Question about Samsung Computers & Internet
THE FOLLOWING HARD DISKS ARE REPORTING FAILURE SAMSUNGHM250HI.. IS THERE ANYTHING I CAN DO?
  • Samsung Master
  • 27,725 Answers
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your "((MOTHERBOARD TO YOUR HARD DRIVE))" make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error even something as small as a faulty electrical extension or fan lead can cause this problem another possible reason could be a memory dump you might be running to many programs at the one time placing to much strain on the CPU also you might not have enough RAM random access memory to check what is running when your computer is running scroll to the bottom toolbar right click select task manager applications and processes if you see something you dont need running select end now to check how much ram you have click start right click on my computer select properties you will see all of your computers details another way to check how much RAM you have click start all programs accessories system tools system imformation all of your computers imformation will be there try uninstalling a few unnecessary programs then click start run type cmd then type chkdsk/r/f which will scan for and attempt to fix any bad sectors and automatically fix any corrupt files on your hard drive this will schedule on a restart don
Posted on May 27, 2011
There is a popup message frequently stating taht "Windows detected a hard disk problem. backup your files immediately to prevent information loss, and then contact the computer manufacturer to determine if...
Click on "Start". Click on "Computer" Right click on "C" drive. Click on "Properties at bottom of menu. Click on "Tools" Click on 1st of 3 options available, check both boxes to scan complete hard disc, this will run a 5 stage correction program upon reboot.
Dec 18, 2012 | Toshiba Satellite L505D-S5983,...
Windows has detected a hard disk problem
you could run the chkdsk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to recovery any bad sectors and automatically fix any corrupt files on your hard drive there are many ways of running the chkdsk utility
click start right click on my computer you should see your drive usually C: select properties click tools check now tick both boxes automatically fix files and scan for and attempt recovery on any bad sectors or you could tick one box and wait until its finished then return and tick the other box
then select check now,start should schedule this task when restart
it will only schedule on restart if its the Primary hard drive with an operating system on it
do not do anything while the chkdsk utility is in progress any input may damage your computer
hope it helps
Apr 14, 2012 | Samsung SpinPoint M8 HNM500MBB 25in 500GB...
Why is my brand new laptop satellite c655d-s5529 keep on saying toshiba mq01abd032 sata disk device the following hard disk are reporting failure
Take the laptop back "asp" you should not be getting messages on the screen, it indicates device issue and maybe a bigger problem.
Mar 07, 2012 | Toshiba Satellite C655D-S5120 Notebook
I have an ACER Aspire 5542 laptop and when I switch on I get the following message. "SMART Failure Predicted on Hard Disk 4 WARNING: Immediately back up your data and replace your hard disk drive....
Save your data asap and replace the drive it's failing. All drives fail over time you are lucky in that you are getting a notice. Others are not as fortunate.
Aug 30, 2011 | Western Digital (WD6400BEVT) 640 GB SATA...
My acer aspire one has a hard drive failure on the following disks IDE/SATA.I diagnosed it then got the following report. HDD doesn't respond to system commands Boot sector damaged read time...
You need to format your hard disk. Please note that formatting will erase all you data from the hard disk and all the software including the Operating system.
If you have your OS master CD you can insert it in the cd/dvd drive and restart the laptop. This will detect the OS CD and try to install it. In the installation process there is an option "Format your hard drive". You should select that option. Then it will format, mark the bad sectors, create a new boot sector and install the OS. You will be just fine.
Aug 03, 2011 | Acer Aspire One PC Notebook
I received the following error on my HP Pavilion laptop: SMART Failure Predicted on Hard Disk 4: WDC WD2500BEVS-60UST0-(S1) Warning: Immediately back-up your data and replace your hard disk drive. A...
SMART is used to measure your HDD health.It warns you of impending failure of your hard drive. If it goes down, it's a good idea to backup important stuff and prepare to replace the HDD.
S.M.A.R.T is an acronym for Self-Monitoring, Analysis and Reporting Technology systems (SMART) and it's usually built in to most modern ATA and SCSI hard disks.
If you need further assistance, feel free to ask. If this answers or solves your issue, please rate it. Thanks, Joe
Feb 09, 2011 | HP Computers & Internet
SMART Hard Dish Error is placed on my screen
S.M.A.R.T. (Self-Monitoring, Analysis, and Reporting Technology; sometimes written as SMART) is a monitoring system for computerhard disk drives to detect and report on various indicators of reliability, in the hope of anticipating failures.
When a failure is anticipated by S.M.A.R.T., the drive is typically replaced and returned to the manufacturer, who uses these failed drives to discover where faults lie and how to prevent them from recurring on the next generation of hard disk drives.
Dec 23, 2010 | Computers & Internet
My averatec booting problem
The SMART is the monitoring system that is embedded in all hard disks - if it reports a failure it means that the hard disk has died. You need to replace the disk and only after that you can reinstall.
Jul 10, 2010 | Averatec 3200 Notebook
MY HARD DISK HAS EXPERIENCED A PROBLEM I CANT INSTALL THE OPERATING SYSTEM. I GET AN ERROR SAYING DISK FAILURE AND ITS DOWN NOW I CANT DO ANYTHING
Disk failure = the hard disk has a hardware failure = it's dead. It can't be fixed, replace it and reinstall.
Apr 15, 2010 | Toshiba Tecra A3 Notebook
Hard Disk Problem
That failure is predicted by the SMART reporting system. Its a status chip on the drive that reports to apps that can read the smart data from the hard drive. Its not always accurate but it usually is.
Time backup your data on that drive ASAP and then buy a new drive.
Sep 07, 2009 | Toshiba MK1637GSX 160 GB IDE Hard Drive
Computers & Internet Logo
378 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
