Icon at bottom says not connected but it is connected. It is intermittent. I constantly have to disconnect and then connect. it only works for awhile. had the router for 8 months never had a problem. I live in an apartment complex. Could that be the problem
  • 61 Answers
I would suggest unplugging the power to the modem and router, plugging the power into the modem back first, then your router. If this does not solve your issue, try bypassing the router and using just the modem. If the problem keeps happening without the router then there is an issue with your internet service and you should contact your ISP. If you find that this just happens only with your router, then there could be a number of reasons why this is happening. Try resetting the settings on your router by using a paperclip or pin in the back. You will need to configure your security and other settings if you do this so beware. Hope this helps!
Posted on May 26, 2011
How do I connect the bluetooth on a marshall stanmore bluetooth speaker?
Check if you have the correct icon, or look on the web for help.
Nov 04, 2014 | Marshall Stanmore Bluetooth Speaker
Toshiba Satellite M45 WinXP keeps dropping wireless internet connection.
Try to do update from Control Panel - Security Center - Automatic update.
Jan 29, 2014 | Toshiba Satellite M45-S331 Notebook
CDX-GT4301P sony car radio loses station/settings memory intermittently.
At the back of the head unit, there are usually two power connections to the car battery live. One is via the ignition, and the other is (usually) a fused connection that connects directly to a relay or fuse that has constant power, even when the car is switched off. This constant power allows your head unit to hold its memory. If the loss of memory is intermittent, it could be a loose cable or corrosion on the fuse.
Oct 22, 2013 | Car Audio & Video
Laptop keeps losing connection to Internet
if you're using Wifi or modem,perhaps the signal are too weak
Aug 26, 2012 | Toshiba Satellite Computers & Internet
I have a Dell Inspiron...I have problems with the internet - it is slow responding and will constantly freeze and tell me that the site is not reponding...what can I do?
Hi there
Have you pushed START then to "Connect to" there you can if you are connected, if nothing comes up push on " show all connections"
Choose the connection that you prefer to connect to.
You will be helped through the process.
Hope you will succeed.
kolbrun.
Feb 29, 2012 | Dell Inspiron 1525 Notebook
My router constantly disconnects. It used to work fine in my room, and now it literally cannot stay connected for a consistent 5 minutes (at best). I haven't changed my computer's location, the router has...
Try connecting an ethernet cable from your computer/laptop to one of the lan ports on the router.
If your connection is still intermittent then replace your router. If your connection is stable then replace your antenna.
They do sell replacement antennas at radio shack or best buys.
Let me know how it goes.
Please don't forget to give me a rating and a vote.
Mar 24, 2010 | D-Link 802.11g Wireless Router WBR-1310...
There's a constant hourglass icon that comes on & no email
Hi, its a connectivity issue please contact your service provider, they will help you
Oct 24, 2009 | RIM BlackBerry 8700c Cellular Phone
Netgear wg111v2 wireless constantly connects and disconnects
Set the security on the wireless router to WEP and perform the steps below to configure settings:
1. Right click on My Computer icon and go to Manage.
2. Go to Services then go to Service and Applications.
3. Double click on Wireless Zero Configuration.
4. Change the Start Up Type to Automatic and click on Apply
5. Click on Start and press OK to close the window.
6. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
7. Right-click on the wireless Network Connection icon and select 'Properties'.
8. Go to the 'Wireless Networks' tab .
9. Check the option 'Use Windows to Configure this Wireless Connection' and click 'OK'.
Now please perform the following instructions to connect to the wireless network:
1. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
2. Right-click on the wireless Network Connection icon and select 'Properties'.
3. Click on the 'wireless network' tab.
4. Under Preferred networks if you see any name in the list then highlight the name and click remove.Click OK.
5. Right-click on the wireless Network Connection icon and select 'View Available Networks'.
6. Look for the SSID (aka Network Name) of the Wireless router or access point.
4. Highlight the SSID from the list that you want to connect to.
5. Type the security Key here and click on the 'Connect' button.
6. You should have successfully established a wireless network connection.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Jul 09, 2009 | NetGear WG111 802.11g/b Wireless Adapter
Internet and Network Connection
we had similar problem earlier and unformtualtly we have to install the OS again. you can first check you firewall setting, try disabling firewall and check. Or will suggest reinstall the OS.
You can also try running antivirus/antispy/CCleaner etc before that.
Regards,
Sails
Mar 11, 2009 | Microsoft Windows Vista Home Basic Edition
Intermittent connection to wireless network
Two possibilities to consider --
There are reports the combination of a hidden SSID and WEP/WPA encryption causes intermittent connections using Windows. Recommended solution to show the SSID instead of hiding it.
Second possibility consider changing the channel the wireless communicates on in the router from the often default 6 to 1 or 11 to see if you can avoid interference on channel 6. Try the other channel if the first does not work. Interference is not only from routers but can be from in house wireless phones and other devices.
Dec 22, 2007 | IBM ThinkPad T43 Notebook
Computers & Internet Logo
David Payne
David Payne
