Question about Relic Watches
I have a ZR11622 I can't get the back off to replace the battery!
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 172 Answers
The back of your watch is attached in one of two ways. Look at the watch back. If it's smooth all around the circumference of the back, you have a snap-fit back. If, however, you see little notches cut into the edges--if they were extended, it would make the back look like a pizza that's been cut into slices--then you have a back that screws on and off.
A snap-fit case back often has a small (very small) raised section at one spot of the rim; this is so you can insert a tool called a case knife and pop the back off. If you don't see that small raised section, you'll need to wiggle the blade of your case knife under the edge and gently apply leverage from there--it's usually easiest by one of the watch lugs, as opposed to near the watch crown. If you don't have a case knife, you can often use a thin (but tough!) knife blade to do the same thing. Remember, though, that applying this much force through a knife blade can distort or take a chunk out of your edge, so be prepared to sacrifice a knife or be prepared to re-sharpen it after this exercise. A screwdriver does not work very well; the blades are typically too narrow to provide good leverage without distorting the case back, and they may even cutt a gouge into the watch body. Avoid using them for this purpose. To increase the water resistance of watches, Relic case backs are often very tightly fitted--they're tough to get off, and even tougher to push back into position. I would not be surprised if you would need a jeweler's press to get the back of this watch back into position.
If, on the other hand, you have a case back with notches in it, you will need to unscrew the back of the watch. You'll need a special wrench to do this. There are lots of makers and models from a basic $5 "watch crab" to a $100 workbench-mounted device that works on all kinds of watches, including Rolexes. Again, because screw backs are usually tightly fastened to increase water resistance, simply using a pair of needle-nose pliers in the ridges probably won't work. Nor will using a screwdriver in one notch--these backs are designed to move when equal pressure is applied around the edges, and applying force in one area only locks things up. Under no circumstances try to pry off the back if you have a screw back -- this will damage the threads, and you'll probably never be able to get the watch back together again.
You can find case knives and case wrenches at many jewelry supply stores, mail order supply houses like Otto Frei (http://www.ottofrei.com/store/home.php?cat=296 will take you right to the watch repair tools), and on eBay. However, if you're near a Harbor Freight store, they sell a "watch battery changing kit" and jeweler's press for an extremely reasonable price. These aren't the ultra-high quality tools that a professional jeweler would use, but they'll be perfectly fine for changing the occasional battery for many years. I've probably closed 100+ watches using the inexpensive press I got from there.
Posted on May 27, 2011
2 Suggested Answers
gemineye61
  • 831 Answers
SOURCE: what battery is the replacement? Relic
Thank you FixYa.
Look on the back of the watch, or in the manual. If it doesnt say the battery size you will need to take to jeweler to have them measure the compartment to see what battery is needed. Sorry but no other way to know the battery needed.
Best regards. Jewel
Posted on Sep 20, 2010
What exact battery do I need for Seiko SKA348?
  • Remove back
  • Find battery holder
  • Note battery type
  • Obtain replacement battery
  • Remove old battery and install new
  • Check operation
  • Reinstall back
  • Set time, etc.
OR,
Take your Seiko watch to a jeweler who, for a reasonable sum, will replace the battery
ORORO
Nov 22, 2016 | Seiko Watches
Finding and replacing the battery on my Zodiac sea dragon Z02270
  • Remove back
  • Locate battery. Note mounting arrangement for later battery replacement
  • Install battery
  • Check operation
  • Install back
  • Set time, etc.
Oct 19, 2016 | Zodiac Watches
How do I Replace the battery for my Michael kors mk-5758 watch
  • Remove back
  • Find battery in holder and identify type. Note mounting for reference during installation
  • Place watch and back in a plastic bag to prevent contamination while you obtain a replacement battery
  • Install new battery
  • Check operation
  • Install back
  • Set time etc.
Aug 30, 2016 | Michael Kors Watches
What is the battery that my mk 5590 watch needs?
  • Remove back
  • Find battery and identify type. Note mounting arrangement and polarity (place watch in plastic bag to keep out dust while replacement battery is being obtained)
  • Install battery
  • Check operation
  • Install back
Aug 17, 2016 | Watches
How to replace battery
Some watches the back screws off some have to carefully pry the back of with a knife. Once in look for anything that holds the battery in. Carefully remove the battery and check the number on back for replacement. If it has anything holding the battery in place it is easy to break. If the watch is expensive or has sentimental value take it to a watch repair or a jewelry store for replacement.
May 21, 2014 | Watches
Replacing a battery on a C9 by Champion Womens watch
to change the battery in a champion watch:
(1) remove the back, (2) carefully peel loose the foam strip and set it aside (3) release the battery retaining bracket with a needle or awl and tweezers, (4) grasp the case with your thumb and forefinger so that your thumb is holding the works inside the case, (5) turn the watch over and the battery should fall out (6) put the new battery in the holder, (7) snap the retaining bracket back in place (8) replace the foam strip (9) replace the back 5b238361-61b1-4b0d-ab40-54fb346f5586.jpg
Dec 07, 2013 | Geneva Watch Group C9 by Champion Womens...
