Question about E-Machines eMachines Monitor E15T4
I need a (dvi and vga and power) cord to hook up my monitor My Model type is eMachine LE1987. Product E19T6W
    Brigadier General:
  • 10,406 Answers
Go to any computer-store, and buy a cable.
Or, look on www.eBay.com for a seller of such a cable.
Posted on Jun 07, 2011
Want to restore my computer. How do I do that?
I would need more info to answer that question for you. The title say question about Emachine E19T6W? That is the monitor? What is the make an model of the computor you want to restore?
Jul 11, 2014 | eMachines E19T6W 19" Monitor
Where is the nearest retail store to me
Rather depends where you are!! Area 24441 could be in Coventry, Virginia or sevral other places.
May 23, 2014 | E-Machines eMachines Desktop PC
The screen reads no signal
eMachines flat-screen monitors offer high quality at low cost.
eMachines flat-screen monitors are compatible with most brands of PCs.
Issues with eMachines flat-screen monitors can arise from faulty power sources, cable problems and incompatible settings.
These issues can be resolved by testing step-by-step each possible cause.
Plug the computer's power cable firmly into a working AC outlet.
Press the computer's power button.
Check the LEDs on the front of the computer case to confirm that the computer receives power.
Plug the eMachines monitor's power cable into a working AC outlet.
Press the monitor's power button.
Check the LEDs on the front bezel or power button of the eMachines monitor to confirm that the monitor receives power.
Orange or blinking LEDs indicate low power or no signal.
Green LEDs denote a working connection..
Perform a monitor self-test.
Switch off the monitor.
Unplug the video cable from the monitor.
Press the eMachines monitor's power button.
An eMachines logo, Windows logo or "no signal" message indicates that the monitor is working properly.
Plug the eMachines monitor's video cable into the video port on the computer.
Attach the monitor's included DVI-to-VGA adapter to the monitor's VGA cable if your computer has a DVI port (15 or 25 pin-slots with 1 side slot) in place of a VGA port (15 pin-slots, no side slot).
Press the eMachines monitor's input button to change the monitor's setting to match the computer port used.
Set your monitor to DVI if connected to your computer's DVI port.
Set your monitor to VGA if connected to your computer's VGA port.
Connect the eMachines monitor to a known working computer with a known working video cable if the problem persists. Contact Gateway, eMachines manufacturer, if the monitor issue is not resolved.
Jul 15, 2013 | Acer eMachines Black EL1850G-42w Desktop...
Can i get an adapter for my emachine monitor to go into a dell desktop ...my lead i have now doesnt fit as unable to screw it in
YES.
I believe it is time now for the guessing game............
1) Is the monitor about so high, and so wide?
2) Does the monitor look like a small TV, or is it flat in appearance?
3) What does the monitor cable look like?
4) Is your hair Brown, and do you smoke cigarettes?
NO.............just wanted to see if you were following along! Geez!
An Analog monitor, such as a CRT type of monitor, uses a VGA cable,
http://www.wisegeek.org/what-is-a-crt-monitor.htm
http://en.wikipedia.org/wiki/VGA_Connector
Scroll down a little for a VGA Cable example.
Flat LCD screen monitors are Digital.
Some may have a VGA Cable attached, but the best cable option is a DVI cable,
http://en.wikipedia.org/wiki/Digital_Visual_Interface
(Click on any photo on those two Wikipedia pages, to enlarge)
Using these two examples, does one apply to the eMachines, and one apply to the monitor?
Let us say the monitor has a DVI cable.
The eMachines Desktop PC has a VGA port. (Connector)
For this you would simply use a DVI to VGA adapter,
http://www.directron.com/dviadapter.html
Now notice...........this is a VGA MALE to DVI FEMALE.
The DVI cable on the flat LCD screen monitor, has a male connector.
The contact pins of it go into socket holes, in the DVI end, of the DVI to VGA adapter.
The VGA port on the eMachines, has socket holes.
The male VGA connector end on the DVI to VGA adapter, has contact pins.
Point?
Make sure you get the correct DVI to VGA adapter.
There is a male DVI to female VGA adapter, also.
This is just one example.
For instance I'm using an HP 2009M 20-inch widescreen monitor, AND an RCA 26-inch HDTV, as dual monitors.
Presently using the HP 2009M with a DVI cable, and the RCA L26HD31 HDTV with a VGA cable.
(I'm also using an ATI Radeon HD5450 graphics card. Pretty 'pud', but it does OK for what I want)
Primer;
A computer sends out a digital signal. To get the best graphics quality, you ideally use a monitor with a digital cable. (DVI, etc)
When you use an Analog monitor on a computer, the computer has to change the digital signal down to an Analog one.
Therefore the graphics quality is not as great.
