Question about Ariston Technologies Ariston AWD12 Front Load Washer/Dryer
Ariston margherita washing machine
Hi, Ihave a problem with my washing machine ,I put it on any programme for washing or spinning but after that the motor turns 3 times thye machine will empty the water and the knob starts turning and the light starts flashing until i swith it off.Ihave checked the filter and the motor they are ok can you please help me
  • 1 more comment
  • Anakinlucas Oct 14, 2008
    hi, Ihave a problem with my washing machine ,I put it on any programme for washing or spinning but after that the motor turns 3 times thye machine will empty the water and the knob starts turning and the light starts flashing until i swith it off.Ihave checked the filter and the motor they are ok can you please help me
  • Anonymous Nov 08, 2008
    I have the exact same problem, but unfortunately I don't think there is a solution. Here I am waiting to leave for ten days, I was about to quickly wash and dry some clothes for the trip but instead the knob is turning like it sometimes does!! I don't know whether you have the manual or not but the knob turning is actually listed in the manual as something that happens sometimes, it says not to call them before switching the machine off and putting the knob in stop position and turning it on after a few minutes. If the problem persists, they say, it is reporting an anomaly. doesn't say what exactly...
  • Anonymous Mar 20, 2014
    It turns ok but when you take it out it leaves the actual filter inside the machine and you end up with the black knob you turn in your hand
I have an old Margherita washing machine year 2000, my problem I don't have user's manual. Can you please provide me or teach me how to operate the machine?
Thanks & regards
ray salac
Posted on Sep 03, 2008
    New Friend:
My washing machine will not follow the program...when you start after 2 minutes it will drained and the powdered soap not yet dissolve or not yet used will comes out...i restart twice before it will follow again the program...we buy this machine last feb.1,2011...please give your recommendation what is the main problem because the service center in cagayan de oro didnot solved this for more than 1 month now...hoping for the reply...this is my email address [email protected] i am out of confidence and trust to this service center anymore...thank you...
Posted on Dec 02, 2011
Water is very hot in the machine.what to do
Posted on Sep 28, 2011
I have the same problem. Was anyone able to fix?
Posted on Oct 28, 2008
SOURCE:
WFS1073DD front load WASHING MACHINE Everything works but will not spin fast enough to spin the water out. It spins very slow
Early automatic washers used a motor with multiple windings to provide the various speeds required by different parts of each wash programme. Modern washers use an entirely different sort of motor and the speeds are selected and controlled electronically with feedback to ensure the speed is correct.
I suspect the problem is the electronics - the part of the programmer and controller that regulates the motor speed but you should check the motor and motor brushes, the drive belt and all electrical connections as a matter of best practice before you spend money...
Aug 13, 2017 | Washing Machines
Ariston Washer not running Programme
It sounds as if the brushes in the motor have worn,when the motor stops it wont go through the program,try turning the ddial around to spin to check the motor
Mar 07, 2014 | Washing Machines
I can't stop the dryer from coming on Ariston AL128D, I just want to wash
Hi there, the F button on your washing machine (see manual http://www.gebruikershandleiding.com/Hotpoint-Ariston-al-128-d-margherita/preview-handleiding-431405.html?page=0004) is the clue. if pushed in it won't dry. don't know why, but by trial and error this seems to work
Sep 12, 2012 | Ariston Technologies AL128D Margherita...
Hi I have a Bosch WFL226 MAXX. The wash programmes seem to work OK - the motor operates the drum and the pump works fine and drains the machine. The water level vacuum switch seems ok (it stops it...
Bosch WFL226 MAXX This video will show you how to change the pump washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Dec 21, 2010 | Washing Machines
I have a new hotpoint aquarius washing machine, I put it on Cycle 1, and it stops before spin and I have to manually turn dial to B. is this correct thing to happen?
Make sure that you have selected a programme that does not have a spin, or a reduced or slow spin. if it spins o/k when you select 8, then it cannot be motor problem
Mar 01, 2010 | Washing Machines
Ariston - Margherita Washer -dryer model AWD
Check motor brushes for wear. Brush length is about 30mm new; 10mm or less is too short to do what they're meant to.
Feb 28, 2010 | Washing Machines
Ariston A1635 Margherita Control knob spinning
According to the instruction book - it appears the machine has been stopped mid cycle then re-started.
Switch machine off, turn control knob to a solid circle symbol (they are after every set cycle). Switch machine back on and lights will flash and program is reset. You can then select wash cycle as normal.
Jan 22, 2010 | Ariston Technologies AW125NA 13 lbs. Load...
Ariston Technologies Ariston AWD12 Front Load Washer/Dryer Logo
3,877 people viewed this question
Top Ariston Technologies Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Harjeet Singh
Are you an Ariston Technologies Washing Machine Expert? Answer questions, earn points and help others
