Kodak ESP 7 paper jam, jam is cleared, but cant get paper tray into maching
  • ehpark37 May 29, 2011
    Paper tray slid back in easily, but the printer will not print, which was the original problem.
  • 4,472 Answers
Did you remove the paper tray completely out of the machine? Or are you just having a problem with the paper itself. Once I have more information I can assist you further. I would also recommend referencing the manual here:
p.40 of the manual may help you
http://resources.kodak.com/support/pdf/en/manuals/urg00976/ESP7_UG_GLB_en.pdf
Thank you,
lee
Posted on May 27, 2011
How can I clear a paper jam on Kodak all in one printer?
www.kodak.com/go/aiosupport
Getting help on the Web
For more troubleshooting information:
Paper jam
• Check for paper in the rear-access cleanout area.
• Open the printer access door and gently remove any paper from inside the printer.
• Make sure the paper in the tray is free of tears or creases.
• Make sure you do not overload the paper tray.
For more information, go to
www.kodak.com/go/stepbystep
Jan 03, 2015 | Kodak ESP Office Equipment & Supplies
Says paper jam, but there is no paper jam
->Clear any loose paper from the paper tray. This will help you locate the jam. You will find it either in front, near the paper tray, or in the rear.
->To clear a paper jam near the paper tray, grip the paper and pull it firmly but gently from the printer. If you find a stack of papers jammed, grab from the middle of the stack and pull.
->For a rear jam, remove the back of the printer. When you find a free edge on the paper, grip it firmly and pull it out.
->Replace the back cover. Press the "Resume" button or turn off the printer, and then turn it back on. Your settings should reset.
->Try printing another document
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Nov 20, 2012 | Kodak ESP 5 Printer
Paper jam
You are receiving this error message because there is a paper jam or the top (photo) tray is not securely in position and the printer cannot initialize. This error message can appear for an ESP 7, ESP 9, ESP 7250, or ESP 9250 all-in-one printer.
To resolve a paper jam, we have an easy Step-by-Step Solutions and Repair tool. Within the tool, select All-in-one printer, then Paper jam.
When you clear the paper jam:
  1. Make sure you open the paper output tray and inspect the top tray for photo paper that could be jammed inside or that remains in the nip at the entrance.
  2. Pull out the bottom paper tray and clear any paper jams.
  3. Remove the duplexer from the back of the printer and clear any paper jam.
NOTE: Curled photo paper could induce a paper jam. To prevent curling:
  • Store un-printed paper in a tightly closed plastic bag or in its original packaging.
  • Store sealed packages of paper flat, and not on
  • When you are ready to print, take only the paper intend to use immediately.
To remove curl in photo paper:
  1. Place the paper in a plastic bag or in its original packaging.
  2. Gently bend the paper in the opposite direction of the curl, then insert it into a tube-a paper towel tube works well.
    NOTE: The tube should be larger than 1.5 in. (4 cm) in diameter.
  3. After a few minutes, remove the paper from the tube.
  4. Remove the paper from the plastic bag or packaging.
  5. Verify that the curl has been removed from the paper. Repeat the steps above if necessary.
If the top paper tray is not securely in position and the printer cannot initialize (you may hear a grinding noise, and the top paper tray will not open), contact Kodak.
Nov 02, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
How do I clear a paper jam in the Kodak ESP-3 can't get to the paper
If you have tried the Kodak standard instructions for clearing the paper jam problem and it did not help try the procedure below. Works for esp 7.
1. Open the printing area of the printer (containing the ink cartridges).
2. The Ink cartridge holder should be to right side of track.
3. Look on left side, below the track for the cartridge that is used to
clean the print heads.It can be identified by a square black pad
approx. 1" sqaure that appears to be made of "felt".
If it is visible this is most likely your problem.
4. To correct problem locate the flat latching lever approx. 3/4" wide that
sticks up about 1/2" above the cartridge. It is locacted just behind
the "felt" square. Gently push lever toward rear which should free the
cleaning cartridge and allow the entir cartridge to move slightly
backward.
5. Close the top of the printer and cycle the printer off and back on.
If this is the problem, the "paper jam" error will now be gone.
This is such a simple fix I do not know why kodak does not inform
customers of this problem and how to fix it.
Jan 17, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
How do I clear a piece of paper jammed in my Kodak ESP5 All in one printer
1 Lift the output tray.
2 Open the paper trays and remove any paper.
3 Turn OFF your printer.
4 Wait 30 seconds, and then disconnect the following from the back of your printer: USB cable, Ethernet cable, Fax cable, AC power cord.
CAUTION: Do not use force when removing the paper from the printer.
5 Check inside the cleanout area for a paper jam. If necessary, remove any paper or debris.
6 If paper is not visible, check the printer for foreign objects, such as paper clips or staples. If necessary, carefully remove the foreign objects from your printer.
7 Open the printer access door.
8 Remove any foreign objects from the printhead access area, and then close the printer access door.
9 Connect the following to the back of your printer: USB cable, Ethernet cable, Fax cable, AC power cord.
10 Wait 30 seconds, and then turn ON the printer.
11 Squeeze and move the paper-width guide on the paper tray to the left.
12 Load the paper into the upper paper tray.
13 Squeeze and move the paper-width guide to the right until it touches the paper.
14 Close the paper tray.
Best of Luck
saj
Nov 02, 2009 | Kodak ESP 5 Printer
Kodak esp 7 has a paper jam I cannot remove the paper
backward.
May 09, 2009 | Office Equipment & Supplies
Paper jam error light on kodak esp 5
  1. Remove the paper tray.
  2. Disconnect the power cord, wait 5 seconds, then reconnect the power cord.
    NOTE: The printer will reset and eject the paper. If the paper does not eject, try to remove it manually.
  3. Replace the paper tray.
  4. Press the Print button on the printer to resume printing.
Apr 01, 2009 | Kodak ESP 5 Printer
ESP 7 paper jam error
I had the same problem, but after pressing the OK button when the paper jam came up again I pressed the CANCEL button and was able to print my document. See if that works for you too.
Mar 19, 2009 | Kodak ESP 5 Printer
My Kodak ESP5 keeps saying "Paper Jam please remove paper jam" But there is no paper in it?
My esp 5 gave me this same message. I'm not an expert but here is what worked for me.
I turned off and disconnected both cables (usb and power) then reconnected and turned on.
At this point it still read paper jam, so I took ink cartridges out and paper out.
I then reinstalled ink cartridges and PULLED OUT THE PAPER TRAY to it's FULL capacity, added about 5 sheets of paper, and on the main menu I chose the allignment function and printed a test page and suddenly....no jam!
Hope this works for someone. For some reason pulling the tray all the way out cleared the "jam" message for me. Now if I could just get the new ink cart to work I'd be all set! Good Luck!
Dec 20, 2008 | Kodak ESP 5 Printer
43 people viewed this question
jasbo
jasbo
