Question about Belkin Wireless G Router 54Mbps 802.11g, 4-Port
I have a Belkin Wireless G router 54Mbps.It is installed since last july, but I had a problem this week with the modem, so I would like to rename the wireless network and include a password, because I lost the first configuration. Is it possible to send me the steps of the configuration?
  • Belkin Master
  • 4,338 Answers
1. Locate the reset hole on the router. The button will be on the back or side of the router.
Leave the router powered on.
  1. Use a paperclip (or similar) to press and hold in the reset button for 10 seconds.
  1. Remove the paperclip.
4. Wait approximately one minute for the router to restart.
The settings for the router have now been reset back to their default.
Do not forget the new password and keep it somewhere safe. If you forget your password, you'll be unable to access your router's settings. If you forget or lose your password, you'll need to "Perform a hardware reset on the router". This will reset the password to its default, as well as erase any and all other settings you may have changed.
Setup steps:
1. Connect the computer to one of the four LAN ports on the router.
2. Open a web browser on the computer.
3. In the address bar of the web browser, type http://192.168.2.1
Posted on May 27, 2011
My belkin router does not give signal, only lights on are the modem and the numbers of the ports... power, wireless and internet are not on
If there is no Power light in the router its obvious the router has gone bad. But still you can try few troubleshooting steps. Try Unplugging and replugging the power cable of the router and try resetting the router for 10 sec (use a paper clip and hole the pin hole reset button on the rear end to reset it). If still the power light did not come then contact 1 800 2235546 (Belkin Toll free number) and request a replacement.
Thanks in advance!
With Regrads,
Prema.
Jan 06, 2011 | Belkin F5D72344 Wireless G Router 54Mbps...
Router was losing internet connection frequently and now will not connect to internet. Checked cables and direct connect from modem to Mac is fine.
Did you try a reset? Also, if you are using WEP encryption on the N router, you are only getting 54MBPS rather than 108MBPS. Use WPA.
Dec 07, 2010 | Belkin Wireless Pre-N (F5D8230-4) Router...
I have a Dell studio laptop, a D-Link Modem and a Belkin Wireless 54MBPS router. Is it a simple thing to "marry" the two? Do I just follow the Easy install wizard? Are there some security measures to...
It should be straight forward to do, as you don't have to have the same manufacturer throughout to get the wireless working, just as long as the wireless network card that you are using has drivers for the operating system that you are using.
Just follow the installation instructions the wireless adapter, and as long as you know what sort of network encryption you are using (WEP, WPA, WPA2), and the wireless key, you should not have a problem.
Hope this helps, and good luck :)
Oct 18, 2010 | Belkin (F5D7230-4) Router (587009)
Belkin wireless n route only puts out 54mbps
The reasons you only get 54mbps could be: one, your networked PCs don't support N-mode and broadcast in G-mode, so that the router falls back to 54mbps.
Two, the signal strength is too low or the radio noise level is too high to allow N-mode operation at full speed.
So, after checking with the manuals and vendor brochures, you should try connecting the router with a single PC close by - say, ten feet in the same room - and check connection speed. If you can connect at 108 or 125 depending on which N mode you have (N, N+, N1...), the problem is likely to be distance, walls or noisy equipment.
If you still can't connect, double-check the configuration of both router and PC (wifi board "Advanced Properties" in Hardware Management) to check whether N mode is enabled at BOTH ends, especially "Wireless Mode" in the PC.
If it still doesn't work, I'd test it with a Belkin N USB key, for example, just to check that when router and client vendors say, "802.11N", they do indeed refer to the same thing. That's not so cut and dried a thing as one would expect. The N-mode standard was not completely defined from the start, so that many vendors jumped the gun and implemented their own "N-modes" which are often NOT compatible with each other. If you had a US Robotics router and a Yuwasa (and outdated SparkLANs, IIRC) wifi board, you'd discover that you could only attain 11 mbps - and if the USR router was set for "G only" or "G and N" instead of "B, G and N", you would get no connection at all.
Oct 04, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Belkin Wireless N router/Embarq 660 modem/No internet
Make sure your physical connection is correct. From the modem, the ethernet cable should plugged in to the Internet/WAN port of the router. And your computer to port 1. Access the setup page of the router again and Enable the MAC Address Clone setting. Clone the MAC Address of your PC there then power cycle the router and modem. You should be all set.
Apr 15, 2009 | Belkin (F5D8231-4) Wireless Router...
I have G 54Mbps wireless Belkin router I was disconnected from the internet yesterday and i've couldn't connect anymore since. I tried to re setup the soft were but he CD doesnt give me the choice of...
Try unplugging the router and the cable/dsl modem if you have one. Wait 10 seconds and then plug the modem in. Wait a minute for the modem to boot back up and then plug the power to the router back in. Wait a little for the router to boot up and then reboot your computer.
Oct 07, 2008 | Belkin Computers & Internet
Set up my belkin g router
You may have to configure the belkin router depending on the type of ISP that you have.
Basically, you can do these to configure your router:
1. connect the computer to the numbered port of the router and connect the modem to the internet/WAN port.
2. turn off the modem, router and the computer for 30 seconds
3. turn on the modem first, wait for the lights to stabilize then turn on the router, wait for the lights and lastly turn on the computer.
Sep 04, 2008 | Belkin (F5D7230-4) Router (587009)
Router
check you cable connections, try to check if you can go online wired to the router if you are connecting wirelessly. You can also bypass the router and connect directly to the modem to make sure its working.
Jun 15, 2008 | Belkin (F5D7230-4) Router (587009)
Belkin Wireless G Router 54Mbps 802.11g, 4-Port Logo
96 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
