Question about Frigidaire Refrigerators
Possible reasons why my freezer stops working then is again up and running - this is a Frigedaire professional series side by side stainles
  • Frigidaire Master
  • 43,501 Answers
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on May 27, 2011
Freezer ices up and fridge part warm, timer changed worked well for 2 weeks model frt 163ag no frost fridge
Hello Claire Trancoso - If the refrigeration side is the one with the issue, you need to check the damper door/switch that is between both doors. In side by side units this damper controls the cool air from the freezer to come over to the refrigeration side to cool it. Contact a professional technician to diagnose if the unit has a floating restriction, an issue with the evaporator fan or a possible air leak.
Dec 17, 2012 | Frigidaire Gallery Series GLHS269ZDB 36"...
Frigidaire Side by Side Model: PHS68EJSB0 The temperature is warm on both the freezer and fridge. They are at about 25F and 60F. I have cleaned the condenser coils and they are wet now. Initially, the...
If you have the door alarm continuously beeping you will need to try and hard reset the unit. Turn the circuit breaker for 4-5 minutes and retry the unit. But if still the 5 beeps are coming on, then its problem with control panel board.Its not detecting door closed.------- The control board needs to be inspected.---------- If the doors are not getting closed, that means some cold air is getting out and thts why temp is not getting set.This is one possibility of temperature problem.-------- But if both doors are closed tight and no issue of air getting lost out, then other possibility for this problem is weak compressor.-----------
The compressor just keeps on running.The problem is weak compressor.The refrigerant in the compressor is got low.The compressor is weak.The compressor needs to be replaced.-------------- The working procedure of this unit is as follows: --- The compressor starts then it cools the freezer section. When the freezer reaches its cooling level the defrost cycle starts functioning. In this cycle the fan in the freezer section starts running and the cool air in the freezer section is passed to the fridge section and the fridge section gets cold. The air from freezer to refrigerator passes from the section, in that section the damper is located.------------ But as you mentioned that freezer not cooling this indicates problem with compressor.When compressor cools the freezer section then fridge section gets cold.If freezer section is not getting properly cold then fridge section will not cool properly/.So the problem relates to compressor.---------- In the compressor there is a refrigerant called FREON.With the help of this Freon the compressor cools the freezer section.Freon is a gaseous type cooling agent.The compressor will stop cooling when coolant gets leaked from its chamber.--------- Again recharging the Freon is possible, but the cost for that recharging is approx the cost of new compressor.So its always advisable to get compressor replaced.Because new compressor has warranty for few years.------------------ You can get required parts from from online sites like: --- www.repairclinic.com or from searspartsdirect online site. --------- This should help.Thanks.Helpmech.
Aug 21, 2011 | Frigidaire Professional Series PHS68EJSB...
I have a Frigidaire professional model Phs68ejsb since 2009. It will randomly start to cool down both in the freezer and refrigerator side, stay like that for a couple of days and start working again. This...
heatman101
Apr 22, 2011 | Frigidaire Professional Series PHS68EJSB...
Door seal on my Frigedaire sise by side gets hot, what is wrong?
I had this once with a Fridigare GLRS267ZAQ4 side by side but it was also heating up water and the freezer wasn't working very well.
My problem was that the coils and condenser in the back bottom of this unit needed a major cleaning and the fan wasn't working very well. Cheap to buy that part and replace yourself. This problem was causing this unit to heat up everywhere because the coils and compressor were not being cooled properly.
I have often found this unit to get ice build up in the back inside wall and had to take a hair dryer to it in order to melt the ice. This mostly caused problems with the ice dispenser and freezer getting warm.
Right now I am having a problem with my refrigerator not cooling well but the freezer is fine. Guess I'll try to defrost the ice and check the coils again.
Hope this helps!
Kyle
Dec 15, 2010 | Frigidaire FRS3R5EMB Side by Side...
Refrigerator not working
Sounds like a possible defrost system failure,there are multiple components in the defrost system that can trigger this symptom(defrost heater,defrost timer,thermostats) if the freezer cannot go through the defrost process the frost will build up on the evaporator restricting air flow, the freezer will seem to work, but early signs will be fresh food section will start to get warm. Good luck!
Nov 26, 2009 | Cars & Trucks
Frigidaire Frig side by side making a loud buzzing noise
it sounds like the compressor, or something near it. it is generally the only moving part in a refrigerator other than the door, so would be my first guess. If it is constantly running, but staying cool in the freezer there may be a small leak somewhere or the compressor is losing power, and pumping slower.
Jun 15, 2009 | Frigidaire FRS26H5AS Side by Side...
Fridge Not Getting Cold
The only thing i can thing of is the start switch it may be burned out.It is located on the compressor.If your compressors running and there is no cold air in freezer part and fridge you may have a sealed system leak.Open the rear bottom panel while the fan is running and feel the compressor if it is hot and it is running you may need a repair person to come look at it.also forgot to say is if you have frost bult up in rear freezer panel that would indicate it is froze up and will need a manual defrost .After done that the defrost timer may need replaceing it is locatedaround the control and light area.hope i fixya :)
May 22, 2009 | Frigidaire FRT21P5A Top Freezer...
Freezer keeps buzzing
don't worry! its the sound of compressor vibration and it is normal........if the sound is more than turn round the refrigerator and tight the nuts of the compressor stand......................have a nice day:-)
May 14, 2009 | Samsung RB2155SH Bottom Freezer...
Frigidaire Gallery Professional Series - No clock/oven functions
i have an old model of the fridgedare gallery professional series stove. After self cleaning, the ignition sparks for the burners will not come off, they keep clicking and only stops when i pull out the plug. can you help me with this situation?
Nov 01, 2008 | Frigidaire FGB24S5A Gas Single Oven
Refrigerators Logo
107 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
