Question about Campagnolo Cycling
Can I transfer Campagnolo Italian thread bottom bracket cups (I think from a chorus) onto a Record Campagnolo English threaded cups.
    Brigadier General:
  • 8,546 Answers
There's a reason they have a different name.
http://en.wikipedia.org/wiki/Bottom_bracket
Posted on May 27, 2011
What is the part number for the bearing and bearing cup on an unidentified bicycle?
you will have to take it to a bike shop. real hard to read numbers you can not see.
Mar 12, 2016 | Cycling
Tip
How to Remove and Replace the Bottom Bracket on an Indoor Cycling Bike
Following is a basic guideline of removing and replacing the bottom bracket on an indoor cycling bike. Due to the different brands of indoor cycling bikes and designs for bottom brackets, the following should only be used as a guideline. If any of the information is not exact to the bike being serviced, refer to the service manual or call Sportsmith for further help.
Common Tools Needed:
Phillips Screw Driver
Set of Allen Wrenches (standard and metric)
Bottom Bracket Tool
Cotterless Crank Puller Tool
9/16" Socket
Ratchet Wrench
Pedal Wrench
Crescent Wrench
You will begin by removing the outside belt/chain guard by using either or both the Phillips screw driver and Allen wrenches. It may be necessary to remove the drive side pedal (using the pedal wrench) in order to completely remove the outside belt/chain guard.
Once the belt/chain guard is removed, you will need to remove the belt/chain. If the unit is belt driven, you can simply "walk" the belt off the pulley by pushing the belt to the outside while turning the crank backwards. **CAUTION: PINCH POINT ** If the unit is chain driven, most use a continuous chain that can be "walked" off the sprocket just like the belt. **CAUTION: PINCH POINT ** Some chains may use a connecting link and can be separated at the connecting link to remove the chain. The connecting link is different in appearance from all other chain links.
Now it is time to remove the crank arms. How to Use a Cotterless Crank Puller Tool
It works best to place the bike upside down for best leverage to remove the bottom bracket. (If placing the bike upside down, ensure proper seat adjustment for best bike balance.) Begin removing the bottom bracket from the drive side of the bike. This side has a reverse thread. You will need to turn right to loosen and remove the bottom bracket. Place the teeth of the bottom bracket tool into the teeth of the bottom bracket cup. Using the ratchet wrench or crescent wrench to turn the bottom bracket tool, you will turn right to loosen and remove the bottom bracket. (If removal of the bottom bracket is difficult, it helps to use a crescent wrench in combination with a bolt threaded into the bottom bracket shaft to hold the tool in place while applying pressure to break the bottom bracket loose.) Remove the bottom bracket from the frame. Remove the bottom bracket cup and/or lock ring from the non-drive side of the bike. This is a standard thread. You will turn left to loosen and remove this bottom bracket cup and/or lock ring.
Install the new bottom bracket from the drive side and tighten flush to the frame. Install the bottom bracket cup and/or lock ring to the non-drive side and tighten.
Re-install the crank arms and pedals. Make sure the crank arm bolts are tightened to the proper torque. If unsure of proper torque specs, refer to the equipment service manual or call Sportsmith.
Re-install the belt/chain onto the pulley/sprocket. If belt/chain was "walked" off the pulley for removal, it can be "walked" onto the pulley/sprocket by placing the belt or chain along the bottom of the pulley/sprocket. Carefully, turn the crank arm forward while lifting on the belt/chain. **CAUTION: PINCH POINT ** Continuing turning the crank forward until the belt/chain is in place.
