Question about Intermatic T101 - 24 Hr. Dial Time Switch - NEMA 1 Indoor Steel Case - Gray
The manual switch is in the off position. In attempting to set it to on, the adjustment lever does not remain in the on position, but rather returns to the off position. Is there something I'm not doing correctly?
The manual override switch is supposed to snap back and forth each time the trippers move the on-off lever.
If the manual override does not snap back and forth crisp and clean, then tripper might be in the way at that moment.
Open following link for troubleshoot checklist:
http://waterheatertimer.org/How-to-troubleshoot-Intermatic-timer.html
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on May 27, 2011
I am having trouble getting the engine to run. It will crank but won't stay running.
Attempt to hold the choke in the on position. Typical of these designs the choke returns to the run position as the unit warms up. It is likely that the carburetor has become fowled by residue remaining after the gas has evaporated.
this is a common problem. The residue restricts the
critical fuel metering passages and by retaining the choke on the mixture is enriched enough to maintain engine operation.
The best corrective action is to not remove the carburetor , but to attempt to replace the fuel with fresh fuel preferably without ethonal. Second would be to add a fuel additive that has the ability to clean out the fuel system.
Attempt to run the unit and using the choke try to maintain operation.
Allow the unit to sit overnight and hope that the residue will dissolve. If the fuel metering adjustments screws are adjustable record the current setting and adjust the settings counter clockwise to enrich the fuel mix. Small adjustments 1/4 turn.
Allow the unit to run adjusting over time the mixture back to the original settings as the residue dissolves,
Disassembling the carburetor is only recommended by a professional. It is very easy to damage a good carburetor attempting to clean it.
Hope this has helped?
Mar 26, 2016 | Electrical Supplies
What do codes p0707 and code p0708?
1. Place the selector lever in the "N" (Neutral) position.
2. Loosen the manual control lever lock nut to separate the cable and lever.
3. Place the manual control lever in the "N" (Neutral) position.
4. Turn the transaxle range switch body until the 12 mm (.47 in.) wide end of the manual control lever aligns with the switch body flange [12 mm (0.472 in.) wide portion].
5. Tighten the attaching bolts (2 pcs.) to the specified torque. When setting up the switch body, be careful O-ring does not drop from the switch body. Tighten the attaching bolts carefully.
6. Make sure that the selector lever is in the "N" (Neutral) position.
7. Adjust the flange nut so that there is no slack in the control cable and make sure that the selector lever operates smoothly.
8. Run the vehicle and confirm that the transaxle is set in each range when the selector lever is shifted to each position.
for more help visit https://cbrtechsolutions.net
Jan 25, 2013 | 1997 Mercury Sable
How to fix the shift cable
  1. Position the steering column transmission shift lever to PARK (P).
  2. Apply the parking brake.
  3. Raise the vehicle. Refer to Vehicle Lifting.
  1. Position the transmission range select lever to PARK (P). Rotate the range select lever clockwise until it reaches the full mechanical stop position.
  1. Slide the black retaining clip forward on the range select lever cable end. This will allow the white lock button to be pushed out.
  1. Push the white lock button on the range select lever cable end out. This will free the metal core adjust body which is inside the cable end. Do not push the white lock button completely out.
  2. Inspect the metal core adjust body on the cable end for dirt or debris that may restrict the travel. Remove any debris by washing the cable end, the metal core adjust body, and the white lock button with soap and water. If the travel of the metal core adjust body remains restricted after the cleaning, replace the cable assembly.
  3. Lower the vehicle.
  4. Ensure that the parking brake is applied.
  5. Turn ON the ignition switch.
  1. Move the transmission shift lever from PARK (P) to 1 and back to PARK (P) ten times.
  1. Place the steering column transmission shift lever in the Park (P) position.
  2. Turn the ignition switch to the OFF position.
  1. Position the transmission range select lever to PARK (P). Rotate the range select lever clockwise until it reaches the mechanical stop position.
  1. Push in the white lock button in order to secure the core adjuster body inside the range select lever cable end.
  1. Slide the black retainer clip rearward over the cable end until it covers the white lock button. Lock the clip over the cable end.
  2. Lower the vehicle.
  3. Turn ON the ignition switch.
  4. Ensure that all the transmission shift light positions (P. R. N. D, 3, 2, 1) engaged and illuminate. If you cannot perform this task, repeat the cable adjustment procedures.
  5. Ensure that the engine starts in PARK (P) and in NEUTRAL (N) positions only. If the engine does not start in PARK (P) and in NEUTRAL (N), the Park/Neutral Position Switch may need adjustment.
