faulty or have loose connections.
Apr 19, 2010 | Kenmore Elite 45986 Front Load Washer
Whirlpool Duet Steam washer
HELLO.F35 IS A ERROR CODE WHICH NEEDS THE ASSISTANCE OF A WHILPOOL SERVICE AGENT.THE CONTROL BOARD MIGHT NEED TO BE REPROGRAMED BEFOR YOU CONSIDER REPLACING IT.GOODLUCK.MOHAMED
Sep 15, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Sears Kenmore HE3 Error Code F35
Aug 25, 2008 | Kenmore Elite 45986 Front Load Washer
Error code f35-3 on konica minolta 7145 copier
How to reset failure codes (F34, F35, F36). To reset failure codes, perform the following: 1. Enter the 25 mode (turn the machine ON, while pressing the 2 and 5 keys). 2. Select [1. software SW settings]. 3. Using the arrows on the left of the touchscreen scroll to DIP SW 3. 4. Using the middle arrows scroll to BIT 1. 5. On the touchscreen select OFF (0). 6. Power the copier OFF/ON.
Mar 04, 2008 | Office Equipment & Supplies
Whirlpool Duet 7.0 Cu. Ft. Super Capacity Plus Electric Dryer Logo
79 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
