Question about Bissell Vacuums
Will not spray to the floor - Bissell Vacuums
My Bissell Proheat carpet cleaner/hose for cleaning will not spray anything
My ProSeries Carpet Cleaner won't spray. What ... - Bissell
www.bissell.com > Support > Helpful Resources > FAQs
BissellLet's start by figuring out where your carpet cleaner can spray. If you have no spray at all, start below. If you have no spray at the floor but can spray from the hose, scroll down for the ... Turn the unit on after cleaning and see if water sprays to the floor now. IV. .... My ProHeat® Self-Propelled's Powerdrive isn't engaging.
Bissell Carpet Cleaner Won't Spray. Easy Repair - YouTube
? 1:48
https://www.youtube.com/watch?v=nccdrjpGp34
Dec 20, 2013 - Uploaded by Cecil Argue
You may have a bad pump, clogged hoses or a clogged heater. ... Just want to tell you that this was the perfect ...
Nov 30, 2015 | Bissell Vacuums
Bissell 9500 proheat 2x wont spray liquid to the floor
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
ghhdg
May 29, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
I have no spray on floor but have spray at hand
Same Bissell 9500 cleaner. Hand piece works fine, but cant spray water / cleaner when doing the floor. I've made sure the rollers are working and taken my air compressor on low psi and blown back to make sure the floor spray lines are clear...
Going to take apart and check the pump today.
Still looking for help! Thanks
Sean
Apr 18, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell spray to floor not operating. Spray to upholstery fine.
heatman101
urr
Jan 01, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
I can't get the solution to spray or suction from the floor . the hand attachment will spray somewhat and suction, but not from the floor. i have the blue 9200
If it is only a problem with the floor sprayer, this suggests that the nozzles or tubes to the floor unit are clogged. Take off the water storage part, and you'll see two red clips (these are the floor nozzles). Squeeze and pop these out, and see if they are clogged.
If that is not the issue, open the unit up and see if the tubing supplying the front (floor) nozzles are clogged.
Please let me know if this was the issue or not.
- Matt
Dec 22, 2009 | Bissell 9200 Upright Vacuum
My Bissell ProHeat steam cleaner won't spray water. The accessory
Under the plastic under the water tank (its a pain to pull apart to get to it) there is a solenoid that actuates the water between the floor and the tools. This is toast if its not spraying the floor, its simply not reacting to the signal to let it go through to the water side.
Seems to be a common problem with the Bissell Proheats. You can order a new one online for about $12 and try to get to it to replace it yourself (if you can open up the base its obvious which part it is if you just follow the hoses).
Sep 22, 2009 | Bissell 1697-7 Powersteamer Pro Deluxe...
Floor spray not working
my bissel carpet cleaner is working apart from it will not pass any water ?? help
Sep 14, 2008 | Bissell Vacuums
9200 sprays out of hose but out of floor
Try taking the tank off, remove the 2 spray nozzles and blow thru them to see if they were clogged. You could try running a mix of vinegar and water, sometimes that will open up any clogs. Is the knob on the floor setting?
May 04, 2008 | Vacuums
Vacuums Logo
14 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
