Question about RCA Audio Players & Recorders
Can't hear my speakers, but i can hear through my headphones
  • yadayada
    yadayada May 26, 2011
    Do you have the speakers muted?
    Brigadier General:
  • 3,301 Answers
Check the speaker connections, if you have a receiver that has front and rear,, switch the speakers to rear to make sure the speakers themselves are working correctly, by allowing the headphones to produce sound its letting you know the outputs for the receiver itself are good , also,, be sure that the speaker selection switch is ON and that its set for the correct speaker selection. (re front or rear or both) and that Mute isn't on
Posted on May 26, 2011
Headphones plugged into TV audio output but speakers don't turn off
use the tv's setup menu to set the audio properties,eg. speakers on or off when headphones are plugged in.
Dec 22, 2012 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
When I play a song it will sound like its just instrumental on the speakers and when i plug my headphones in I can hear the words, then I will unplug the headphones and it will go back to instrumental....
the speakers your plugging in aren't making full contact inside the plug which means you either aren't pushing it in far enough or the metal connectors are bent. if your device is in a protective case try taking it out and plugging in your speakers sometimes the case will prevent a tight connection. other than that you need to get the device looked at.
Mar 03, 2012 | Apple Audio Players & Recorders
I would like to listen to my saddisk with out using my hear plugs
The Sansa does not have any speakers. You need to have something produce sound. If you don't want to use headphones/ear plugs, you can plug some speakers into the headphone jack.
Jan 13, 2012 | SanDisk Sansa e140 MP3 Player
Cd boombox and headphones
HelloWhen a headphone pin is inserted into a headphone socket, it is normal that the internal speaker of the system will cut OFF. It is normal operation, and not a fault. The speakers of such portable sets are wired such that it should cut OFF when headphone pin is inserted into it. We inserts headphone pin to hear the reception or CD music personally. So there is no need for an output from its speakers. Isn't it?
Dec 18, 2011 | Disney Memorex Portable CD Boombox...
I hear echo sound every time i play music/movie and i cant figure out to turn it off "how"
Does it happen with headphones in as well? If not, do you have a built-in-microphone? Sometimes the sound coming of the speakers can be picked up by the microphone, resulting in an echo sound. Make sure that the microphone is off (or test it by covering it up while playing some music), and quit out of any applications that are using it.
If you hear it in the headphones as well, it could be a sound card problem, which means it would need replacing. If you don't hear it in the headphones, but hear it in the speakers and don't have a mic, it's either your speakers, or (more likely) your computer just doesn't get along with whatever software you're using to play movies/music.
Sep 17, 2011 | Acer Aspire 6930-6771 Laptop
I'm not getting any sound out of the speakers. I have sound through my headphones but cann't get anything out of any speakers.
If you can hear the sound from the headphone(earphone jack), the fault is between the headphone itself or the speakers. Check the continuity of the speakers(voice coil) using the multimeter to determine if it is faulty or not.
If you've confirmed that the speakers are not the issue here, you may spray an electrical contact cleaner to the earphone jack of your unit while pulling and inserting the headset plug to clean the contact from dirt build-up inside. You may also replace the earphone jack with new one to back the unit in normal operation.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Aug 18, 2011 | Teac AG-V8060 Receiver
How can I get headphones to work with my Symphonic WF203 TV?
This set doesn't have a headphone jack, nor does it have RCA audio output jacks. Without one or the other, you're out of luck connecting headphones to this TV.
I remember a product some years ago that allowed adding headphones using a small microphone placed in front of the speaker. This was hooked to a little amplifier that ran the headphones so the volume could be independently controlled. It was marketed as a way to let "hearing-impaired" family members listen to TV shows without needing to make it uncomfortably loud for others. I haven't looked, but something similar might still be available. It's cumbersome, though, and needs power, plus maybe being costly if you find one.
It's possible to add a headphone jack, but you need to know how to do electronic soldering. Find a spot on the case where you can make a hole and mount a headphone jack, then wire it to the speakers. If you want the headphones to cut off the speakers when plugged in, you need a switching jack, and the speaker wires need to be cut and connected to the correct terminals. The switch built into the jack then disconnects the speakers when the headphone plug is in. If you don't need to turn off the speakers it's a little easier. You just need to wire from the jack to the speaker terminals. I've added jacks on quite a few sets. If you don't feel up to it and don't know anyone who is, you can see if a TV shop (if there are any left in your area!) would do it. (The shop I used to work for charged about $20, including the jack, but that was over 10 years ago now.)
Good luck, and thanks for using Fixya!
Jun 12, 2011 | Symphonic WF20D4 TV
I cannot hear while making calls. The volume switch does not work either. When I make a call the other person can hear me but I cannot hear anything. The system sounds and ringer volume are turned up....
When making calls, try putting it on speaker phone.
This problem is widespread, and it is due to a problem where the phone does not recognize that the headphone jack has been unplugged. This means that the phone will send data to the headphone jack, and not to the speaker anymore. You can try to 'unstick' it by inserting and removing a jack until it recognizes it, or repeatedly blowing into the phone's headphone port. Both of these solutions have worked for me, but they take quite a bit of effort, so I have just gotten into the habit of using speakerphone. For me it still works, event when the phone is in headphone mode.
May 01, 2011 | Palm Pre Cell Phone
My son hears better with headphones we can't hear tv
It is normal that when you plug in the headphones the main speakers are switch off.
You can get the TV modified by a TV repairman to disable the switch that cuts off the speakers when the headphones are plugged in.
May 02, 2009 | ASUS m6n Notebook
83 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