Re-install the outside chain guard and test the unit. Ride the bike without tension and test with tension. Ensure functionality and feel of the ride. Make any adjustments if necessary
Removing and Replacing Bottom Bracket on Indoor Cycling Bike
on Mar 11, 2015 | Exercise & Fitness
Tip
Bottom Bracket & Spindle Replacement of LeMond RevMaster
Part 1 Video Discussing the Dis-assembly & Inspection of the Bottom Bracket & Spindle for a LeMond RevMaster Bike
  • This Part 1 video will demonstrate how to inspect and adjust or remove and replace the bottom bracket and spindle on your Lemond Revmaster
  • Tools needed for this procedure:
    • 8mm Allen Wrench or Socket
    • Cotterless Crank Puller Tool
    • Lock Ring Removal Tool
    • Bottom Bracket Tool
    • Phillips Screwdriver
    • 4mm Allen Wrench
    • Bungee (optional)
    • Rubber Mallet
    • 7/8" Wrench
  • To begin remove the belt cover, there are four screws
    • You will need a 4MM Allen wrench
  • Now remove the two screws on the back from the opposite side of the bike
    • You will need a Phillips screwdriver
  • Now position the crank arm as seen in the video and remove the belt cover from the bike
  • Before removing the drive belt, tighten the brake assembly so that the flywheel is locked in place and loosen the torque on both bolts using an 8mm Allen wrench or socket
    • Do not remove them at this time only loosen them by a half a turn or so
  • Using a 7/8" wrench loosen the belt idler
  • Now use a 4mm Allen wrench to loosen the tension adjustment bolt completely, but do not remove it from the frame
  • Now remove the drive belt
    • To aid in this process you can use a bungee to slide in behind the belt at the top, as shown in the video
  • Then pull away from the bike while spinning the crank arms
  • Now remove both crank bolts with a 8MM Allen wrench or socket
    • Removal of the crank bolt on the left side of the bike is the same as removal from the right side
  • Now remove the crank arms with a crank arm puller, threading the outer portion into the crank arm as shown in the video
    • Be sure to thread the outer portion in as far as possible to prevent damage to the crank arm threads or the tools threads
    • Use a 7/8" wrench to make sure the outer portion is threaded in completely
    • Now spin the handle clockwise to press the crank arm off of the bike
    • Be careful when the crank arm comes off as if you are not holding it, it can fall in the floor
    • Also use the wrench to loosen the tool before removing the crank arm from the unit
    • Now you can unthread the tool from the cranks arm by hand after removing the crank arm from the bike
  • Next inspect the bottom bracket cups for looseness, to do this use the bottom bracket tool by hand to see if you can turn either of the bearing cups
    • To further verify the adjustment of your bottom bracket use a rubber mallet to tap lightly on each side of the spindle to check for movement from side to side, if you have movement, or one or both of the bearing cups is loose, you need to re-adjust the bottom bracket. If you are only inspecting the bottom bracket and did not find any need for adjustment you would re-assemble the bike at this point
  • Once the crank arms are removed look closely at the spindle
    • It should have defined edges and be smooth
  • As you can see by the video our spindle needs to be replaced
  • Next you will need to remove the lock ring
    • The lock ring is around the bottom bracket cup on the left side of the bike
      • In the video is an example of a lock ring
    • To use the lock ring tool you slip it over the lock ring using the three notches and torque the lock ring in the proper direction
      • This one needs to be turned counter-clockwise to loosen
    • Then remove the lock ring by spinning it off the bearing cup
  • Next you will need to use the bottom bracket tool to remove the bottom bracket cups
    • Begin with the left side
      • Slip the tool into the splines of the cup and loosen
        • For stubborn bottom brackets use a 5/16"-24 x 2" bolt and some washers with a 1-1/4" wrench
          • Slip the tool into the splines and thread the bolt with the washers into the spindle
          • Get it snug but not completely tight
      • Now use the wrench to turn the cup counter-clockwise for the left side and remove it completely
    • Remove the cup from the right side now
      • Slip the bottom bracket tool into the splines of the cup and turn it clockwise to loosen
    • If you cannot get the cups loose with this method try turning the bike on its side to get better leverage as shown in the video
  • This concludes the dis-assembly and inspection procedure of the LeMond RevMaster bottom bracket & spindle
  • Click here to see Part 2, re-assembly and installation to complete the replacement procedure
Video of Bottom Bracket and Spindle Replacement Part 1 Dis assembly LeMond...
on Feb 19, 2015 | Lemond Revmaster Lemond G-Force Digital...