Digital cable technology now, is DVI, HDMI, Display Port, and Mini-Display Port. And some others I'm sure I've forgotten.
http://www.hardwaresecrets.com/article/Video-Connectors-Tutorial/157
For additional questions please post in a Comment.
Also post what the monitor manufacturer name, and model number is. (Look on the back)
Are you using the VGA connector on the motherboard, (Back of computer), or do you have a graphics card installed?
If you have a graphics card installed, what is the manufacturer name, and model number?
Regards,
joecoolvette
Mar 06, 2013 | Dell Dimension 4300 PC Desktop
No Video
If its a flat screen monitor ?
eMachines flat-screen monitors offer high quality at low cost. eMachines flat-screen monitors are compatible with most brands of PCs. Issues with eMachines flat-screen monitors can arise from faulty power sources, cable problems and incompatible settings. These issues can be resolved by testing step-by-step each possible cause.
Plug the computer's power cable firmly into a working AC outlet. Press the computer's power button.
Check the LEDs on the front of the computer case to confirm that the computer receives power. Plug the eMachines monitor's power cable into a working AC outlet. Press the monitor's power button. Check the LEDs on the front bezel or power button of the eMachines monitor to confirm that the monitor receives power. Orange or blinking LEDs indicate low power or no signal. Green LEDs denote a working connection.. Perform a monitor self-test. Switch off the monitor. Unplug the video cable from the monitor. Press the eMachines monitor's power button. An eMachines logo, Windows logo or "no signal" message indicates that the monitor is working properly. Plug the eMachines monitor's video cable into the video port on the computer. Attach the monitor's included DVI-to-VGA adapter to the monitor's VGA cable if your computer has a DVI port (15 or 25 pin-slots with 1 side slot) in place of a VGA port (15 pin-slots, no side slot). Press the eMachines monitor's input button to change the monitor's setting to match the computer port used. Set your monitor to DVI if connected to your computer's DVI port. Set your monitor to VGA if connected to your computer's VGA port. Connect the eMachines monitor to a known working computer with a known working video cable if the problem persists. Contact Gateway, eMachines manufacturer, if the monitor issue is not resolved. Hope this helps.
Jan 03, 2013 | Computers & Internet
Can i connect my xbox 360 using Dvi D to Hdmi in the dvi slot and also my tower to the vga slot on my eMachines E19T6W
I am not an xbox person, but as far as hooking it up, it should work as long as the other device is NOT powered up. That being said you will still have to provide audio from the xbox another way as dvi only carries a video signal, unlike the hdmi which carries both audio and video.
Dec 12, 2011 | eMachines E19T6W 19" Monitor
I have an Emachine model 568 part number E1573r. the monitor cable plugs into the computer but it has a wire with anther plug where does it go
Most new monitors these days have two 'plugs' for input:
The one that's 3 rows of 5 pins (usually blue) is VGA, which is the older type. (Picture here: http://upload.wikimedia.org/wikipedia/commons/thumb/8/81/Vga-cable.jpg/750px-Vga-cable.jpg )
The more common one is a white connector, and lots of pins is called DVI. ( Picture here: http://upload.wikimedia.org/wikipedia/commons/3/37/Dvi-cable.jpg )
You can use whichever you want, but if your computer has DVI, use that, as you'll get a better quality picture. You only need one of the two to be plugged in
Dec 01, 2010 | E-Machines eMachines Monitor E15T4
I need the power cord and the other two cords for model#1701ap.its a monitor .the monitor has 3 cables that hook to the back of it Ineed all threre
All cables can be fount at any IT shop or site. BTW you need only 2: one for power - like this one
http://www.ciao.co.uk/Belkin_Components_Power_cable_Power_3_pole__5369096 -
and only one for data - like one of these
VGA  http://www.amazon.co.uk/dp/B0000B1K4E/ref=asc_df_B0000B1K4E642217?smid=A1AUCPBF2P18HS&tag=ciaouk-ce-mp-21&linkCode=asn&creative=7974&creativeASIN=B0000B1K4E
DVI    http://www.corporatecoms.com/catalog/product/view/id/9231/s/belkin-cable-3m-proseries-dvi-dvi/
May 05, 2010 | Computers & Internet
DVI input on monitor not working
Contacted viewsonic about this issue- they suggested- have both dvi and vga hooked up to same machine. start with poweroff on both. power on monitor, then power on computer. when you see display coming from the vga, power off pc, then disconnect vga cable, turn off power to monitor, disconnect power cord from monitor for 5 + seconds, reconnect power cord, power on monitor, then power on pc.
If this doesn't work to get the dvi working, (as happened to us) we returned our monitor for a replacement, since it was still under warranty.
Sep 17, 2007 | ViewSonic VX2025wm 20.1" LCD Monitor
E-Machines eMachines Monitor E15T4 Logo
125 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
