Question about Ovens
My rca gas oven will not heat up model #317B6034
Yes the ignitor glows but the burner does not come on
Posted on May 14, 2014
2 Suggested Answers
  • 385 Answers
SOURCE: I have a GE Profile
It sounds like you have a bad ignitor in the oven. Hope this helps get you going in the right direction.When you turn on the oven the ignitor should glo.
Posted on May 16, 2011
Kenmore oven 317b6034
It sounds like the heating element is faulty. If it has a short, it will have a damaged place. A short causes a build up of amps until it can't take anymore and then a action will happen like a fuse blowing, which it the noise you hear. You can get replacement elements on Amazon fairly cheap. To fix, unplug the stove. Lift and tug on the element to pull it out of the socket. It is usually easy.
Rich Long
Jan 26, 2014 | Kenmore Ovens
I have a GE Profile Gas Range model 317B6034. The top / range works fine, but the actual oven will not turn on at all. I don't smell gas nor is there any sound when I turn the oven on. Basically,...
May 16, 2011 | Ovens
Our Kenmore oven does not come on/heat up. I think it is the igniter that isn't working, but can't find the info on when we bought the range to know whether it might be worth having a repairman out or if...
if you open the bottom draw,on the frame you should see amodel number and serial number,all you need is a model number,most likely it will be the ignitor,pull out the racks,lift up the floor and you'll see the ignitor,first unplug it or shut down the breaker.remove the screws that hold the ignitor in place,if you don't see an ignitor it might not have one,but if it does take out the screws and pull the wires out,there should be a plug or wire nuts,disconnect them and check it with a meter,if it's bad change it out,first get back to me with the model number,if the top lifts up where the burners are the number could be up there too.don't force the top up,if it's tight and doesn't seem like it doesn't lift don't force it.
Mar 05, 2011 | Kenmore 33464 / 33465 / 33469 Gas Single...
I own a Hotpoint self cleaning oven Gas - probably 1989 (only number I found was on the door - 317B6034) The ignition coil on the bottom of oven will not light up to ignite the gas tube. Locating the...
The problem is usually the igniter not reaching the correct amp draw .When the igniter does not reach the correct amp draw it may allow the gas valve to partially open or not open at all. The igniters are inexpensive and easy to replace. This video will walk you thru the correct procedure for testing an oven igniter. It may be a different model but the testing will be the same.You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
Nov 17, 2010 | Ovens
I have a RCA gas self cleaning oven,It heats on broil but not on bake.we have noticed over the weeks the oven was getting as hot as the thermostat was set at.Now it won't heat at all
Hi. This sounds like a weak igniter, the symptoms usually are: burner won't light, or takes longer than normal to ignite the burner, may or may not smell gas in the oven, does not maintain set temperature or burner does not come on fully. On gas ovens, a glo igniter is like a light bulb, the more you cook, the faster it wears out. Bottom line, needs to be replaced. Good luck.
Feb 13, 2010 | GE Ovens
GE Gas built in oven Model JRS14 will not heat up
The bake ignitor has failed.Turn off the gas supply. Remove the racks. Then remove the bottom pan cover in the oven to access the ignitor. Place a amp meter on one wire of the ignitor.Turn the BAKE switch on. If it reads less than 3 amps,replace the ignitor.
Oct 30, 2009 | GE 24" Built-In Single Gas Wall Oven
Maytag gas oven wont restart after pre heat
you have a bad oven sensor /faulty connection or bad control board.look for probe coming thru inside rear wall.should read 11k ohms cold.go bad a lot part number Hope this helps ,please rate my response :)
12001655
Jun 25, 2009 | Maytag 24" Built-In Single Gas Wall Oven -...
Oven does not heat. Broiler and stove work. NO gas smell.
could be the oven thermostat, get a plumber/heating engineer out, but make sure you can trust him, cause he could try and say u need a new cooker when it MIGHT only be a new oven thermostat.
Feb 02, 2009 | GE Ovens
SF114PXSBO Whirlpool Gas Oven won't heat
your ignitor is bad, the thing that glows in the broiler compartment. two 1/4" screws and one plug, simple fix. you can do it. just call a local parts store with model # and brand,
Mar 30, 2008 | Whirlpool SB160PEE Gas Single Oven
Whirlpool oven model sf315peew Super cap 465
try the broiler if it lights then replace the oven ignighter in the bottom under the bottom plate of the oven cavity reply if the broiler doesn't light
Jan 30, 2008 | Ovens
Ovens Logo
142 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
