Question about Roland Microcube Guitar Amplifier
Microcube volume kind of goes up and down itself. It is noticed when playing long notes, volume goes almost off and in next second it is ok. Any hints where to start fix the problem. another problem is that I have repairing skills based on roadeitape and hammer.
  • 140 Answers
First clean the controlls, then check for any loose components
Posted on May 27, 2011
When playing the volume goes in and out (meaning it will just go louder or softer randomly). Have no service center in my state and need help with this.
I would try cleaning the jacks and the input volume pots as a starting point. You can always remove the electronics and ship them to a service center. If it's not in warranty, you can just take it to any local repair shop.
Aug 09, 2015 | Behringer Ultratone K3000fx 300w Keyboard...
The volume on my "Clavinova" keeps rising and falling for no reason.
The most common cause is damage to the volume potentiometer.
Replace it.
Mar 15, 2015 | Music
Subwoofer ain't doing anything on peavey triflex
Could be a few issues. If it is powered up when you plug it in, it might have a short circuit protection that shuts it down, or a thermal overload that is over sensitive. It might also be an issue with the cable you are using to connect it, from a broken wire to one that has a plug just slightly too long- there are 5 different tip lengths.
This also assumes the input itself is not being over driven, and that the output is not shorting out either..
Jun 10, 2012 | Music
I have a priva PX-410R, when I turned it on today just one of the keys is playing at full volume like I was pressing the key really hard. The rest of the keys are playing normally. If I put it on say a...
Each key has two contacts. One closes first and then the other. This allows the processor to measure the key velocity which is then used to control volume. The key contacts are conductive rubber "pills" pressed onto circuit board traces. Clean them ONLY with 99% isoprophyl alcohol and Q tips. The disassembly of the unit to access these is NOT for the inexperienced so you might want to take it to a repir shop. Here is a service manual for a Casio 811 which is totally different packaging than yours, HOWEVER the keyboard itself will be similar and you will get an idea what is involved with getting into one of these things:
http://elektrotanya.com/casio_ctk_811_ex.pdf/download.html
Scroll down to "get manual" and click to download... IGNORE other download links.
The keyboard exploded view is around page 32 in this manual.
Aug 03, 2011 | Music
After playing for a while, approx 15 min, the volume dies away leaving some sound but greatly reduced. It then gradually returns to normal volume after about 3 mins. Otherwise all other functions seem to...
Such a long delay and a slow return to volume is puzzling. If the return came back in say 30 seconds, I would suspect 1/2 of the V1 tube (12AX7) might have a failure of the heater. When it has failed see if this tube has TWO points of light in it. The cooling down and warm up would give a 15 second ramp up or down in volume. This tube has a path around it that would sustain a very low volume. Try swapping one of the other 12AX7's into this spot. If the sound totally goes away replace the one that was in V1 at first place and see if problem goes away.
Mar 29, 2011 | Peavey Delta Blues 115 30w All Tube Combo...
Ok, i love the tones on this amp, but for some reason, i start to play, not even on at a high volume, just like at a nice level, ill play it for like 5-8 mins and it will shut off, like the power is still...
This is a tiny amp good for practice at low volume levels. You are likely overdriving it and the power amp chip goes into thermal protect. If you volume level is much louder than a small boom box, you are driving it too hard. Best to get a bigger amp.
Jan 26, 2011 | Line 6 Spider Iii 15 Modeling Guitar...
Fender Hot Rod Deluxe Volume Fluctuations. My amp (fender hot rod deluxe) will occasionally have volume fluctuations when I'm playing. The changes usually occur when I've moved my setup from one place...
First thing would be try another guitar with the amp. This will eliminate if it's a problem with the guitar or the amp itself. If the guitar is working properly then check all the tubes to be sure they are all seated into there slots completely. Depending on how much use they have been played it may be a good suggestion to then replace your tube's. Occationally the tubes will start loosing power, making sound fluctuate up and down or distortion sounding static in background noise. You will notice a big difference with newer tube. But remember the bias must be set correctly to match the new tubes so they won't over heat. You can check out youtube for setting the bias. Anyway this is my suggestion and I wish you good luck.
Jan 18, 2011 | Fender Hot Rod Deluxe Guitar Combo...
When playing on the metal channel the guitar will go clean then back to distortion then clean. When it goes clean the volume drops way down. Any suggestions?
Tha might be a cold solder joint, if you can access the Printed Circuit Board, try hitting it with the handle of a screwdriver in various zones. If you notice the problem comes and goes while doing this, then your'e close to the zone where resoldering is needed.
Dec 10, 2010 | Line 6 Spider Iii 15 Modeling Guitar...
My granddaughter has the Disney Hannah Montana Keyboard but we cannot find the instructions for it.
Try the live chat feature here:http://disneyinteractivestudios.custhelp.com/app/answers/detail/a_id/3192 or try here: http://www.jakks.com/customer-service JAKKS apparently is the company that manufactured them.
Oct 29, 2009 | Music
Yamaha 88 key piano grand plays wrong pitches w/ changing volume
If it has a sequencer/ recorder built in, you have the ability to change the pitch/ detune by using some key strokes after initiating the program mode. If your not sure how to do that, try unplugging the keyboard for thirty seconds and push the power button while it's unplugged, then plug it back in. Any better? What model is it.
Jan 01, 2018 | Yamaha Full-Size Keyboard
Roland Microcube Guitar Amplifier Logo
Top Roland Music Experts
Michial Gueffroy
Alex McGaughan
Alex McGaughan
Level 1 Expert
Are you a Roland Music Expert? Answer questions, earn points and help others