  6. Turn the ignition switch to LOCK.
  7. Ensure that the ignition key can only be removed with the transmission shift lever in the PARK (P) position.
  8. Start the engine and check the vehicle transmission shifting. The range select lever cable is properly adjusted if the steering column shift light positions are the same as the transmission engagements.
Dec 03, 2012 | 1999 GMC Yukon Denali
GMC Yukon Seat Switch
You don't mention what year your Yukon is ? This could very well be a control Module problem .
I'll post how the power memory seat's work or are suppose to work !
Memory Seats Description and Operation
Battery voltage is supplied to the memory seat module through a 25 A circuit breaker. The memory seat module supplies the seat adjuster switch assembly with a battery positive reference voltage. While the seat adjuster switches are in an inactive state the switch contacts are closed to the adjuster switch common circuit. When a seat adjuster switch is pressed to an active state the switch contact is closed to the reference voltage circuit. Battery voltage on a switch signal circuit indicates to the memory seat module the switch status is active. Each seat adjuster motor is controlled by the memory seat module through 2 motor control circuits. While the seat adjuster motors are in an inactive state the motor control circuits are closed to ground circuit contacts within the memory seat module. The memory seat module operates the seat adjuster motors by switching one of a motors control circuits to battery voltage. The seat adjuster motors are bidirectional and the direction of adjuster motor rotation is determined by which of the adjuster motor control circuits is switched to battery voltage while the other remains grounded.
Memory Set/Recall Operation
The seat adjuster motors are equipped with internal position sensors. The adjuster motor position sensors are monitored by the memory seat module and are used to determine the seat position when storing or recalling memory settings. The driver seat adjuster motors use potentiometer type position sensors. The position sensors are supplied with a 5 V reference and ground circuits from the memory seat module. The position sensor signal circuits return to an analog input within the memory seat module. During adjuster motor operation the position sensor provides a voltage change proportional to the change in revolution of the adjuster motor shaft. The memory seat module monitors the voltage from the position sensor signal circuits to determine the adjuster motor positions when storing or recalling memory seat position settings.
The memory recall switch assembly on the driver door provides inputs to the driver door lock/window switch. Battery voltage is supplied to the memory recall switch assembly from the driver door lock/window switch. When a RCL 1, RCL 2, or EXIT switch is pressed, the switch contacts close the appropriate switch signal circuit to the battery voltage supply circuit within the memory recall switch assembly. When the driver door lock/window switch receives active switch signals from the memory recall switch assembly, the appropriate commands are sent to the memory seat module using the GMLAN Serial Data circuit. The Body Control Module software version determines the personalization features available.
Memory seat recall operation is allowed only with the transmission selector lever in the PARK position while the ignition is on. The transmission selector lever position data is provided to the memory seat module by a message through the GMLAN Serial Data circuit.
There are somethings listed you are not familiar with , like GMLAN Serial Data circuit ,maybe Body Control Module software etc... GMLAN is a communincation network that the computers on the vehicle uses to share information , transmit commons etc... you can google it to read about it .
There are DTC'S - diagnostic trouble codes that can set in the module in control . Do you know what DTC'S are .
DTC Descriptors
DTC B1825 01: Driver Seat Recline Position Sensor Circuit Short to Battery
DTC B1825 06: Driver Seat Recline Position Sensor Circuit Short to Ground or Open
DTC B1825 5A: Driver Seat Recline Position Sensor Circuit Plausibility Failure
DTC B1850 01: Driver Seat Lumbar Horizontal Position Sensor Circuit Short to Battery
DTC B1850 06: Driver Seat Lumbar Horizontal Position Sensor Circuit Short to Ground or Open
DTC B1850 5A: Driver Seat Lumbar Horizontal Position Sensor Circuit Plausibility Failure
DTC B1860 01: Driver Seat Lumbar Vertical Position Sensor Circuit Short to Battery
DTC B1860 06: Driver Seat Lumbar Vertical Position Sensor Circuit Short to Ground or Open
DTC B1860 5A: Driver Seat Lumbar Vertical Position Sensor Circuit Plausibility Failure
DTC B2355 01: Driver Seat Front Vertical Position Sensor Circuit Short to Battery
DTC B2355 06: Driver Seat Front Vertical Position Sensor Circuit Short to Ground or Open
DTC B2355 5A: Driver Seat Front Vertical Position Sensor Circuit Plausibility Failure
DTC B2365 01: Driver Seat Rear Vertical Position Sensor Circuit Short to Battery
DTC B2365 06: Driver Seat Rear Vertical Position Sensor Circuit Short to Ground or Open
DTC B2365 5A: Driver Seat Rear Vertical Position Sensor Circuit Plausibility Failure
DTC B2375 01: Driver Seat Assembly Horizontal Position Sensor Circuit Short to Battery
DTC B2375 06: Driver Seat Assembly Horizontal Position Sensor Circuit Short to Ground or Open
DTC B2375 5A: Driver Seat Assembly Horizontal Position Sensor Circuit Plausibility Failure
5) Memory Seat Module is under the front of the driver seat , you could look under an see if all the connectors are fully seated.
