Question about Roper RT18DKXKQ / RT18DKXKT Top Freezer Refrigerator
Our refrigerator (Roper RT18DKXKQ) smelled really bad for a long time, though we saw no spoiled food. So we cleaned it out, and noticed that there is water leaking, dripping from the ceiling of the refrigerator (from the foam area). How do we stop this leaking? I am guessing it is somehow coming from the freezer, through the top of the refrigerator.
  • Roper Master
  • 43,501 Answers
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Posted on May 27, 2011
The refrig has stinky smell after not opening it for two weeks without any spoiled food.
Is it a moldy odor or rotten food odor?
I suggest cleaning interior and then spraying with odor remover like: Nok Out Odor Eliminator and Sanitizer
Mar 20, 2016 | Refrigerators
Used wrong water filter. Now that we replaced with correct filter, there is a horrible odor in the refrigerator.
Hello Mary;
My name is Peter. I am a retired field service refrigeration technician.
Putting in the wrong water filter will not effect the smell in your refrigerator. At times the granules in a water filter will break down and get into your water dispenser and ice cube tray. This should not create a bad smell, just cloudy water.
Your plastic liner in your refrigerator has pores and holds odor. You have something in your fresh food section or freezer that is spoiled. Your fresh food section receives cooling air from your freezer. If you have a spoiled product in your freezer you will not smell it because it is frozen. But, as the cooling air goes into your fresh food section and cools down you will smell it.
Find the bad product in your freezer and discard.
With a 50% solution of white vinegar and water wash the plastic liner.
Now you can put a tray of baking soda in your unit, until you purchase deodorizers based on temperature requirements, one especially designed for the freezer section and one for fresh food section. These deodorizer are about $12.00 each.
Try Lowe's and Home depot.
May 11, 2015 | Samsung RF31FMEDBSR Stainless Steel 31 cu....
The refrigerator in my new home is Roper RT18DKXFN01, a 1997 top freezer about five feet tall. Should I be pulling out pans from the bottom and cleaning them? If so, I can't get it to move - is there some...
Hi ; Not an expert on this fridge,
You do not need to clean the coils
But at the back of the fridge , there should be a water trap sat on top of the compressor that is linked to the fridge via a pipe.
It allows condensation to run out of the fridge to the trap, where the heat from the compressor evaporates it.
Its possible that food waste has travelled down the pipe into the trap and is creating tha bad smell
You could also check the back for anything else that may have arrived by default and is causing the smell
Not sure if it has a special way to move it : But its a heavy object , so a little extra force may be needed.
Take care and good luck
Apr 21, 2017 | Roper RT18DKXKQ / RT18DKXKT Top Freezer...
Samsung RF267 water tastes terrible. Filters changed twice and not helping
If new plumbing, system is flushing and may cause a bad taste or odd color.Has a food item spoiled?
Make sure that strong smelling food (for example, fish) is wrapped so that it
is airtight.
Clean out your freezer periodically and throw away any spoiled or suspect food. Place foods in airtight containers to prevent the transfer of odors.And also Flush out water hose from tap end to freezer with warm water And also clean fridge with wet cloth (with soap solution). And then clean with dry cloth. .Keep fridge door open after cleaning all compartments for 4hrs minimum, as fresh air could wipe out any bad odor in fridge. And then start using fridge. Hope, it's helpful.
Jan 29, 2011 | Samsung RM255LASH Side by Side...
Refrigerator fan is running but there is no refrigeration happening. First noticed it a few hrs ago when preparing to fix dinner. All foods in freezer are thawed. email me at dijagro@gmail.com
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Sep 16, 2010 | Roper RT18DKXKQ / RT18DKXKT Top Freezer...
Whirlpool Gold GS5SHG Refrig/Freezer trips gfci
Sounds like the condesor coil fan motor went bad and shorted in the windings or stator. It can be replaced fairly easily. You can get the mtor from one of the online part stores and install through the base of the unit next to the compressor. you should clean the area of lint while your down there, it helps keep it operating more efficiently.
Jun 08, 2009 | Roper RT18DKXKQ / RT18DKXKT Top Freezer...
Chemical odor in refrigerator/freezer
put coffeee grains or orange peeles this will take the smell away thanks from gilles
Mar 14, 2009 | Refrigerators
Smelly refrigerator
HI.
i guess u will benifit from this link
plz rate this post
click here
BEST REGARDS
Aug 13, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Ice and Refrigerator and Freezer smell like alcohol chemical
I believe that you might have a coolant leak causing the chemical odor. You really should get it checked out by a fridge repair-person because it's not healthy to breathe in the fumes.
May 21, 2008 | Hotpoint HSS25GFP Side by Side...
Roper RT18DKXKQ / RT18DKXKT Top Freezer Refrigerator Logo
172 people viewed this question
Top Roper Refrigerators Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Roper Refrigerator Expert? Answer questions, earn points and help others
