DVD PLayer Region Unlock
Hi
I am from India. I have Philips DVP 5150 model DVD Player. I tried few DVDs but it says "WRONG REGION". i would like to know how to unlock this region code.
RGDS
  • dark0803 Jan 03, 2009
    Hi
    I am from the Philippines. I have Pensonic Midi Karaoke DVD Player model MD5455. I tried my original DVD disc but it says "WRONG REGION". i would like to know how to unlock
    this region code.
    DarK_M.A.
  • Anonymous Jan 07, 2009
    unknown disc
    Guru:
  • 1,463 Answers
Hello mushkil
you could try the following
1. Turn on the unit
2. Open the loading tray
3. Press the "Setup" button on the remote
4. Navigate to the "Preferences" page using the right arrow key
5. Enter 138931
6. You will now see the current region code displayed
7. Use the Up/Down arrow keys to select the region required or "0" for all
regions
8. Press the "Play" button on the remote
this should unlock it to all regions .
riz.
Posted on Aug 16, 2008
    Master:
  • Televison & ... Master
  • 883 Answers
If you are limited by the region code of discs, you could get a region free player which can enable you to play Blu-ray and DVD discs from any regions. You could try Leawo Blu-ray Player which is a region free and 4K Blu-ray player.
Posted on Jul 04, 2019
1. Power ON the DVD player with no disc inside
2. Goto SETUP and go to Preferences
3. With preferences highlighted, Press NEXT CHAPTER>',
PREVIOUS CHAPTER '<, NEXT CHAPTER>',
PREVIOUS CHAPTER '<
4. The OSD will show the current Region Code
5. Press the Navigation Up or Navigation Down buttons to
select your desired region, or 0 for region free
6. Press OK to confirm your region selection
Posted on Dec 18, 2012
SOURCE:
I bought some DVDs at amazon.com, but I live outside the region code area witch the DVDs are supposed to work. I live in code area 4. I need someone to find a code to region 1. I have a Phillips home...
This player is relatively easy to change to region free. Please complete all of the steps below to unlock your DVD player.
Please note: Unlocking any DVD player may invalidate the warranty. Unlock sequences may not work with some firmware updates and some DVD players have been damaged through failed attempts to unlock them. Unlocking your DVD player is done at your own risk.
Unlock sequence for the Philips DVP 3020:
1. Switch on your TV and DVD player;
2. Make sure the TV is set to the correct input for the DVD player;
3. Remove any disc from the DVD player and close the disc tray;
4. Press the "SETUP" button on the DVD player remote control;
5. Use the LEFT/RIGHT arrow keys to highlight "PREFERENCE";
6. Enter 1 3 8 9 3 1 using the numerical keys on the Philips DVD remote control;
A pop-up menu will appear on the TV screen.
7. Use the UP/DOWN arrow key and choose "0" for all regions;
That's it. You should now be able to watch DVDs from all regions on your player. It is also a good idea to switch the player to standby and then switch it back on before trying any discs.
This is a verified unlock sequence for the Philips DVP 3020. If it doesn't work the first time, switch the power off and start again at step 1. If it still doesn't work, it is likely that you have updated your Firmware to a new version and this unlock sequence does not work with your firmware version
If you need further assistance, please reply to me from within this page and let me know which firmware version you have installed in your DVD player.
Regards,
BElectric.
Jan 28, 2011 | Philips Televison & Video
How do you make a philips dvd player model no dvp 5990 region free ???
Philips DVP 5990
How To Make Region Free:
press Setup
select the Preference Tab
Press 1 3 8 9 3 1
Press up/down key to select "0"
and press Setup to exit.
If you can't get into Preferences Tab, you may need to press the stop button twice first, then press setup.
Sep 17, 2009 | Philips DVP5990 DVD Player
DVD movies form Amazon show in India ''wrong region''.
try to unlock your dvd player to play all free region. what you need is the code to unlock and a remote control to enter the into menu/programming mode. please specify model # of your dvd player when you look for the unlock key.
Apr 03, 2009 | Philips Televison & Video
Want to unlock Philips DVD player (DVP320)
Did you follow these instructions exactly? If you pressed 9990, as you mentioned, it will not work. You need to press 99990. Do you see region "0" on the display?
start the player without any DVD in it.
open the lid.
while the lid is open press 9,9,9,9,0
you should see region 0 displayed.
close the lid.
Your DVD player is now region free.
note:
replace 0 with 1 to 6 at to set the wanted region number if needed.
Mar 05, 2009 | Philips DVP320 DVD Player
Unlock region code
Keep Tray in eject position
Press Setup from remot
Go to preference page
Press"138931"
Using Navigation Key chane region code to "0"
Press "OK"
OR
open tray
press 98790
Jun 25, 2008 | Philips DVP3040 DVD Player
My DVD player Phillips dvp 5150 show a region error when i try to play DVD.
I have a a Phillips DVD player with the model number DVP 5150. when i tried to insert a CD in the player, it doesn't show the loading screen in TV. My TV ios of samsung, Please help..
Feb 02, 2008 | Televison & Video
Dvd player
Most of the DVDs available in India mostly use Region 2, Region 4 and Region 5 codes, all together in one DVD.
Education on region dvd codes:
http://en.wikipedia.org/wiki/DVD_region_code
If you want something on the cheaper side try a Philips DVP5982 Multi-Region DVD Player.
hope that helps!
Jan 31, 2008 | Panasonic DVD-S52 DVD Player
Unlock region codes
Hi All,
I am looking for the region unlock code for a Sony portable
DVD player.Model number DVP-FX720
Jan 12, 2008 | Insignia NS-PDVD8 Portable DVD Player
Multi region
Your DVD player can be hacked by following the attached guide so that it will play any region. http://www.videohelp.com/dvdhacks/philips-dvp-320/3522
Jun 21, 2007 | Philips DVP320 DVD Player
Televison & Video Logo
753 people viewed this question
Top Televison & Video Experts
Ekse
