Question about Toro Power Lawn Mower
I have a Toro self paced recycler mower with rear wheel drive. When I pick it up the wheels turn but when I put it down it just doesnt seem to be working at all. Any suggestions?
    Novelist:
    Champion:
  • 222 Answers
It sounds like your belt is slipping / loose and should be replaced. Hope this helps. Good Luck.
James
Posted on May 27, 2011
  • rlewisvt May 30, 2011
    how do you disasembly the mower to get to the drive belt
Self propelled I have a toro super recycler model 20092 when I cut the grass it seems like the mower wants to pull to one side all the time. The right side. thoughts? year 2009
I assume this is a powered mower, that is to say it turns the wheels to assist in mowing. Only one wheel is powered, so it can pull to the side.
Nov 11, 2016 | Toro Garden
Toro model 20332. Have put new transmission, belt and new drive wheels on back. When I use the personal pace bar it makes a grinding noise. Doesnt make noise unless I push that down.
Sounds like either the gears on the wheels or ends of the trans shaft are bad, or the internals of the trans are bad. Are the parts actually new-new, or used and new to the machine, you didn't specify. What happens when you manually spin the pulley on the top of the trans in either direction?
Aug 14, 2016 | Toro 20332 22" Personal Pace Walk Lawn...
Why do the wheels lock up on my self propelled 22" recycling mower
Sounds like they need cleaning & oiling. Check that nothing is keeping it from moving. I have ran over string or cord before & got caught and wrapped around wheel.
Oct 27, 2014 | Toro 22 in. Personal Pace with Blade Stop...
I have a Toro mower made in 5/09 self propel system it grinds when you pull it in reverse. The selp propel is not working. The belt is on. and it seems to be only the left rear wheel? The cable is not...
Yes it is the transmission. A Mower shop will charge you about $225 to fix.. I order parts online and fixed mine for $90. Transmission consist of 3 gears which turns the rear wheels to self-propel.
Jul 21, 2014 | Toro Lawn Mower. 22 in. Personal Pace with...
Why does my torolawnmower take off when i start it?
I have a riding toro lawn mower that cut off on me and wouldn.t start back, what could be my problem? The crak wheel trys to turn but it won,t turn over
Dec 11, 2012 | Toro Lawnmower Lawn Mower SP Drive Belt...
Replace right rear hieght adjuster on a toro self pace mower
Remove wheel, remove screws mounting adjuster, straighten or replace.
Oct 02, 2012 | Toro 22 in. Personal Pace with Blade Stop...
Toro 22" recycler Mod
Got the same problem with mine, replaced the drive belt, removed the wheels and checked for rocks and pebbles, greased, checked also bottom of gearbox. grease was present no broken teeth, top pulley has excive side to side play. Have not disaasembled yet. Hope someone would have had a solution here.
Apr 11, 2011 | Toro Lawn Mower With Toro Power Tools
I have a self-propelled Toro Personal Pace lawnmower, Model 20022. Both rear wheels engage and rotate when I lift the rear wheels off the ground, but when I put the mower back on the ground, the right...
Routine maintenance is required on the drive gears on these Toro mowers and Toro doesn't tell anybody. Put a block under the rear end to lift the wheel off the ground. Remove the wheel. You will see the drive gear. VERY IMPORTANT: take good notes, pictures, etc..when dissasembling. Remove the outer snap ring retainer from the axle shaft. Next should be a thin washer. Remove the washer. Pay very close attention to the gear, as it has to go back on in exactly the same direction. Remove the gear. There is a slot in the axle shaft. Rotate the axle to have this slot pointed up. In the slot is a small key (rectangular piece of metal), remove the key. Under this key is a spring. It, and the key, is stuck in the axle slot, therefore not allowing the gear to drive the wheel. Dig out the key and spring, clean them and the slot. Put a dab of axle grease in the slot and reassemble. In my shop, this is part of a mower tune-up, and is recommended every 50 running hours. That is usually every other year for the average home-owner.
DO NOT TIP your mower over to do this repair. Mowers are just like cars, they like all 4 wheels to stay on the ground. Tipping a mower over can/will cause fluids to go places they aren't supposed to go.
This is a relatively simple repair and can be done with basic mechanical knowledge and basic tools.
Do the other side too, it needs it.
Sep 11, 2010 | Garden
Toro 22in Lawn mower. Loud gear noise when try to engage drive.
Problem is in the rear pinion gears on rear axle and the design of the axle itself. I have a 2005 model 20041 had the same problem. I found a Toro dealer that had the fix.The problem is creadted by the fact that there is too much "play" in the rear axle. You have to limit that play by installing shims, or washers First, but the 2 new rear pinion gears for the rear axle. While you're at it, you may as well buy 2 new rear wheels because the "grinding" has worn the sprockets on the reas r wheels.Next, get 2 "fender washers", 1/2" ID and about 1" OD. I found it easier to turn the mower over and set it on saw horses to work on it.( drain the gas and oil first). Remove both rear wheels, pinion gears and all the washers etc. (caution - keep all parts from one side together - do not pile all parts together - keep them seperated by wheel - the reason is I believe there is one more washer/shim on the right side than on the left). Now to put everything back together, find a spot on the axle where the washer will fit in between the standard stuff.Install new pinion gears and replace the rest of the washers/shims just as they came off. INstall new wheels and you'll be good as new!
Jul 07, 2009 | Toro Lawn Mower With Toro Power Tools
Toro Power Lawn Mower Logo
472 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Roland W VanLue
Roland W VanLue
Are you a Toro Garden Expert? Answer questions, earn points and help others
