Question about American DJ Supply American DJ Emerald Sky Green Laser (Standard)
I have two American DJ Emerald Scans. One of the lasers is not as bright as the other. What can I do to fix the problem?
  • American DJ Master
  • 5,603 Answers
Often mirror adjustments get knocked out of alignment. Open and check for this. Carefull of eyes from laser.
Posted on May 29, 2011
Power comes on, but the lights dont
I can ONLY give you suggestion.... Note that most of the high power laser devices have safety interlocks to insure the beam is moving before turning laser on. Verify any dip switch settings to make sure they are in a suitable mode. If the laser comes on during test, ASSUME that a setting is wrong. I do not have this unit so my suggestion is general based on experience with other devices.
Nov 30, 2012 | American DJ Supply Galaxian Royale LED...
I have an American DJ Hyper Gem LED light and have used it at 4-5 dances...its okay in small halls, but I have a friend that also bought one and his is super bright and throws the effect far, mine does...
Uncover it... you will probably find that some of the LED's are not lighting. OFTEN soldering on circuit boards OR a bad LED in a string kills several like Christmas strings. More than this you need to be somewaht adept at electronics to repair it.
Jul 02, 2011 | American Dj Hyper Gem Led 4way Led...
Hi there, I have an american DJ Dekker LED. I plugged it in and put it into Sound active / sound to light mode. I'm getting response to sound because I can hear and see the fan inside the unit...
I have OFTEN found that a cable has come loose. Open the unit and look for such a situation. Also make sure the motion (probably a disc) is working/rotating since with high power LED devices, they have interlocks for safety to keep beams moving.
Jun 24, 2011 | American DJ Supply American Dj Dekker Led...
I am having trouble running an american dj quad gem in dmx mode. I have other lights that are working fine.
If by chance teh light is on the end of a long DMX cable run, read about putting a terminating resistor at the end of the chain. You say you are having "trouble"... that doesn't tell us anything that we could help you with.
Apr 23, 2011 | American DJ Supply American Dj Quad Gem...
Parts for american dj tri phase no sound attvation mic is fine
Usual problem is unit hasn't been put into sound activation mode. Make sure the display says:
"SOUn" and select the "on" in that mode.
Mar 17, 2011 | American DJ Tri Phase Led Lighting Dmx...
American dj mini fog, I conected to wall, but the machine doesn't gets hot, and not make smoke, why?
There are two switches/buttons on top... You have to both turn on the unit and also activate it with the second button OR using a remote plugin box. The heater takes a bit of time to warm up internally. You will not sense much if any heat outside the unit... They take a few minutes to come on. Make sure you use approved "fog juice" in the unit.
Dec 18, 2010 | American DJ Mini-fog - 450 Watt Fogger Dj...
DJ LIGHTS
MOST DJ lights are not protected to be used outside in weather.
Other considerations are visibility from highways and also aircraft. Certain lights could cause a problem for these two scenarios.
When outside, often the distances are longer and the light drops off as the square of the distance.
Laser types require fog to get the effect and there really isn't a way short of getting the weather to cooperate and give you fog to get those effects.
Between the laws of physics and the construction of lighting intended for interior use, what you are asking for is just not easily obtained.
The inability to control ambient lighting outside is a real problem. Many of the DJ things require a fairly darkened room. The sky glow from a city is enough to kill off the effects.
May 19, 2010 | American DJ Flash Beam Lighting Effect
American DJ Supply American DJ Emerald Sky Green Laser (Standard) Logo
226 people viewed this question
Top American DJ Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you an American DJ Music Expert? Answer questions, earn points and help others
