Monitor suddenly went black. Whn restarted,the monitor came on for about 3 seconds, then went black again.
  • Cathann Smith May 26, 2011
    Have you checked all the cords especially power cord for the monitor. How old is the monitor?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 50 Answers
This may be shot in the dark...since you may have already thought of it...
Could it be that you've accidentally hit some keystrokes that placed your monitor into the mode for viewing it on an outside source such as a tv?
On my Dell Inspiron 1524 laptop, if I press the FN and F8 (CRT/TV) keys, it temporarily disables my monitor since it assumes that I have a TV connected. Since you didn't list the Make and Model of your laptop, it may be on a different key. The FN key initiates a special function when it's pressed with the appropriate key. If you press the combination again, it should eventually allow you to see your monitor again.
I hope that will solve your problem. If it doesn't you may wish to write again.
--Sandy
Posted on May 27, 2011
Acer aspire 4736Z suddenly went black
Ram chips may be bad. Test it using an external monitor. If the problem does not occur on external monitor then you lcd screen may be going bad
Dec 24, 2013 | Acer Computers & Internet
My Acer AL2216W monitor this morning went blank. I woke up, turned on pc and went to sleep like an hour more, when I woke up, the screen was black and light orange, as usual, when pc is not used for a...
Go to Control Panel, (top right View Small Icons). Then look for Power Options. On this page, you'll have the option to leave the monitor on. You should also check "Advanced Power Options". Don't be afraid of the word, "Advanced." It only means "customizeable"
If your mouse isn't waking your monitor, try the keyboard's space bar. I found it works better than the mouse at waking a sleeping computer
Apr 04, 2017 | Acer AL2216W LCD Monitor
I was playing Fallout 3 and after a while, my screen turned a bit darker, not really dark but as if there is a light shadow on it and after a few seconds it turned black. I tried to press twice on the...
try shining a torch/flash light on the screen
If, when the flashlight is on the monitor, the problem is fixed then you have aback light issue.
You will have to contact your manufacture or shop you bought it from
Mar 04, 2011 | ViewSonic VX1940w LCD Monitor
All of a sudden, the screen display went black. When we restart the computer (Windows XP), we see the initial windows logo but nothing else -- EXCEPT, pressing and holding the screen's "INPUT...
Very doubtful. Either you have a defective or corrupt display driver, or possibly a malware infection. Is that a laptop or notebook computer? If so, is there a VGA port for an external monitor? If do, try using a known good external monitor.
Apr 28, 2017 | Sony SDM-HS74P/S 17" LCD Monitor
Dell E173FP 17 monitor went dark and not working. I restart the pc it shows for only few second and went out again. I plug in one other monitor in my pc and it work fairly well. So something not right with...
Hi!
There are three possible cause why your monitor went black and start working..
1. If your monitor is dead set.. no reaction or lights turn on after power on.. then it needs to check if there is blown capacitor in its power supply section..
2. The high voltage ballast transformer of the backlight inverter is burned - it needs to be replaced so that it will not have a direct effect on the power supply section of the monitor.
3. The backlight inverters are all busted - the backlight was located at the upper and lower back edge of the monitor.. If these lights are busted then all that will be seen in your monitor is black screen.. It will need to be replaced so that image display will come out from your screen..
These 3 reason and its solutions can only be done by yourself if you have the knowledge, proper skills and the right tools to open the back cover of the monitor and replace the problem parts....
Otherwise, bring your monitor to a credible technician and if there is warranty,, avail of this...
Hope that answer your question..
Much appreciated if you rate this help..thanks..
May 20, 2010 | Dell E173FP 17" LCD Monitor
I plugged it in and the screen came up for a second and then went black. I turned it off and turned it back on, the screen came up for a second then went black again. What could be wrong?
is the cpu running ,, with connection to monitor,, you can try restart,, and go to display properties,, screensaver,, there power button and change the settings,,,
Sep 27, 2009 | Dell E173FP 17" LCD Monitor
Used as second monitor suddenly stared to go dark
If the screen is lighting up for a fraction of a second when you turn on & then goes dark, this indicates a fault either with the backlights on the screen or the inverter part of the monitor. You can check the backlights if you have access to a backlight tester, you need to remove the rear cover & connect the backlight cables into the tester, if this checks ok then look for a problem on the inverter board, checking the capacitors for any signs of distress.
Aug 11, 2009 | LG W1934S-BN 19" Monitor
Monitor screen is black
bad capacitors on the power board internal to the monitor they need to be replaced.
Mar 02, 2009 | Proview PL913S 19" Flat Panel LCD Monitor
Monitor turning black
the backlight fluorescent bulb is burned out.
Dec 26, 2008 | Computers & Internet
Problem with samsung syncmaster 540N 15"
To replace all Electrolatic capacitors in Power supply& drie Currected
check all connectors are properly connected r not
Sep 13, 2008 | Samsung SyncMaster 540N 15" LCD Monitor
Computers & Internet Logo
56 people viewed this question
David Payne
David Payne