How do i Reconnect the speedo cable on my 1978 GMC Truck with 350 motor, 4x4?
Depending on which end needs to be reattached, At the Speedometer Head or at the Transfer Case, or at the Cruise Control Module (if equipped with Cruise Control).
At the Transfer Case : Underneath the truck, on the left side of the transfer case, near the tail housing/rear of the transfer case (if it's a NP203 or NP205), there should be a small rectangular box threaded onto the transfer case, the other end (facing away from the transfer case) has a threaded end on it where you'll thread the end of the speedometer cable on.
At the Speedometer : Behind the instrument cluster, protruding from the back of the speedometer, is a round male port that the speedometer cable snaps onto. You just push it onto the back of the speedometer and it locks into place. Some cables have a metal end for the Speedometer end, some have a plastic end. The ones with the plastic end will sometimes break and won't stay locked in place at the speedometer.
If it's equipped with Cruise Control, you'll have 2 Speedometer Cables, an Upper Cable (From the Cruise Control Module to the Speedometer) and a Lower Cable (from the Transfer Case to the Cruise Control Module.) Both ends of the Lower Cable have Female Threaded ends (one to thread onto the box on the side of the transfer case, one to thread onto the Cruise Control). The Upper Cable has one threaded end and one Clip On/Press On end. Reconnecting the cable is the same as the methods I mentioned above, but with 2 additional threaded connections on to the Cruise Control Module (which is usually found on the Fenderwell in the engine compartment)
Jan 09, 2015 | GMC Cars & Trucks
I have a noisy pedal. I have undone the lock nut on the pedal shaft, but the shaft/bearings doe not come out easily. Is there any tricks to pull out the screw shaft from the pedal housing?
Beneath the locknut is a washer with a tang that has to be removed. Beneath the washer is the threaded cone which can be removed with a socket wrench.
Aug 20, 2014 | Campagnolo Pd-Re110 Pedal Top Plates For...
The thread for the top needle just sews and loops onto the lower thread
I think you are saying that there is a loop showing on the bottom of the lower thread stitch. If the lower stitch looks correct and not bunching, you will need to change the tension on the upper stitch. Make sure that your threads are firmly inserted within the discs also before adjusting the tension. It doesn't take much to change the tension so take it slowly.
Dec 31, 2013 | Sewing Machines
Trying to buy a Replacement Bottom Bracket. Need to know whether to buy english or italian Thread
Not to state the obvious, but it really depends on the type of bike you have. If it is any standard mountain bike, most likely will have english threads.
Mar 26, 2011 | Cycling
Are ALL Colnago bottom brackets 'Italian' thread? Or do they also offer English, too? Thanks
Yes, everything is metric on all bikes, our country does not make bike parts anymore. Get a good set from a top bike shop, bottom bracket tools etc because you need quality tools not junk. It is well worth the investment if you know what you are doing, always remember it is far cheaper to take it in for repair than crossthreading something, then it is big bucks to fix.
Aug 27, 2010 | Cycling
VW alternator won't fit on brackets on engine
You need to widen the gap between the tabs. This will allow the alternator to slip over the bracket much easier. Get a socket big enough to allow the threaded insert to be driven inside it. (18/19mm) Then thread the bolt in a few threads and give the bolt a few taps with a hammer until the threaded insert moves about 1/8" or so. This will allow the alternator to fit easily in the bracket and the insert will be pulled back in as the bolt is tightened.
Aug 29, 2008 | 2003 Volkswagen Golf
Cycling Logo
79 people viewed this question
Top Campagnolo Cycling Experts
Michial Gueffroy
jimmarmor_ma
Are you a Campagnolo Cycling Expert? Answer questions, earn points and help others
