Question about Samsung WF337AA Front Load Washer
My washer turned off in the middle of a cycle and the garment plus light is on how can i fix this.
Lights keep flashing and door locks without finishing cycle
Kenmore HE2 Plus Front Load Washer Keeps unlocking ...
www.fixya.com > ... > HE2 > Kenmore HE2 Plus Front Load Washer
flashing prewash and add garment lights My HE2 Plus will fill with water, but when ...Kenmore HE3 2plus wont finish cycle Washer wont finish the last1 minute of cycle. ...We ran a load twice and it still did not unlock. du is the code for cannot ... Why does the door keep unlocking and locking in between the drum rotating?
Admiral, Whirlpool, Maytag - Washer Repair - Not ... - YouTube
? 5:51
https://www.youtube.com/watch?v=oBihToN6dxs
Sep 6, 2013 - Uploaded by ApplianceVideo.com
Troubleshoot your Admiral Top Load Washer that has these following symptoms: Not Completing all Cycles ...
Washing machines - Ariston
Jan 05, 2016 | Washing Machines
Washer making a clicking sound, the tub isnt draining, and the add a garment stays on
Door switch isn't making. .if door isn't closed the washer won't run and will have the add garment light will stay on.
Oct 04, 2014 | Kenmore HE2 Plus Front Load Washer
Clothes with pin holes are seen afetr washing/drying with He2 plus/He Washer dryer combination
Are you over loading the dryer? I know those combo machines can't dry a lot at once
Apr 28, 2012 | Kenmore HE2 Plus Front Load Washer
Ran Cleaning Cycle, lights blinking w/ F- 21min alternating
f-21 is a blocked drain pump.remove the bottom panel,if you have a shop vac get all the water out,you'll see the pump and in the middle there's a piece that you can turn and pull out,first put towels under and around the pump to catch any water that leaks out,turn the part slowly and with your shop vac catch the water with the vac,take your time and open it little by little catching the water with the vac,when you get all the water out twist the middle part out and clean the catch and feel around in the boot and the pump and make sure you have it cleaned out.stick the middle piece back in and start the washer or you can fill it with a gallon of water and put it into a drain cycle and make sure it drains,if it doesn't you cooked the pump and have to replace it,let me know what you find and next time send the model number.
Jul 25, 2010 | Kenmore HE2 Plus Front Load Washer
Pushed pause. Added garment. Washer will not start again.
possible you have not held "start" button down for the required 5 sedonds to restart cycle??
May 16, 2009 | Kenmore Elite 45986 Front Load Washer
Control lock light will not go off.
Do you have any error codes?
Does water remain in the washer after the final spin?
If water remains in the washer after the final spin, then the door will not unlock. Drain/Spin or Spin Only to remove any remaining water from the washer. The door should unlock at the end of the cycle.
Is the door locked and the Add A Garment light on?
If the Add A Garment light is on, then the washer door will unlock after the Pause/Cancel button is pressed once. Pressing the Start button will restart the washer at the same point where it left off in the cycle.
Is the door locked and the Add A Garment light off?
If the Add A Garment light is off, then the washer door will unlock after the Pause/Cancel button is pressed twice. The door will not immediately unlock while the cycle is running due to a possible high-water level in the washer, high-water temperature, tumbling or spinning. It may take up to five minutes for the washer to stop spinning and draining before the door will unlock. You will hear the door click when it unlocks.
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
Dec 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Control Lock
Restarting my washer
did you try, unplugging unit for 30 secs, then replugging and starting again
Dec 07, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Samsung WF337AA Front Load Washer Logo
141 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
