Question about Western Digital Essential NetCenter WDXE3200JB 320 GB USB 2.0 Hard Drive
Windows cannot detect (find) the netcenter. blinking light. makes 4 clicking noises when started.
  • Western Digital Master
  • 27,725 Answers
The clicking noise is the reader arm jumping across platters on your hard drive you have a dirty hard remove the hard drive then give the hard drive a firm tap on the side to free the reader arm
all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again, sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
hope this helps
Posted on May 27, 2011
TV CUT OFF,CLICKING NOISE NOW & STANDBY BUTTON FLASHING
"Short circuit" protection section circuit detects a short circuit; most often with its main board; and shuts down the set immediately after switch ON; to prevent further damage to components. This is what happening with your TV. Contact any service technician.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Type in the brand name of your TV, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Mar 16, 2015 | Televison & Video
TV will not turn on-- clicking noise in the back
The power pack the the power cord goes into has gone bad and needs replaced, see manufacturer for service or parts.
Nov 15, 2007 | Panasonic PT-50LC13 50" Rear Projection...
Sharp lcd tv.lc45gd4u no power red light blinking two times pauses then repeats
Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 1200 posts to different brand TVs now. Pull up older posts there. Blinking codes to so many brand TVs are described in detail here.
Nov 12, 2012 | Televison & Video
I have Windows 7 Build 7600. My Gateway NV5814 laptop doesn't connect to the internate post a windows update. The Ethernet cable is plugged into the NIC port but the blue and green lights do not blink and...
hi
Please disable windows update. Click on start , click on run type services.msc and click ok locate windows update , double click on it , click on stop and change the startup type as disabled . Click on apply and reboot .
Nov 18, 2010 | Gateway Computers & Internet
My Sony KDS-60A2000 is 41/2 years old. About 2 weeks ago I could not get the tv to power up. the green stand by light just kept blinking. I powered off, then powered up again and the tv started and and...
TV needs lamp replacement as existing lamp got weak or has been reached to end of its working life, please note that lamp is not dead or broken so that is why lamp lit is not lit at tv front.
Hope these info will help you.
Thanks.
Nov 03, 2010 | Sony KDS-60A2000 60" HDTV
1999 Carrera 4 hasn't been driven for about one month. Now it won't start but you can hear this clicking noise from the back. Lights, windows and radio all work. Any suggestions? Thanks.
Make sure your battery is fully charged and all battery connections are clean and tight. If the vehicle still makes the clicking noise when you try to start it, then it is your starter solenoid.
Feb 23, 2010 | 1999 Porsche 911 Carrera
It makes a clicking noise when starting. What causes this and is there a remedy?
I think your drive is failing. There is a hard drive inside of that and the arm is loose. It probably won't read files correctly very much longer if it still can. You need get get your files off of there before you loose them. If you're having trouble reading drive, put it in the freezer. When it's good and frozen plug it back into computer and copy fast. The cold will contract the metal and make the arm work again for a shot time. It should still be on warranty but get your files off fast before it fails.
Dec 06, 2009 | Western Digital Essential NetCenter...
2006 Dodge Caravan Engine Light Blinks 10 Times & wont start
It sounds like your starter needs cleaned or replaced. The poping noise could be the actuator not engaging right. As for the engine light, it could be just a coincidence.
Jun 23, 2009 | 2006 Dodge Caravan
External USB drive making clicking noise - Windows does not recognize it!
it is going to crash soon as the platter seems to broken it is non repairable yes but u can save the data by taking help of any good tech
May 19, 2008 | LaCie External USB 2.0 500GB 7200 RPM 500...
Western Digital Essential NetCenter WDXE3200JB 320 GB USB 2.0 Hard Drive Logo
267 people viewed this question
Top Western Digital Computers & Internet Experts
Marcin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
