Question about Microwave Ovens
My Panasonic microwave (NN-T571S) no longer heats although other functions appear to operate (not all the time though as it sometimes cuts out mid program). Problem occurred after cooking potatoes on sense 3 times consecutively following which there was a burning smell and the top of the microwave got very hot. There was a plastic container on top so not sure if this was the cause of the failure (and burning smell). Any advice on possible repair would be appreciated.
  • 591 Answers
Don't look for a guilty one!!! you have a busted MAGNETRON unit, and it is usually as expencive to replace than the oven it self... sorry...
Posted on May 26, 2011
Panasonic NN-H965WF Microwave oven
We recommend the microwave is evaluated by an authorized service center by using www.panasonic.com/repair Welcome to Panasonic Online Repair
Apr 13, 2014 | Panasonic Microwave Ovens
Panasonic Counter top Microwave model # NNT695SF Often when I push the start button, the microwave will go for a few seconds and then cut out. I then open the door and then shut the door and push the...
Issue with your Main Panel Power Fail to innitiate ..Du to Component mal-functioning inside the unit ...Possibility Magnetron defect, Or main Transformer Over heat, Also check for safety swich on the door for bad connection...
Sep 30, 2010 | Panasonic NN-T695SF Microwave Oven
Our Panasonic 1350 microwave no longer heats food.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
ghdgh
May 13, 2010 | Panasonic NN-S963BF Microwave Oven
My NN-T695 Panasonic microwave oven starts up for two seconds then cuts out before doing any warming?
I'm having the same problem with the same model microwave. It has taken hard use for a long time, but now it will (sometimes) start and then stop after a second or two. I think it's a loose connection, because a couple of times I got it to work by rapping on the back or side.
Mar 02, 2010 | Panasonic NN-T695SF Microwave Oven
Microwave heats intermittently
Doug, not not attempt repairs on your m/wave unless you have had training.
When you take off the cover even with the plug turned off, their is still charge inside the m/wave which could kill you!
sounds like the magnetron may be faulty, get your approved engineers to carry out a' power check' on the magnetron etc,
Sep 28, 2009 | Panasonic Microwave Ovens
Microwave cut off
the main control board is "seeingf" a high amprage draw from the inverter board . you have a problem with the inverter or the magntron . parts are more than a new unit . try to stay away from the inverter type , there just not ready for prime time . google "panasonic inverter reviews " and you will see just common your problem is good luck
Jan 16, 2009 | Panasonic NN-S753 Microwave Oven
Stopped heating, shuts off before time expires
My panasonic microwave model # NN-S540BFW stops after 4 seconds after you hit the start button and cuts off on its own. What is wrong with my microwave?
Jan 12, 2009 | Panasonic NN-S763BF Microwave Oven
Microwave shuts off after 3 seconds
Although your model number doesn't seem to show up, the NNS950-series units are powered by an high-voltage inverter. And yours has failed. While an inverter (switched-mode power supply) is more efficient from a power consumption standpoint, it is more complex, thus more statistically prone to fail. These should only be examined and worked on by someone who has the necessary technical qualifications. Seriously. Often the machine-soldered connections in a microwave inverter are too weak, so they eventually fail, especially if heat is high in the area. They sometimes fail catastrophically. When not catastrophically damaged, you may hear clicking or squealing and may smell an electrical odor, which is sometimes obscured by the cooling fan. Sometimes a whole new inverter is cheaper than the time and labor required to fix the old one. If a technician is willing and able to troubleshoot and repair the inverter to component level, it will may be expensive, but may be worth it, especially if he or she will resolder and reinforce connections as needed as part of a thorough repair. That could easily make your inverter beter than a new one! You might be able to get some verbal estimates if you call Panasonic-authorized appliance / microwave repair shops and ask then specifically about inverter component-level repair and simple inverter replacement costs for your exact model number.
Dec 26, 2006 | Panasonic NN-S950WA Microwave Oven
Microwave Ovens Logo
278 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