How to replace a battery on a ebel watch?
The most water resistant watches will have a screwed down case back and crown for maximum water resistance, both of which are backed by internal gaskets. These are the types this articlde will concentrate on. To change the battery in a water resistant watch you will need:
  • Adjustable case tool
  • Case holder ' + google_ads[0].line1 + '
    ' + google_ads[0].line2 + ' ' + google_ads[0].line3 + '
    ' + google_ads[0].visible_url + '' + ' Ads by Google'; } else if (google_ads.length > 1) { s += 'Ads by Google
    '; for(i = 0; i ' + google_ads[i].line1 + '
    ' + google_ads[i].line2 + ' ' + google_ads[i].line3 + '
    ' + google_ads[i].visible_url + '
    '; } s += ''; } document.write(s); return; } google_ad_client = 'pub-8735055091446807'; google_ad_channel = '5953492595'; google_ad_output = 'js'; google_max_num_ads = '2'; google_ad_type = 'text_html'; //google_image_size = '468x55'; google_feedback = 'off'; // --> google_protectAndRun("render_ads.js::google_render_ad", google_handleError, google_render_ad);
  • Small screw driver
  • Polishing cloth
  • Cotton gloves
  • Small tweezers
  • Plastic tweezers
  • Soft clean cloths
  • Battery tester
  • Paper cup
  1. Place the watch in case holder. Place the watch in the case holder, if you have one. If you do not, place it on a soft cloth.
  2. Check for room to work. Check to see if there is room to attach the adjustable case wrench and rotate it 360 degrees. If not remove watch band.
  3. Remove case back. Fit the adjustable case wrench into the slots on the case back. Tighten it down until it is snug. Be careful not to slip with this tool as it can scratch the case back of your watch. Work slowly. When it is unscrewed gently pry up the case back taking great care not to damage the internal gasket. If the gasket gets damaged it will need to be replaced with the battery to retain water resistance.
  4. Remove battery. The battery will be held in place by some type of retention device. It will need to be removed. Some clips will be removed by using tweezers. Some clips may be moved using a screw driver, and some simply bend out of the way slightly. Remember how it was removed as it must be put back in place exactly for the circuit to be completed after battery change. If the clip is removed, place it and any screws in a paper cup to prevent loss. Remember how the battery was seated, plus (positive) side up or down etc. it needs to be replaced correctly to work.
  5. Test battery. Using the battery tester check the battery. If it is dead move to next step, if it is not take the watch to a jewelers for inspection.
  6. Clean and inspect battery box. Inspect the battery box the battery came out of. If there is corrosion take it to jewelers for inspection. If there is light dust it may be cleaned with a clean soft cloth.
  7. Buy battery. Use the numbers on the battery and buy a new one. Occasionally the number will be obsolete and you will be referenced to a replacement battery in the battery charts. This is the time to also replace the gasket if you need to. Check with a watch maker or jeweler, or the watch company to buy a replacement. We cannot stress enough how important this gasket is to a water resistant watch, without its integrity your fine watch may no longer be resistant.
  8. Replace battery. Using the plastic tweezers if you have them, or fingers wearing cotton gloves, replace the battery. Never use bare fingers as finger oils may corrode or short out the new battery. Carefully replace the retention device as it was remove.
  9. Replace case back. Make sure that the gasket is in place, and not pinched or caught in the case back when you set it in place. Screw down the case back using your fingers until it is tight and needs the case wrench. Attach case wrench as before and tighten down the case back.
  10. Reset and clean watch. Using the appropriate method reset the watch. Use the polishing cloth to clean off any dirt and finger prints.
OR...take to your local jeweler/watchmaker who has the appropiate tools and let them do it for you!!!! :)
Aug 10, 2010 | Ebel Sportwave Gent 100m Water Resistant...
I want to change out batteries
1. Lay the watch upside down on top of a towel or cloth on a flat workspace. Use a small flat head screwdriver or blade to pry under the watch backing, then lift the backing from the watch. Slide the battery cover to the side to access and remove the battery.
2.Take the battery to any electronics store to purchase a replacement. Bringing the old battery will ensure you install the correct type of battery in your Fossil watch.
3. Replace the battery and the battery cover. Apply pressure to the backing until it "pops" back into the watch.
THANK YOU FOR VISITING FIXYA
Aug 05, 2010 | Fossil Dress - Analog Glitz Red Dial Watch
How do you open the back of the Timex Ironkids wristwatch in order to replace the battery? It has four small screws and part of the plastic wristband keeps me from prying off the back to replace the...
mcdevito75 here, Those 4 screws hold the back onto your Timex. Do not try to pry off the back cover, rather you"ll need jewlers screwdrivers to un--screw that back cover to replace the battery.
Jul 31, 2010 | Timex IRONKIDS 70491 wristwatch
Watches Logo
826 people viewed this question
Top Relic Watches Experts
Ansel Alberto
Ansel Alberto
Jim Parker
Jim Parker
Are you a Relic Watch Expert? Answer questions, earn points and help others