The best diagnostic step would be to hook up the factory scan tool an see what the computer is seeing as far as inputs from the switch an outputs it's sending . I wouldn't suggest you take the seat apart an try testing electrical inputs etc.... unless you very familiar with automotive electrical systems an circuits .
Mar 06, 2017 | GMC Cars & Trucks
P0707 transaxle range swutch- open circut
You can start by unplugging the sensor and look for bend pins or rust in the connector. Once this is done you can try re-adjusting the range switch.
This is from www.hmaservice.com.
also try a tanny flush
May 14, 2012 | 2001 Hyundai Tiburon
Where is the neutral safety switch located on 1998 ford crown victoria
On 1992 and later models, the neutral safety switch is incorporated into the Manual Lever Position or Transmission Range MLP/TR sensor.
RENOVAL & INSTALLATION
  1. Disconnect the negative battery cable.
  2. Raise and support the vehicle safely on jackstands.
  3. Place the transmission in Neutral.
  4. Remove and discard the manual control lever nut, then remove the lever from the transmission.
  5. Detach the TR sensor electrical harness connector, remove the TR sensor retaining bolts, then pull the TR sensor off of the transmission case.
To install:
  1. Position the TR sensor against the transmission case and loosely install the 2 retaining screws.
  2. Attach the TR sensor electrical harness connector.
  3. Use an alignment tool, such as the TR Sensor Alignment Tool T93P-70010-A, to align the TR sensor slots.
  4. Tighten the TR sensor bolts to 80-100 inch lbs. (9-11 Nm).
  5. Position the manual control lever onto the TR sensor, then install the new lever nut to 22-26 ft. lbs. (30-35 Nm).
  6. Lower the vehicle.
  7. Connect the negative battery cable.
ADJUSTMENT
Fig. : Adjusting the MLP sensor (click image for zoom)
Park is the last detent when the manual control lever is full forward. Return 2 detents toward the output shaft for Neutral.
  1. Position the manual control lever in Neutral .
  2. Raise the and safely support the vehicle.
  3. Loosen the sensor retaining bolts.
  4. Insert Gear Position Sensor Adjuster tool T93P-700 10-A or equivalent, into the slots.
  5. Align all 3 slots on the MLP sensor with 3 tabs on the tool.
  6. Tighten the attaching screws to 80-100 inch lbs. (9-11 Nm).
  7. Lower the vehicle.
Hope this helps (remember to rating ans leave a testimonial commnet about this free answer).
Oct 11, 2011 | 1998 Ford Crown Victoria
Seat Position Cant be moved
The manual lever to release the seat is supposed to have a spring on it to return the release lever to the lock position, if the lever does not spring back when you let go of the seat adjustment lever then you know there is a missing, dis-connected, or broken return spring.
If this is the case try putting the seat where you want it to be and make sure that the adjustment lever returns to the lock position, now check to see if the seat will lock in with the adjustment lever in the lock position.
If it does lock in repair or replace the return spring.
Make sure that the adjustment lever is attached to the locking linkage and it does move the locking mechanism.
If it still does not lock into place then there is something wrong with the seat locking mechanism, and some WD-40 sprayed onto the seat rails and track might release a stuck mechanism, and if everything seems to be working alright, and you can see that the locking mechanism in the seat rail is moving in and out of the lock position, then the locking tabs are most likely sheered off and you will need to replace the seat.
Also look under the drivers side seat and compare the lever position and the linkage connections with the passenger side seat, and make sure that it is all operating like the drivers side seat.
Apr 28, 2010 | 2000 Renault Sportwagon
Brake lights are staying on constentily except in park
Also check the light bulbs in the 3rd brake light. If they are out (burned out or removed) the brake lights will remain on. I found this out by trial and error. I replaced the brake switch, tested voltages also and everyone told me that the 3rd brake lights should have nothing to do with it. But the do, don't know how or why, ford dealer wanted to charge me $86 for diagnositcs and $70 for complete 3rd brake assembly. Went to Napa and got bulbs for $5.00 (5 bulbs) and everything works now. Also this causes the cruse control not to work.
