Question about Technics SL-1200M3D Turntable
Serato does not recognise my technics turntable. The turntable is on and turning well but no response from serato. the arms in the serato do not move...help?
  • 670 Answers
Serato is a software to be used with an external soundcard it doesnt care what turntables you have. u have to a rane mixer or one that is serato capable in order to use it. then you have to go and link and sync your time codes
Posted on May 27, 2011
Cant get a digital signal to run serato
It's not really a digital signal, per say. Its an analog representation of a digital signal. This is good because it's easier troubleshoot. The first thing I would try is check the ground wires. #1cause of Serato Traktor problems. If that's not it, play an analog record to see how it sounds. If you have a missing channel, clean the cartridge with a pencil eraser and inspect the stylus and try again. Restart your mixer and computer (this cycles the ground) and you should be good to go.
If not you may have bad cables that will have to be changed. See the thing about turntables is the audio signal never comes in contact with the turntables electronics. it goes from the needle through the arm and out the cables. The cartridge's signal is magnetic not line level so it needs good shielded cables. Perfect opportunity to upgrade the cheap cables from the manufacturer and you can internally ground the turntable at the same time Eliminate the annoying ground wire. It requires a bit of soldering, all amateur stuff. Youtube is filled with tutorials on changing cables and eliminating the ground wire. oh make sure you have a good shielded USB cable.
If this doesn't work I can think of more.
Give more secifics about your setup.
I’m happy to help further over the phone at https://www.6ya.com/expert/erik_149c4c1c216e42f2
Apr 20, 2014 | Technics SL-1200MK2 Turntable
Im playing my SL-1200MK2 threw serato and it when i press play to make the record spin serato pick up that the record is slowly spinning backwards? and no noise is coming from the record
do you have your timecodes set properly and configured with serato? that could be the issue try adjusting the timecodes w serato and basically re sync them. if this doesnt help please let me know
May 11, 2011 | Technics SL-1200MK2 Turntable
There is not a signal going from the turntable (technics 1200 m3d) to serato on my computer. when I analayze it there is nothing
i got my turntables repaired by these guys www.technmics1210repair.co.uk
i did they made my setup work like new so im going to spread the word.
give them a shot
Jan 16, 2010 | Technics SL-1200M3D Turntable
Tonearm not emitting signal into Serato
there is a switch that cuts off the signal when the tone arm docks.check the wiring is not broken inside and that the switch is ok.typically,red green white black red and white are plus and left ground is green and right ground is black.the collar that screws on to the head unit has 4 pins.make sure the contacts are clean.measure the wires one at a time from the tone arm to the rca plugs on the back.the green and black go to the outside collars,and the red and white go to the center pin of the rca plugs
May 26, 2009 | Technics SL-1200 Turntable
One cdj and one turntable
This is possible, by connecting your turntable to the Line Input on the serato box. Then just connect both to your LINE INPUT on your mixer, and set the controls on your Serato Software to LINE INPUT - NOT Phono.
- OPTiC
Technics Repair Videos
Technics DJ Repair
Technics Parts
DJ Parts
DJ Equipment Sales
Audio Video Accessories
Jan 18, 2009 | Technics SL-1210 Turntable
Song playing backward but table going foward with serato.
hi... swap the left and right rca cable.the one who said it works good on the deck but on the screen goes back ward....see what hapen..u
Dec 09, 2008 | Panasonic Technics SL-1200MK2 Turntable
Playing songs backwards wit serato scrach live
I got it partially fixed. The black wire from the tone arm was broken so that been solder back on place nd the rca also the song is playing foward on channel 1 only, thats a start! New problem accuring now! Can't use that table to scarch now caus every time i do so the song goes foward only??? No back and forth in the sound??? I'll get a new tone arm and it should get everything better!
Tone arm pushing towards the cent or the record
Your tonearm is either damaged, or your anti-skate is not set properly. It should be set to ZERO. Take a look at this video for some assistance...- OPTiC.
Digital Analog Therapy
www.djprolab.com
www.1200s.com
Oct 08, 2008 | Technics SL-1200MK5 Turntable
Problem
Make sure your ground wire is connected. I know Serato does not work properly if your ground wire is connected.
Also, make sure your running the connection from the Line Out of the Serato box into the LINE IN on your mixer. You can use the Phono Input also, but I generally tell people to use the line input to avoid any issues. Regardless of which input you use, make sure that your Serato software is either set to LINE or PHONO, otherwise it wont run properly.
- DJPROLAB
Feb 14, 2008 | Technics SL-1210 Turntable
Technics SL-1200M3D Turntable Logo
561 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
