Question about Health & Beauty
MY GoGo Scooter beeps 5 times when i put the key in and it wont go?
wcdoc1953
  • 278 Answers
SOURCE: when I turn the key
The beep code will begin with 10 very fast beeps, followed by 5 slower beeps. The 5 slower beeps is your actual code. The beep code 5 is a brake fault.
The scooter may be in freewheel mode or there may be a short in the brake.
Make sure the scooter is in drive mode with the rear brake lever in the correct position. If that does not clear the fault you need to check the electromagnetic brake.
To check the brake you need a digital voltmeter. The brake should read 30 to 65 ohms when you read across the pins. You need to measure the resistance at each successive point on the harness because there are 5 connectors. While you are inspecting these plugs, check for corrosion, loose pins, broken wires, and pins not making good contact. Disassemble the front and rear halves of the scooter when you do this.
If all the resistance checks are good up to the controller plug for the brake, you have a bad controller. With that being said, I usually see a bad connection at the multiple points in-between. Sometimes the wires for the brake will melt at the connector at the controller.
Inspect these areas visually, removing the rear cover of the brake/motor/transaxle and the controller. An experienced tech should charge you under 1 hour labor for the diagnosis. You may be able to save some money by checking the obvious areas for unplugged or bad connections first.
The brake will cost about $250, the interface wiring and connectors about $50 and the controller is about $500. For this reason, you should invest in a good tech to diagnose the problem first, before proceeding with any hit and miss do it yourself repairs.
Including a second visit to install the new parts, labor cost should not exceed 2 hours total.
This is a very popular model so you should be able to find an experienced tech in your area.
Posted on Dec 23, 2010
Testimonial: "Awesome detailed info on how to fis/diagnose the problem."
gewiz
  • 1263 Answers
SOURCE: PRIDE GOGO ULTRA X Beeps and Cuts off
Please make sure your charger is okay, can you try another charger ?
the other thing is , the FREEWHEEL lever can it move itself say when you go down a kerb , what are they replacing ? do you have the part ? send me a photograph if you do ?
Posted on Jun 13, 2009
  • 177 Answers
SOURCE: The Pride GoGo 4 wheel scooter does not move
Hi. How many beeps between pauses? This is a fault code.
A couple of problems might cause this fault. Is your free-wheel lever in the correct place. These levers operate a switch, that tells the controller that the brake is disabled, this stops the controller from driving the scooter with out brakes.
Might also be caused by a stuck brush in the motor. This is usually caused by the caps that hold the brushes in, not being tight enough. Check the brushes, make sure they slide in and out smoothly, retighten the caps. Be carefull because these caps can crack easily.
Good luck. Neil.
Posted on Jun 12, 2010
wcdoc1953
  • 278 Answers
SOURCE: I HAVE A PRIDE 3
Hi Fred,
Good job on replacing the batteries!
With the go go scooter, a beep code of 5 indicates a solenoid brake trip. This means that the brake manual/freewheel lever may be in the freewheel position. This means that you can push the scooter. Remove the key and push the freewheel lever to the drive position. Restart the scooter and the code should be cleared and the scooter will run. Hope this helps.
Posted on Jan 20, 2011
  • 50 Answers
SOURCE: l when i have used
Hi lindatuxford
I have owned my own business for 3 years and have been working on scooters and powerchairs for 15 years.
1. Sounds like a brake problem. Here is the test. Run your scooter until it stops. Being careful not to get burned. Touch the brake attached to the free wheel lever and trans axle. If you have a bad brake it will be very hot, don't get burned. If the brake is cool, then thats not your problem.
2. Bad batteris can also have the same results as you describe.
3. Pull out the battery box out, Wire brush all connectors and replace the velcro on the bottom of the box. Sometime the box can jump out and stop your scooter and beep your horn.
Good Luck
Tim
Posted on May 02, 2011
We just changed batteries. When we put the key in, there are 5 beeps and nothing will move.We have pushed the brake lever on the back forward and still nothing.
Hi I have no data on the go go ...if the circuitry is similar to pride x the 5 beeps mean the manual lever is in freewheel u have to remove key put freewheel lever in drive & replace key good luck
Jan 20, 2016 | Pride GoGo Elite Traveller 12amp Mobility...
Battries fully charged, turn key on and only beeps 5 times. Thats all.
hi Hal, that is a issue around based the brake or connectors to the brake or the micro-switch that is moved when you move the drive , freewheel lever.. ... firstly make sure the scooter is in drive mode and not free-wheel mode ., where the axle comes apart you will see a number of connectors , make sure they are a good fit ...
Update me please...
Regards
Rob
Oct 29, 2015 | Pride Mobility Products GoGo Ultra X...
Wts gogo scooter just keeps beeping whenu switch it on whats that mean
this could mean the scooter is not in drive try the free wheel lever first.
Feb 25, 2015 | Pride Mobility Products GoGo Elite...
My gogo ultra is showing fully charged and horn beeps, when i put key in it beeps fast 10 times and 5 beeps after
5 beeps usually means scooter is out of gear, but since the lever is in the drive position and the scooter gearbox/differential is engaged, it seems that the controller is not sensing the gear change. Possibly a faulty micro switch in the motor housing can be the cause of this, usually the micro switch is pressed down by the drive lever and if the switch is pressed down the motor controller knows the scooter is in gear.
Feb 11, 2015 | Pride Mobility Products GoGo Ultra X...
My battery is fully charged but my scooter wont go?
hi, how many bleeps before a pause ? or is it constant bleeping ?
This error can be caused by a bad connection , check where the back end comes away from the frame...
Regards
Rob
www.gewizrepairs.co.uk
Aug 17, 2014 | Pride Mobility Products GoGo Elite...
Why does it beep five times when key is turned on and controls won't work
hi, the 5 bleeps are related to the brake,,, located at the rear of the scooter located on the side of the motor, attached to that is the free wheel lever,, in drive mode ,, check that the microswitch is working correctly, check the wire( connectors etc ) from the brake to the controller ,
www.facebook.com/gewizrepairs
Aug 07, 2014 | Pride Mobility Products GoGo Elite...
Beep codes beeps
Contact a local DME dealer in your area or, on the internet. Give them your serial number for the GOGO to order a new solenoid brake. It is important to have your serial number when ordering to ensure you get the correct part.
Jun 07, 2014 | Pride Mobility Products GoGo Elite...
Solenoid brake trip code
first of all take a look at the microswitch connected to the brake, these can fail, check the connections from the axle to the frame they are a great source of problems...
Regards
Nov 15, 2013 | Pride Mobility Products GoGo Elite...
I HAVE A PRIDE 3 WHEEL GOGO SCOOTER. THE BATTERIES WENT DEAD. I REPLACED THEM AND CHARGED THEM UP. NOW I GET A 5 BEEP CODE WHEN I TRY TO START. IS THERE A LIST OF WHAT EACH CODE IS? THANKS FOR YOUR...
Hi Fred,
Jan 19, 2011 | Pride Mobility Products Go Go Ultra X 3...
Health & Beauty Logo
964 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
