Question about Whirlpool Accubake RF362LXTS Electric Kitchen Range
The cooktop light on our Whirlpool AccuBake Model MERP4101SQ 0 is on all the time. The stovetop is not hot but I've heard about problems with some burners of ceramic top ranges coming on. Is this something that I need to worry about. Thanks for your attention. Cheers Ron
SOURCE: how to fix a crack in ceramic top
Mine cracked and I ordered a replacement shipped overnight. I can't get a repair person out before Christmas. Is it easy to do it myself?
Posted on Dec 20, 2007
jsrock516
  • 5911 Answers
SOURCE: How do I change the element on a Whirlpool Gold range?
If you have replaced the dual element with a new one, and have verified that you have the wiring installed correctly, it may be the infinite switch that controls the element that is bad. That would be the switch behind the control knob for the element in question.
Posted on Sep 19, 2008
  • 111 Answers
SOURCE: whirlpool ceramic cooktop
Scott,
On each of the heating elements there is a thermostat that does two things. It is a high limit safety thermostat and then a different set of contacts turn on the hot surface light. Unfortunately, you can't just replace that part. You will need to isolate which element it is with a mutimeter and replace the entire element.When you turn one of the units on high you will see a dark line under the glass running 1/2 way across the elements. Those are the thermostats... Find the defective one and the rest is pretty simple to replace
Posted on Dec 19, 2008
SOURCE: whirlpool super capacity 465 gas range model# sf377pegq5
I have the same problem intermittently on my Super Cap 465. After reading the following quote from another site, "There have been cases where radio waves, electronic signals and sometimes something as strange as dimmers in lights have caused some weird problems with some computer panels in stoves like these", I tried turning off lights that might be on the same circuit and wouldn't you know it, the oven igniter circuit worked.
Posted on Jan 04, 2009
daddy1264
  • 76 Answers
SOURCE: burner on electric ceramic/glass cooktop is getting too hot
sounds like you need a new thermostat
Posted on Jan 08, 2009
Whirlpool accubake
Almost all electric stoves vent the oven through a hole in either the back right or rear burner. They can get very hot. I am surprised that your control panel is burned. It is only dangerous if you place a combustible over the burner. I have had some people do this and it has melted it. i haven'y heard of a fire from this but it could happen if it was hot enough.
Jul 31, 2014 | Whirlpool Accubake RF362LXTT Electric...
Cooktop light doesn't shut off
The temperature sensor located on the that element is failing. the sensor red light reminds you that the burner area is still hot. The light should go out once the glass top has cooled,but the failing sensor won't allow it. A slight rap with your hand on glass top over that burner once cool will put the light out. It more than likely continue until the unit is replaced.
Jan 20, 2013 | Whirlpool Accubake RF362LXTT Electric...
I have a Whirlpool Accubake self-cleaning oven,model RBD275PD86. My wife ran the self-cleaner, then after a short time, everything went black,as if it burned out the oven. What needs to be replaced to get...
CHECK THERMAL CUT OUT ON BACK OF UNIT, MOST LIKELY THE PROBLEM YOU CAN BUY A CAN OF ELECTRONICS FREEZE AND SPRAY IT AND THEN TIP WITH BACK END OF NUT DRIVER CHEAP FIX
Sep 27, 2009 | Whirlpool 30 in. RC8700 Electric Cooktop
Plastic spoon melted on ceran stovetop. Used a
We Use Debruce Polish on all our cooktops. Debruce also works on stainless steel and polished granite, marble, porcelain, formica and glass. DeBruce is non-toxic odor-less and eco-friendly. You can get DeBruce on line at debrucepolish.com.
Aug 24, 2009 | Whirlpool RCS3014 Electric Cooktop
Whirlpool accubake rbd245pdb no power to control
Make sure there's power getting to your range, oven or cooktop. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in.
If all check out ok with all the above, replace the ERC
Jun 19, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Stovetop stays hot when burners are not on
Is it a glass top. If it is, glass will absorb the heat. It will cool off after some time. That is normal.
Dec 18, 2008 | Maytag 30 in. Admiral LGC1330 Gas Cooktop
Whirlpool Accubake RF362LXTS Electric Kitchen Range Logo
79 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
