Question about Frigidaire ATF6700F Front Load Washer
I have a ATF6700FE1 and received error code E23
    President:
  • 842 Answers
Oddly, you're the second person I've seen with a frigidaire error code today. I have modified the last response I wrote to address the error code that you have reported.
According to the error lookup table for the machine (That you can view if you go to: http://www.scribd.com/doc/8559708/Frigidaire-Affinity-Front-Load-Washer-Error-Codes )
E23 is "Drain pump relay on control board failed" - Solution - Replace the control board.
I THINK that this machine only has one main board. I say this because machines with 2 main boards have a nasty habit of one board dying and taking the other out at the same time.
You can get a new board from the manufacturer, or quite possibly from somewhere like ebay if you're lucky. The problem with a DIY fix of this magnitude is that the cost of the board is high and if the diagnisis is whrog, or more extensive than just the board, you may find yourself with a board you don't need, but cant return because it has been fitted (and the scratches where the connectors go are a dead giveaway for this). Worse still, a board that you blew up, because it wasn't JUST the board that was faulty..... And a machine that still doesn't work and now needs more parts. DIY with main boards can be a high risk strategy and I've been bitten a few times when I've thought I was being clever and doing a bargain DIY fix.
So, ask yourself the question, do you call out someone who is qualified and let them take the risk, do you do it yourself, or do you throw the machine away. I would suggest step 1 is to call the guy in the local paper, get an estimate and make a decision based on that.
Posted on May 27, 2011
How do I find the control panel that controls the pump motor? Due to error code E23?
Frigidaire GLTF2940FS1 washer Error Code E23 ...
www.shopyourway.com > Manage My Life > Questions
Sep 13, 2013 - My washer stopped mid-cycle and emitted a burnt odor. Troubleshooting shows error code 23. I pulled the connector off the pump and have ...
Kenmore Washer (48112) E23 error code ' ShopYourWay
Get shopping advice from experts, friends and the community! Hey all, I have a Kenmore front load washer model #48112. When I hit the start button the NO ...
Oct 23, 2015 | Washing Machines
Error code E 23 How do I test drain pump? The unit rolls to the left then shuts off with a beep beep beep.
[PDF]Error Code E23 Frigidaire Washing Machine - WordPress.com
https://grednandwestsign.files.wordpress.com/.../error-code-e23-frigidair...
E23 Drain pump relay on control board failed or wire off pump. E24 Drain pump relay If your. Frigidaire Washing Machine Error Code is not listed here, check Then the code E41 appeared and. I could do nothing else with the washer. The error .
Oct 23, 2015 | Frigidaire Washing Machines
What does error code E23 on a frigidaire affinty front load washing machine mean
Good Morning Friend,
I understand you are receiving an E23 code on your Frigidaire Affinity washer, model# GLTF2940ES. The E23 code states that the drain pump relay on the control board has failed. This could also be a possible false code. I suggest resetting your appliance, by either unplugging it or shutting the power off at the circuit breaker, for 3-5 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 18, 2014 | Frigidaire GLTF2940ES Front Load Washer
My Siemens IQ700 displays error code E23. I switched off and on again and still the E23 is displaying. What should I do now? Thanks!
You basically have water in the sump at the bottom of the machine, and the sensor gives you E23 error to stop a 'flood'.
Unscrew the back cover and dry it with towels and then a hair dryer and you should be fine...
You must have added extra water and overfilled the tray, or there's a leak somewhere if the problem persists.
Oct 18, 2013 | Washing Machines
Code E23 comes up om my Frigidaire Affinity front load washer. I have changed the motor control board but still have the code E23, checked the wiring harness and everything looks good. Unplugged the pump...
Hi James, thank you for your post! If you are getting an error code E23, it usually means one of three things: your drain pump relay has failed, a wire may be disconnected from the pump, or your main control board needs replacing. However, since you have already replace the control board, one of the best ways to determine if this is a false error code is to reset the power to the appliance by either unplugging it or flipping off the breaker. It is important to wait roughly ten minutes and then turn the washer on. If the error code persists, it would be advisable to reach out to an expert technician to ensure the appropriate replacement part is ordered and is installed correctly to prevent future issues. I hope this information helps to some degree - thanks for your question, and please do not hesitate to reconnect.
Aug 07, 2013 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
E23 code how do i fix this on a gallery series
An E23 error code on your washer indicates a failure of the drain pump relay.
Oct 13, 2012 | Washing Machines
E23 error code
this is a drain pump relay on the control board failure.you either need to replace the wire or the main control board
May 19, 2010 | Frigidaire ATF6000ES Front Load Washer
Radio rejects CD's with an error code of E23
I checked my manual and could not find any results for an error e23, there is an error e20 for the reasons The disk is upside down
It is dirty scratched or wet
There's too much moisture in the air,wait about an hour and try again.
From presonel experiance these decks will not play MP3's only disks that have been burned using
the WAV. format.
Mar 25, 2009 | 1997 Buick Park Avenue
Canon MP150
E23 is a paper feed error. Check the rollers and the paper feed mechanism. Following are the various error codes for your printer:
CANNON Printers MP150/MP160 ERROR CODE
E9 The connected digital camera / video camera does not support Camera Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
turn the printer off and lift  the front top and move the cartridge carriage manually at the center and then on the printer.
Mar 14, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Frigidaire ATF6700F Front Load Washer Logo
112 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
