Question about McCulloch FG6000MK 5700Watt 13 HP 338CC Portable Generator
My generator will start if I spray it with either but won't stay running in less I keep spraying it. The bowl has gas in it and the needle is clean. It just won't keep running if I don't spay either or carb spay in it. Can you help need power bad thanks bill
Main jet is clogged
Posted on May 27, 2011
Has gas in bowl and fire but wont start without starting fluid
McCulloch u spray starter fluid Power Generators Questions ...
www.fixya.com > Forum > Tags > u spray starter fluid > Power Generators
McCulloch power generators u spray starter fluid related questions and ... Question about 13HP 338 Cc Portable Generator # FG6000MK ... My 5700 watt 11 HPMcCullough generator wont ... My generator will start if I spray it with either but won'tstay running in less I keep ... The bowl has gas in it and the needle is clean.
This generator McCulloch fg6000mk 11hp has no spark. I've ...
www.fixya.com/.../t7785814-generator_mcculloch_fg6000mk_11hp_no
Jan 13, 2011 - this generator McCulloch fg6000mk 11hp has no spark. I've checked the gas bowl , a small amount of water in the - McCulloch ... water in the bowl not much also sprayed a small amount of starting fluid in .... My 5700 watt 11 HPMcCullough generator wont start. I'm getting good gas to the plug but no spark.
Won't start. I have a never used McCulloch 5700 11HP ...
www.dqrkc.com/support/t1325485-start
Dec 2, 2008 - Question about McCulloch 13HP 338 Cc Portable Generator # ...evaporated. you might tryt a little spray starter fluid in the spark plug ... My generatorwill start if I spray it with either but won't stay running in ... The bowl has gas in it and the needle is clean. ... My 5700 watt 11 HP McCullough generator wont.
1325485 Won't start. I have a never used McCulloch 5700
Jan 21, 2016 | McCulloch 11 HP 5700 WATT GENERATOR
Huaya carb no gas in bowl
the needle has to fall down and follow the float movement
if it doesn't it is stuck on the seat and may need replacing as it has a small rubber section that may damage when pulled down
Apr 24, 2017 | Cub Cadet Electrical Supplies
Generator Won't start
Gap the plug at .030 What is most likely the main problem is whatever gas sat in the carb. Even with fresh gas there will be some old gas still in the float bowl. You may be able to drain the bowl and be OK but I have a feeling that the carb will need to come off and be disassembled and cleaned properly. You can try spraying carb cleaner (I dislike starting fluid as it is too volatile and carb cleaner does just as well in this instance) into the carb/intake. Remove the air filter, open the choke, and spray the carb cleaner in through that way if possible. You can actually keep an engine running by spraying with short bursts. Even by just spraying once you should be able to get the engine to start. If it does start but then will not stay running without spraying more into the engine then it is a carb problem.
Aug 24, 2012 | Coleman Powermate 6250 10hp Generator
EB5000 been sitting 6 months, have fuel stabilizer in gas. Will start, but won't stay running. I sprayed starter fluid and it kept running until I stopped spraying the fluid.
Hi and welcome to FixYa, I am Kelly
If the generator has sat for some time the fuel in the float bowl will turn into a varnish like substance (shellac). The residual fuel in the carb will have to be removed. You do this by removing the fuel solenoid (or bowl nut) which ever one youhave that secures the float bowl to the carb. Then take a screw driver and remove the main fuel orifice and remove the debris from the main fuel orifice. Clean the orifice with carb cleaner. DO NOT push anything into the hole! Also spray the brass tube that the main fuel jet screws into with carb cleaner. You should see carb cleaner being sprayed into the throat of the carb.
While the fuel float bowl is removed get a spray can lid and hold it under the carb float. Turn on the fuel selector and the fuel should completely fill the spray can lid in 8 - 10 seconds. If you do not have this amount of fuel flow you need to remove the main fuel line from the carb and re-check fuel flow. If the flow is good here then use carb cleaner in the float needle area to force any debris back out the fuel manufold connection that is now open because you removed the fuel line. If you still do not have fuel flow then check for debris in the fuel tank exit port, the fuel filter, the sediment bowl under the fuel shut off assembly.
Once again with the spray can lid under the float you should have fuel flow anytime the fuel selector is on and the float level is down. It should shut off fuel just as it reaches level. Any other result and the float and float needle will have to be removed, cleaned and inspected for debris.
Make sure to re-install the main fuel orifice in the treaded area that secures the float bowl in place and.re-connect the main fuel line to the fuel manifold / carb fuel inlet connection
If the engine has a fuel solenoid hook it up and and see of it is working as you turn the key / engine switch on and off before you reinstall the float bowl. You make have to hold the case of the solenoid against the engine to make a ground AWAY from any residual fuel for testing. I.e. don't burn up your generator.
Re-install the fuel float bowl and test the engine. It should now work just fine.
The above steps are successful most of the time on generatosr that have sat idle for an extended period. I have been working on generators large and small for over 40 years.
