Question about Astoria Argenta SAE-3 Espresso Machine
I have boiler pressure and steam coming threw the wands but no water flowing through the brew heads. What could be the problem?
    President:
  • 1,618 Answers
Either the solenoids are damaged or blocked, or the metering jet on the top of the group is blocked, or the blockage is at the flowmeters. Do you get a reading on the pump pressure gauge when the buttons are pressed?
Posted on Jun 02, 2011
How to fix the wand on the espresso machine, not enough pressure is coming from the wand to steam the milk.
First check the steam wand tip to make sure it is not blocked. If it is clear remove the wand and run it under a faucet to make sure it is not blocked, it water flows freely, then the problem is on the fitting that connects the valve to the boiler, remove fitting and check, if clear check the boiler fitting, use a screwdriver and clear the fitting on top of the boiler.
Jun 28, 2011 | Astoria Compact CKXE Espresso Machine
Gaggia Coffee Delux Steam pressure probem
1: do you pres the switch for steam and wait until it is ready? 2: how long time machine needs to be ready for steaming?
solution 1 = if you don't press the steam switch on you will have very small amount of steam. solution 2 = if the machine gets ready only for few seconds to steam, than you must change your steaming thermostat attached in boiler(there are 3 of them: 1 security 2 coffee brewing 3 steam
i hope you fix it soon and enjoy in perfect espresso
Apr 04, 2010 | Gaggia Coffe Deluxe Coffee Maker, Espresso...
Can't get steam from the a Starbucks Saeco Italila Digital Auto
Hi If you can get water to flow from the wand, you can descale the machine. You might have a bad steam boiler. There is also a fuse on the boiler that might be bad. Set your water hardness to 4 to keep the machine working for a long time. Descale more often than not enough.
Jan 26, 2010 | Starbucks Saeco Italia Digital Barista...
Water leaking and coffee dry
Sounds like the boiler is blocked, and machine needs to be descaled. Try this first remove the parnello if your machine has one on the steam wand then using a paperclip clear out the end of the wand, that might be blocked. If it isn't then run the descale to clear out the blockage in the boiler.
Oct 05, 2009 | Saeco 00034 Incanto Sirius Super Automatic...
Steam comes from wand when set to dispense water.
Check the connection to the boiler from the pump, there is no water going to the boiler. Try this test, remove the brew unit you will see a white plastic valve behind it, carefully lift the small lever on the valve(HOT WATER), if water sprays, then the problen is at the brew unit, if no water then the boiler inlet or outlet is clogged.
Jul 01, 2009 | Saeco Magic De Luxe Espresso Machine
Trouble installing replcement gasket in Solis Crema SL 70
SL 70/90 Brew Head Gasket Replacement Time 1 to 2 hrs Tools # 2 allen wrench # 1 Phillips screw driver # 2 Phillips screw driver # 13mm wrench First unplug the machine. Next remove the screw in the top back of the machine. Push the top forward with your fingers. This unlocks the top and it can be placed behind the machine with the wire connected. Next rotate the steam knob counter clockwise till it stops. Inside next to the micro switch there is a brown cam. On the backside of the cam is the #2 allen screw. Loosen this screw and the rotate the steam knob clockwise until it is removed. Now remove the clip on the steam manifold that holds the steam wand. There may be a plastic tie that is securing the clip. Cut it. Pull out the steam wand and let it rest on the bottom cover. Next remove the 4 large screws that hold the cover plate around the brew head. This will allow the cover plate to drop down and swivel on the steam wand, exposing the nuts that hold the boiler on the bottom metal plate. The nuts that hold the boiler on are # 8. Before you loosen the nuts you need to remove the water inlet nut on the side of the boiler. It is a #13 wrench. Remove the water line. Now remove the nuts that hold the boiler on.
Jun 16, 2009 | Solis Crema SL-70 Espresso Machine
Water pump?
If you could brewer coffee or get hot water out of the steam wand then it could be the one way valve on the bottom of the water tank. If you are running the pump output into a glass then it is probably scaled up in the boiler.
Jan 02, 2009 | Saeco Magic De Luxe Espresso Machine
Water not coming through espresso side although steam wand works fine
you both can have same problem, solution is:
  1. low pressure of pump (or too fone grinded coffee)
  2. security valve of boiler openes to early and dont let the pump to rise pressure enough for good brewing( if it is this you can see water returning back to container if you have 2nd pipe in your machines reservoir)
Oct 05, 2007 | Krups Bravo Plus 872 Espresso Machine
Astoria Argenta SAE-3 Espresso Machine Logo
165 people viewed this question
Top Astoria Coffee Makers & Espresso Machines Experts
Charles T Nevin
Charles T Nevin
J.D. Browning
J.D. Browning
obsteiner
Are you an Astoria Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