Feb 10, 2010 | 2003 Ford Focus
Looking for the neutral safety switch
Neutral Safety/Back-up Light Switch
This is a combination switch which controls both Neutral Safety and Back-up lamp circuits.
C6 Transmission
C6 neutral start switch
  2. Raise and safely support the vehicle on jackstands.
  3. Remove the downshift linkage rod return spring at the low-reverse servo cover.
  4. Coat the outer lever attaching nut with penetrating oil. Remove the nut and lever.
  5. Remove the 2 switch attaching bolts, disconnect the wiring at the connectors and remove the switch.
  6. Installation is the reverse of removal. Adjust the switch and tighten the bolts to 55-75 inch lbs. (6.2-8.5 Nm).
  7. Remove the jackstands and lower the vehicle.
  8. Connect the negative battery cable.
AOD Transmission
Removing the AOD neutral start switch
  3. Disconnect the wiring from the switch.
  4. Using a deep socket, unscrew the switch.
  5. Installation is the reverse of removal. Tighten the switch to 10 ft. lbs. (14 Nm).
  6. Remove the jackstands and lower the vehicle.
4R70W Transmission
Removing the Manual Lever Position (MLP) sensor
As of 1994, the neutral safety switch is referred to as a Manual Lever Position Sensor (MLP).
  3. Disengage the harness connector from the MLP sensor.
  4. Remove the 2 sensor attaching bolts and remove the sensor.
To install:
  1. Install the MLP sensor and install retaining bolts. Do not tighten, the sensor requires adjustment.
  2. Adjust the MLP sensor then tighten attaching screws to 80-100 inch lbs. (9-11 Nm).
  3. Remove the jackstands and lower the vehicle.
  4. Connect the negative battery cable.
ADJUSTMENT
C6 Transmission
  1. Hold the steering column transmission selector lever against the Neutral stop.
  2. Move the sliding block assembly on the neutral switch to the Neutral position and insert a 0.091 in. (2.3mm) gauge pin in the alignment hole on the terminal side of the switch.
  3. Move the switch assembly housing so that the sliding block contacts the actuating pin lever. Secure the switch to the outer tube of the steering column and remove the gauge pin.
  4. Check the operation of the switch. The engine should only start in Neutral and Park .
4R70W Transmission
  2. Insert Gear Position Sensor Adjuster tool T93P-700 10-A or equivalent, into the slots.
  3. Align all 3 slots on the MLP sensor with 3 tabs on the tool.
  4. Tighten the attaching screws to 80-100 inch lbs. (9-11 Nm).
I hope help you. Good luck (rated this help).
Sep 17, 2009 | Ford E-250 Cars & Trucks
1996 ford contour transmission range sensor
Transmission range sensor and neutral safety switch are the same thing (when you go to buy the part). It's at the top of your transmission. You'll see the shifting cable connected to it. Here are the instructions for adjustment:
Shift Control Linkage
The transmission shift linkage adjustments must be performed in the order in which they appear.
Column Shift
Place transaxle range selector lever in (D) (OVERDRIVE) position or D (DRIVE) position on vehicles equipped with a transmission control switch (TCS). A weight of 1.4 kg (3 lb) should be hung on the transaxle range selector lever to ensure the lever is located firmly on the (D) (OVERDRIVE) or D (DRIVE) position on vehicles equipped with a transmission control switch (TCS) detent.
Loosen manual control lever-to-control cable retaining nut.
Move transaxle manual control lever to OVERDRIVE position or D (DRIVE) position on vehicles equipped with a transmission control switch (TCS), second detent from most rearward position.
Tighten retaining nut to 17-23 Nm (13-17 lb-ft). Check operation of transaxle in each transmission range position. Make sure that park mechanism and transmission range (TR) sensor are functioning properly.
Floor Shift
Position transaxle range selector lever in DRIVE position against rearward stop. The floor transaxle range selector lever must be held in the rearward position using a constant force of 1.4 kg (3 lb) while linkage is being adjusted.
Move transaxle manual control lever to DRIVE position, second detent from most rearward position.
To take it off, it's a couple of retaining bolts and a wiring harness.
Jun 28, 2009 | 2000 Ford Contour
Intermatic T101 - 24 Hr. Dial Time Switch - NEMA 1 Indoor Steel Case - Gray Logo
66 people viewed this question
Top Intermatic Electrical Supplies Experts
Hippy_dd
Gene Haynes
Jay Finke
Jay Finke
Are you an Intermatic Electrical Supply Expert? Answer questions, earn points and help others
