Require driver update for recently purchased "GIGATECH" USB portable diskette Drive.ASM P/No. 27LA4226=-- PRU No. 05K9283. Thanking you in advance. (David) C.A.Hansen. E-mail address thorbil@bigpond.com.au
  • 185 Answers
Try from the links to get the updates
http://www-307.ibm.com/pc/support/site.wss/MIGR-4P52BK.html
http://www.gigatech-lb.com/
Posted on Aug 16, 2008
NEED TO USE FLOPPY DISC
Search on eBay for an "external USB-interface diskette" drive.
Very cheap, if you buy from a seller in China.
Mar 09, 2014 | Lenovo Thinkpad 05K9283 - USB Portable...
Ibm portable disk with iMAC
You should be able to use it, just plug it in then open up disk utility which can be found in applications and then utilities. Once open you can format whatever way you require.
Jan 27, 2012 | IBM USB Portable Diskette Drive (05K9276)...
IBM USB Portable Diskette Drive (08K9835) driver
Are you allowing Windows 7 to connect to the Internet to download a device-driver? Or, if you run "Windows Update", does it recommend a "hardware" update for the device?
Jan 01, 2012 | IBM Computers & Internet
I have a usb portable diskette drive that says compatabible upto windows 98 I have windows 7 can I download drivers for it?
If it won't plug and play then your basically out of luck. That is a very old device. If you still need to access floppy's i would purchase a newer device or have an internal floppy installed.
thank you,
Lee
Jul 26, 2011 | IBM USB Portable Diskette Drive (05K9276)...
I have a Teac USB portable diskette drive, N533. Until recently, it has worked okay. However, it has started not opening any diskette I put in and instead a message appears that the disk needs to be...
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers
if you can see your usb drive but its not working
ports(com&lpt)right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts also
scroll to disk drives if you can see your drive + to expand right click you should see options update driver disable uninstall scan for hardware changes
select properties you should see options in the general tab to troubleshoot policies volumes driver and details under the driver tab you will have the options to check the driver details update driver rollback driver or uninstall
hope this helps
Apr 28, 2011 | Teac IBM USB Portable Diskette Floppy...
I bought an ibm usb portable dikette drive by amazone and my xp doesnt recognize it , i have a driver for this and if yes where can i get it
You should not require a driver if you are running windows XP. Does windows ASK for a driver or does it just say that the hardware might not work properly - because in that case it might just be that either the hard drive or the casing that the drives comes in is damaged.
Feb 03, 2011 | IBM USB Portable Diskette Drive (05K9276)...
Need for IBM USB Portable Diskette Driver for windows 7
Any "plug-and-play" device with a USB interface should be supported by Windows XP/Vista/7/8. Try it!
Nov 12, 2010 | IBM USB Portable Diskette Drive (05K9276)...
Have bought a second hand IBM USB Portable Diskette Drive. It worked just fine at the sellers place. Now that I try and use my own PC I load a 1.44 Mb diskette and it tells me to load disk ??? What to do...
Hi Graham,
Your Portable USB 3.5 diskette drive uses a pretty old technology that would come with software or drivers needed to run it. You would need to check on your device manager on control panel. But I would advise you upgrade yourself to better storage devices like the flash drive or the CD/DVD USB portable drives. They are a bit more expensive, but the technology is newer and have less issues. Let's face it, the 3.5 diskettes are getting pretty outdated. Don't you think so?
Cheers & Kind Regards
Sep 24, 2009 | IBM USB Portable Diskette Drive (05K9276)...
Computers & Internet Logo
161 people viewed this question
David Payne
David Payne
