Question about Microsoft Windows XP Professional for PC
I get ''SQLDUMPER LIbrary failed initialization'' when i start the computer
    Problem Solver:
  • 5 Answers
SQLDUMPER is an accessory for Microsoft SQL Server that will allow you to track down problems with MSSQL. There's no need for it on your system if you're not using SQL Server.
Using Control Panel, select [Add or Remove Programs], then select the [Microsoft SQL Server] program and click on the remove button.
If you want to reinstall it, you can go to MSDN.microsoft.com and get a new copy, but if you're not using it and no programs you are using are, there's no reason to have it.
Posted on May 26, 2011
Hp portable drive not initialized
You must be logged on as an administrator to perform these steps.
Windows typically assigns a letter of the alphabet to most drives.
If you want to organize your drives in a certain way, you can change the drive letter.
You can assign any letter to a drive as long as long as the letter isn't already in use by a different drive.
To see which drive letters are in use
Open Computer by clicking the Start button, and then clicking Computer.
Open Computer Management by clicking the Start button clicking Control Panel, clicking System and Security, clicking Administrative Tools, and then double-clicking Computer Management.
If you're prompted for an administrator password or confirmation, type the password or provide confirmation.
In the left pane, click Disk Management.
Right-click the drive that you want to change, and then click Change Drive Letter and Paths.
Do one of the following:
To assign a drive letter if one has not already been assigned, click Add, click the letter that you want to use, and then click OK.
To change a drive letter, click Change, click Assign the following drive letter, click the letter that you want to use, and then click OK.
To remove a drive letter, click Remove, and then click Yes to confirm that you want to remove it.
Initialize New Disks
http://technet.microsoft.com/en-us/library/cc771486.aspx
also
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
hope this helps
Aug 03, 2012 | HP Computers & Internet
Barcode Scanner stopped scanning
These devices do fail, so that is most likely what has happened here.
Apr 13, 2017 | Honeywell 3820 Wireless Handheld Barcode...
Web user interface timeout please log in again message over and over even after I log out and try to log back in
This may be caused by a bus level communication problem, try a restart. Power down the computer, power down the library, power up the library, wait for the library to finish initialization and verify from the control panel it is in an online/ready state, power up the computer.
Jan 12, 2011 | IBM System Storage TS3200 Tape Library...
When booting the system the following error message appears: SQLDUMPER failed initialization
the uninstall tool vs_uninst.exe located at http://download.microsoft.com/download/0/a/a/0aacd9c1-a0c5-43ab-a428-0ee440d4472c/vs_uninst.exe.
this error usually occurs when removing certain Microsoft products, or when using the SQL server. Here is a few articles which may help you correct your issue. First, it is a forum where an individual has a similar issue, and the help offered:
http://www.sqlteam.com/forums/topic.asp?...
Next, a Microsoft Knowledge base article on the SQL sqldumper utility, and some troubleshooting techneques:
http://support.microsoft.com/kb/827690
The next page is the SQL tech support and has different errors which can be generated. Look down the list and see if you can locate your particular error and when/how it occurs:
For SQL 2000:
http://www.gridview.org/kb/SQL2000/defau...
For SQL 2005:
http://www.gridview.org/kb/SQL2005/SQLSe...
May 13, 2009 | Microsoft Windows XP Professional for PC
I get I get SQLDUMPER LIbrary failed initialization
SQLDumper is used to collect stack information and debug information in case SQL Server crashes. The dump that is created out of this is normally send to Microsoft and is used by the development team to debug problems (not that you can elect not to send this information to Microsoft).
The error above means that likely your SQL Server installation is corrupt, so I would suggest that you reinstall SQLServer.
Apr 14, 2009 | Microsoft Windows XP Professional for PC
Computer error code
it is because of missing some dll files .that are the library files of windows.so you reinstall your OS
Mar 12, 2009 | Computers & Internet
Initialization failed
You need to uninstall and Reinstall the particular game.. or try system restore for quick resolution
Feb 03, 2009 | Microsoft Windows 98 for PC
Lib 81-AIT4 LCD message initizalizing Drive
tape drives is failure or the library can't find the tape drives. regards
Dec 04, 2008 | Sony (LIB81A3BB) AIT-3 Tape Drive
Microsoft Windows XP Professional for PC Logo
83 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
