Question about Sony PlayStation 3 40GB System
Wont turn off after loosing connection to controller
Im watching a couple of dvd's and suddenly the controller stops to function even if its connected to the ps3 via usb. When i push the ps button on the controller it just blinks. Just bought a new dualshock controller and the same happens to it. When i try to shut down the ps3, the green power lamp just blinks and doing nothing else while the blue lamp is on. Then I'll have to use the switch on the back of the ps3 to restart it. Has this something to do with the last 2 or 3 updates, before that I didn't have a problem?
  • 95 Answers
Update to 2.52
Posted on Nov 11, 2008
Bought at garage sale worked ok in the car but after taking it out of the car it all of the sudden didnt work itll carge but the power light and the screen wont
most in car dvd players have a wire which is connected to the handbrake so that it wont work unless the handbrake is on. (stops you watching films while driving) Try to find a wiring diagram for your unit to find this wire. I am sure that it can be fooled into thinking it is connected but not sure whether it needs to connect to earth(ground) or a positive feed to achieve this.
Hope this helps.
May 09, 2011 | Venturer 3.6" Portable DVD Player
Turntable turns intermittently so unit will not operate
The turntable fan and light all share the same feed, first check wiring for loose connections the problem though is most likely with the controller
Dec 28, 2009 | Viking DMOC205SS Microwave Oven
Maytag HAV2558AWW stopped working all of a sudden. I was doing a load and had it only half filled with water.It will not drain, will not fill the rest of the way. Wont do anything.Any suggestions?
I determined that the problem had something to do with the timer control because it stopped all of a sudden and it would do nothing. I determined that it was not the lid switch because it will fill with water even with the lid up.I checked that the outlet had power. So it must be an electrical problem associated with the timer control. I took off the panel on the back of the timer and pushed the connection plugs together to make sure there was good contact. One of them must have been loose because it worked right after.I thought I was going to have to buy a new timer control module but it was just a loose connection.I have seven children and my washer and dryer work day and night. I am learning to become my own technician.
Sep 12, 2009 | Maytag Washing Machines
47 inch plasma about 6 years old.. perfect condition...at times while playing xbox360 or trying to watch dvd it wont pick up signal. What could this be?
Does it suddenly lose signal while you are playing the xbox? sounds like a loose connection on the input board in the tv. but it could be other things. does it lose signal on all inputs or just a couple?
Jun 16, 2009 | Televison & Video
LABTEC WEBCAM PRO WONT CONNECT ALL OF A SUDDEN
uninstall ...reconnect in a different usb location ..and try to let the pc find it...if not , find it via add new hardware from control panel ...and just click auto install
Apr 05, 2009 | Labtec Webcam Pro
USB support suddenly not working
I have a similar problem and got it to work by resetting the player to the initial settings.
To do this, turn the player off. On the front panel
Hold down the STOP button and turn the player back on.
Display will show CLEAR.
You will have to reenter your settings, but it recognizes the USB again.
I just got this to work, so who knows how long it will last.
Nov 02, 2008 | Pioneer DV410V DVD Player
Horn not working
sounds like a prob in the connection to your steering wheel. the steering wheel has a special connection that allows all the functions on it to be connected via a rotating connection (did i say connection enough...? lol) i dont know the terminology behind it, but that rotating thing is what lets you turn the wheel. Otherwise, regular connections with simple wires would bunch up everytime you turn the wheel. It sounds like something came loose or just lost connection in there..
sorry so vague. im a novice at this.
happy hunting
Sep 09, 2008 | 2004 BMW 3 Series
TV picture flickers
If your DVD player is separate from your tv, you might have a loose cable plug or connection. Depending on the type of flicker you have, a vertical circuit loose connection would cause this. If you could connect it to a cable or antenna it might tell you where the problem is located. A faulty circuit in the DVD might cause this too. Stargazer
Mar 01, 2007 | Sanyo DS31520 31" TV
Doesnt turn on
Good day.
Try to check for the fuse along the units power supply and loose connections.
chris
Nov 21, 2006 | Sharp 25K-M100 25" TV
This system stopped playing DVD with a very slight use
1. An unplayable disc is inserted. 2. The Rating level is set, Cancel the Rating function or change the rating level. good luck!
Jan 12, 2006 | Toshiba SD-V55HT System
Open Questions:
Sony PlayStation 3 40GB System Logo
77 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