Thanks for choosing FixYa,
Kelly
Aug 26, 2011 | Honda Electrical Supplies
Flymo petrol mower starts but won't tick over.....keeps cutting out
Probably needs the carburetter cleaned out. Smell a lot of petrol? could be flooding out. Starts up but dies. No smell of excess petrol? Fuel line clogged at tank inlet, rust? Other crud? Gas gets to carb, engine starts then runs out of fuel. I dont know the flymo carb, but generally...
Start by removing the bowl under the carb, 2-3 screws. Youll need to remove the air filter box first. You should find a float tank which operates a needle valve. This can be released by popping out a pin pivot. DO NOT LOSE THE NEEDLE VALVE which will come out with it. A pointed stem which closes the fuel as the float rises. If you see a lot or just a little crud around here, that can be the problem. Clean it out with carb cleaner spraying up into the where the needle seats, also spray into every opening you see. Carefully replace the needle and float. The needle generally snaps into or is locked into the float loosely, then pin the float back in place while guiding the stem back into its hole. Replace the bowl and try to start it.
Good luck
Jun 05, 2011 | Garden
Troy bilt mower ran fine then died and now it wont start back. It has fire and a new spark plug. It gets fuel past the filter. It starts if i put a small amount of gas into the intake. Whats wrong? My...
Remove the air filter and set aside.
Take a can of carburetor cleaner and spray the inside of the carburetor.
Let it set for a moment and then try starting the engine. It should run a few seconds. Repeat. When it starts squirt a small shot of cleaner in the carburetor to keep it running. That should remove the varnish the gas leaves as it evaporates over the winter.
If it still won't keep running then there is trash in the float bowl plugging the needle valve seat and the jets.
1) Turn off the gas or remove the gas line and plug it with a small screw or stick to keep it from leaking out of the gas tank.
2) Look on the bottom of the bowl for a nut .
3) Remove the nut and drop the float bowl.
4) Carefully remove the pin holding the float and needle valve assembly.
5) Take the carburetor cleaner with the straw it comes with and spray every hole in the carburetor to clean the jets . (up through the needle valve seat, down top of the carburetor , see a hole, spray it with the cleaner.)
6) Clean the float bowl.
7) Reassemble and make sure the gas isn't leaking and try to start it again.
Jun 06, 2010 | Mtd Troy-Bilt Bronco OHV Tiller
Unit will start at full choke but will not stay running with choke off,will load up on full choke and stay running around 3/4 choke
HI,
Turn off the gas and take the bowl off the carburetor.Look for water bubbles in the gas that spills away. Water will float like little balls on gas. If so drain gas tank put in new gas with some HEET added. While you have the bowl off spray up and around the bottom of the now exposed carburetor.
Pay attention to spray up the small copper tube in the center of the carb.
Clean out bowl and put it back on. Turn on your gas. Look for leaks around the replaced bowl. Good luck.
Jan 29, 2010 | Coleman Powermate Powermate 5000W...
I spray carb fluid into the air intake and it runs. As soon as I stop spraying the carb fluid it stops running?
Hi, Making sure the gas is turned on,
Well the engine is not getting gas. If you have old gas in the unit the gas may have "jelled". A emptying of the tank and cleaning of the fuel line along with taking the bowl off the carburetor and spraying upwards into the carburetor, including around the float and needle and seat, may work. As always the carb cleaner is flammable so caution is good. Luck to you.
Jan 28, 2010 | Briggs & Stratton Power Products 5,550...
Wont stay running
the problems is in the carburetor, common problems when unit does not run often and rust get get build up. get some automotive carburetor cleaners and spray it heavy in the carb, don't worried about flooding it or damaging anything, it will dry out faster than gas. (use little gas if you need to) try to start it up and get it running with the carb cover off and continue to spray carb cleaner in the carb while the engine is running, do this couple of time and hope that would clear it out. if that don't work you will need to take it apart and clean it. you have small tiny object obstructing the carb flow. the unit doesn't have a fuel pump, it run on gravity feed, the carb are easily obstructed. hope that help a bit
Sep 30, 2009 | Coleman Powermate Premium Plus 6250W...
Coleman Powermate 5000 starts with starter fluid, but leaks gas into the air filter. Checked the float, it has no holes, and is not jammed. Fuel will go into the carburetor, but no fuel will reach the...
Sounds like you need to clean the carb ports, lines, jets, etc... purchase a carb spray cleaner with a tube to place on the spray head (Berryman's Chemtool B-12 is awesome). Take the carb loose from the generator, and remove the bowl, needle valve and spray carb cleaner thru all the holes, lines in the carb. Reinstall complete with air cleaner and retry... also if the gas is old, drain and replace with new...
May 25, 2009 | Coleman Powermate Powermate 5000W...
McCulloch FG6000MK 5700Watt 13 HP 338CC Portable Generator Logo
854 people viewed this question
Top McCulloch Electrical Supplies Experts
John Trevino
Roland W VanLue
Roland W VanLue
Are you a McCulloch Electrical Supply Expert? Answer questions, earn points and help others
