Mtd 22" Yard Machine Push Mower Logo
Posted on May 27, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where can I get the type of oil needed for the yard machine(22 in) push mower?
Roy Cagle
Level 3:
President:
  • Mtd Master 1,545 Answers
  • Posted on May 27, 2011
Roy Cagle
Mtd Master
Level 3:
President:
Answers
1545
Questions
Helped
913208
Points
4781
You can use regular SAE 30 weight oil from the auto parts store. If you use multi-viscosity, make sure it is synthetic, otherwise use straight SAE30 oil.
6helpful
Weed eater 22" mower with
Hi stnstomper...
Look under the mower for a square plug or allen wrench type plug, this will be your oil drain for the motor.
Some of Briggs & Stratton motors do not have an oil drain plug...
If you do not have an oil drain plug then you will have to run the mower to get it warm, then remove the oil fill plug and tip the mower towards the oil fill plug to drain out the oil thru the fill plug hole.
Free Answer...Please take time to rate me
How much oil goes in a 22'' inch MTD yard machine push mower
Most normal push mowers require 20 ounces of engine oil. I recommend that you use only SAE 30 oil and try to use synthetic.
1helpful
What type of oil is used in a yard machine lawn mower model no. 11A-414E029
SAE 30WT i.e non detergent. Change oil every 25 hours and every 4th oil change us a detergent 30 WT oil.
The manuals will never tell you that but having worked on small engines since the mid 60's that 4th oil change with a detergent oil does a bang up job of keeping the oil ring from eventually cooking onto the piston. Also washes out the crank case and makes it look like new!
Kelly
Yard Machine push mower needs oil changed. How do I know how much oil to put in it. No Dip Stick
when you unscrew the oil cap is should have an oil level mark on the side of it.
2helpful
What type of oil does a OHV 17.5 HP Kohler engine; number of zerk
10w-30 oil. The only grease fittings I know of are on the front wheels and axles.
Where do you drain the oil on a 4 hp yard machine
to drain the oil then you open the oil cap and tip it over and let the oil drain out.
What kind of engine oil does an MTD 22" Yard Machine take?
All engine makers use 30 weight oil in their engines except for kohler...they use 10W30.
Top Mtd Garden Experts
ZJ Limited
ZJ Limited
Sean Wright
Sean Wright
john h
Are you a Mtd Garden Expert? Answer questions, earn points and help others
