Question about LG WM-2277HW Front Load Washer
My lg washer shake s alot when it is spining and makes a loud noise please can you help
Lay machine on it's side check If the balance block on the drum underside is loose, it's secured with 3x13mm bolts
Posted on Aug 16, 2012
  • 489 Answers
The washer needs to sit on a solid foundation for this to work. When the washer is spinning a load of clothes, push the corner of the washer till the noise or vibration quiets down. When it does quiet down, adjust the leg below to reduce the noise.
Good luck
Posted on Jun 15, 2011
When do i know when is over load
The WASHER will Spin Off Balance.,making loud noises.,and Shake alot.,you also may hear squeek noises from THE overloading of clothes..,in THE Belts too..around inside THE Pully."
Feb 24, 2013 | Frigidaire Washing Machines
My maytag 3000 series washer wont stop skaking
bearing are shot if it makes a loud noise, or you put to much clothing in the washer.
Nov 13, 2011 | Maytag Washing Machines
Excessive shaking on spining , washer moves a round on the floor I have leveled it rght on the nose.
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems
Washer noise when spinning
heatman101
Feb 18, 2011 | Kenmore 44042 Front Load Washer
I n the spine cycle the washer makes a loud noise and shakes.I found a dime under the tube between the rim and door gasket.
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
Sep 22, 2010 | LG WM2016C
Washer shakes when spining. More on heavier loads.
shaking is generally due to inadequate floor structure under machine; i.e. plywood floor. in addition, if the washer is on a "pedistal" it will make matters worse; as the center of gravity is away from the floor. in rare cases, one of the drum "struts" can fall apart; and, cause excessive shaking. if you broke the locknut on one of the legs, unscrew the leg, and bring it to the hardware store for a replacement nut.
Feb 15, 2010 | LG WM2487H Front Load Washer
When spining it makes very loud noise , like aeroplane when start
Hi.
It definately sounds like the drum bearings have failed.
It is a DIY job, but not easy, as it entails stripping the m/c down,
If it is under 5 years old, then it should be covered by a 5year warranty., you will just have to pay for the labour, certainly the cheapest option.
Nov 23, 2008 | Kenmore Elite 45986 Front Load Washer
Maytag front loader shakes really loud
make sure the transport tie downs have been removed during installation and that all four feet are adjusted properly so machine does not rock.Also make sure your floor is reasonably solid.
Sep 25, 2008 | Maytag MAH21PD Front Load Washer
Lg wm1832cw front load washer
One of 2 things may be causing the loud noise.  Either the rear bearing on the drum has failed and will need to be replaced (very expensive) or the drain pump has a bearing problem and is making a very loud noise when it is draining (not too expensive).  Either way, you will need a qualified LG technician to diagnose and repair the problem.
Jun 14, 2008 | LG WM-1832C Front Load Washer
Amana NAV8800AWW making noise while running and spining. It used to shake the floor while spining. But lately machine is making noise but not as shaky as it use to be. Thanks for your help.
Spin Shake is usually contributed to a weak floor support condition. Also, carpeting under the leveling legs can cause a "spongey" effect, which can produce the shakes. Prolonged shaking can cause parts to loosen and make noise.Firstly, we must determine what loosened up from all the shaking.
Remove the front panel by removing the 2-5/16" screws located at the bottom front. Pull out at the bottom to release the top retainer clips, and set aside.
Warning! Never reach inside the machine while it is in operation!
Investigate the cause of the noise by setting the washer to spin, and turn on. Inspect all moving parts for possible wear or breakage. Next, stop the machine and inspect for loose or worn suspension parts, nuts, bolts, struts, hoses banging the cabinet, etc. A protective motor cover can cause noise, or a belt slapping the base mount. Once you have conquered your noise issue, then we will have to eliminate the shakes, provided, what you repaired wasn't the cause...and usually isn't.
Carpeting under the leveling legs should be removed or cut away.
If other items in and around the laundry room shake, then you will need to add support to your floor joists. Shim the floor from under the house while the washer is spinning for best results.
Your installation instruction manual should tell how level the washer properly, after you have added support to your floor.
Good Luck! Post me back if can be of more assistance.
Dave E. (Illeagle)
May 20, 2008 | Amana NAV8800E Top Load Washer
Spin cycle doesn't work with loud noise
yea sounds like a bad motor coupling ( this machine equivelent to a belt).
Mar 06, 2008 | Whirlpool LSR7333 Top Load Washer
LG WM-2277HW Front Load Washer Logo
310 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
