Question about Home
I have an eljer patriot whirlpool tub model 015-0105-00 more of question than a problem . In the back of the tub where pump area is there are two pipes coming up from the plumbing that just stick up like a couple of tail pipes are they some kind of vent they appear to be not hooked up or should they be. Also ther is a clear tube going up to front secured to part of tub inner frame that also appears to be a vent or are we missing something ?
  • 7 Answers
SOURCE: whirlpool corner tub not working
you wiil need to check 2 things.First you will need to check the motor.Their should be a reset switch on the motor.also attached to the power buuton is ablack thin hose if this hose came off the switch or motor than the motor wont come on.Look around for an access door .If thier is acloset in an adjoining room you might find it thier.
Posted on Feb 02, 2009
  • 171 Answers
SOURCE: Whirlpool Tub Access
Hi garyv47,
I'm Harvey the Master Plumber.
Your question is: Your daughter just purchased a new condo with an AquaLux whirlpool tub installed in the bathroom. The front side is removable for access to the mechanicals and is held in place on the lower side by velcro. When you pull the velcro loose the side begins to tilt up, but then stops as it hits the upper edge of the tub. You tried pulling down, but it appear to be held by something. You don't want to pull too hard and break something. Any ideas on how to remove it?
It has been my expirience that the top of these access panals are 'tongue and grove' type construction and are not connected to anything. Usually disconnecting the bottom and pulling the bottom out works. If you are concerned about breakage then it migt be wise to consider the Repair Directory to find a reparman. Or you could talk to the condo maintenance guy. You'll find these guys are a wealth of info.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 19, 2008
brainyass
  • 242 Answers
SOURCE: How can I unclog plumbing in whirlpool tub used to clean dogs?
Depending on how mechanically inclined you are, take apart the tub and clean everything out. No easy task, I know, but who want old dog hair floating around? That will be your best bet.
Posted on Oct 24, 2008
  • 5 Answers
SOURCE: EMBLEM, ELJER TUB. DO I CEMENT THE NEW TUB INTO THE FLOOR? HOW MUCH CEMENT AND WHAT KIND?
The tub should just sit on the floor, and caulked around to seal out any water. If it as a fiberglass tub, you might want to put some grout under the bottom to help support it.
Posted on May 01, 2009
SOURCE: installing whirlpool tub
If it is a five foot tub, home depot usually carries them, if not any plumbing supply store will have them.
Posted on Jun 23, 2009
Need reviews on Eljer Whirlpool Triangle Tubs. Eljer a Good Tub to Buy?
Eljer is owned by Jacuzzi Whirlpool. Very nice tub. Eljer is one of the bigger Bathtub Mfg out there.
Not sure why he has not heard of them. Lowes is probably the biggest seller of that brand.
Rod
US Parts Center
Feb 07, 2013 | Eljer Triangle WP 60x60 LH 10JT
Eljer tub 015-0065 pump comes on, by itself, with no water in tub, is this normal?
not it is not normal for a jetted tub to turn on at any time. It sounds like there is a problem in the circuitry on the pump control box.
what is the model number of the pump?
Feb 16, 2011 | Home
Eljer jetted tub on and off switch will not work
It may seem like a dumb answer but check the ground fault outlet or breaker. Then make sure there is enough water in the tub. It should be a few inches over the jets.
Mar 23, 2010 | Eljer Home
I have 40 year old eljer toilets seat cracked,
This website appears to have what you need
http://www.plumbingsupply.com/eljertoiletparts-patriot.html
Hope this helps?
Jan 20, 2010 | Eljer & Patriot& Elongated Toilet Bowl
I havve two Eljer non-wateraver toilet (Patriot?)
I've never had a problem with Eljer toilets. Try adjusting the fill valve so that it allows more water to enter the tank (if you're over the flush valve, install a coupler made from PVC around the neck of the flush valve- inside diameter of the coupler needs to be the same as the outside diameter of the flush valve filler neck).
Jul 02, 2009 | Eljer Home
Installing whirlpool tub
Jun 22, 2009 | Eljer Home
Apr 29, 2009 | Home
Installation of our whirlpool tub
Your sheet rock will go to the top of the lip of the tub and then your tile will overlap this lip. If it isn't done right, your grout will crack if you are tiling.
Mar 22, 2009 | Home
Home Logo
353 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
