Question about Panasonic DMC-TZ4 Digital Camera
My TZ4 lumix suddenly went dead.It just does not respond...Ive tried new batteries.Its in good condition.The lenscap is shut etc everything appears perfect but its dead
Obertelli
  • 3006 Answers
SOURCE: Panasonic Lumix DMC-TZ4 black - memory card locked
Remove the SD card and slide the lock switch on it to the unlocked position. If it's already there then slide it fully to locked and then fully back again.
If this fails then you need to try another SD card to see whether it's a camera fault. If the camera is at fault then there's nothing more you can do other than to return the camera to Panasonic for repair.
Posted on Nov 28, 2009
  • 13433 Answers
SOURCE: Lumix DMC TZ4 lens cover
Hi could you clarify, the plastic doors in front of the lens are stuck half open, but the lens has retracted inside the camera or is the lens in half open position outside of the camera.
Posted on Nov 07, 2010
leecom72
  • 4806 Answers
SOURCE: How can I get a
Click on the link below for the camera's manual. To save the manual to your computer click on the save icon on the top left of the page once the PDF has loaded up.
http://service.us.panasonic.com/OPERMANPDF/DMCTZ4.PDF
Regards.
Posted on Dec 23, 2010
Testimonial: "Speedy, efficient and RIGHT! Thanks"
BillB-SA
  • 2761 Answers
SOURCE: Hello I have a panasonic DMC-TZ4 digital
You can download and print your camera manual, at no cost, here:
http://www.brynmawr.edu/llc/documents/DMCTZ4.pdf
Posted on Apr 22, 2011
Obertelli
  • 3006 Answers
SOURCE: After several years of heavy
Your camera almost certainly has a lens error, this is such a common fault that I hope you don't mind me pasting my stock generic answer below. No point in reinventing the wheel! If your camera has had several years of heavy use and has been dropped at least a dozen times, it's probably time to accept that it's worn out and beyond repair. But what follows costs nothing to try.
Stuck lenses are probably the most common reason that compact digital cameras get thrown away, but there's a fair chance of recovering use of your camera again
The fault is commonly caused by dirt or grit blocking the mechanism, or due to it having suffered a recent fall. Another common cause is that the camera was in a pocket or bag and the power button accidentally activated and tried to open the lens against resistance. The mechanism may have simply become dislodged or there may be parts which have broken.
If your camera is still under warranty and has definitely not been subject to misuse then contact the Panasonic service department in your country to find out about a free repair. If the warranty has expired though a professional repair will far exceed the cost of replacing your camera. You will therefore have nothing to lose by trying to fix this yourself.
Please click here and you will be taken to an excellent article provided by the Camera Repair website. For the most part, you'll be guided on how to physically manipulate your camera to try and clear the fault. Although the article mentions Canon a few times, the advice applies equally to all cameras with lens errors and is not model-specific.
If the link doesn't work then cut and paste the following address into your browser:-
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Good luck, I hope you manage to use this information to fix your camera, or at least are able to use the information to help decide whether to buy another camera. If you do decide that you have to throw your camera away then don't forget to remove the memory card as it can be used in other devices. Please take a moment to rate the free answer I have provided for you and any testimonial which you might wish to add is always welcome.
Posted on Jun 28, 2011
Headlights do not go off so battery went dead. Also dome light does not respond to drivers door
Never rely on the door switch to shut off the lights.
That is always an extremely unreliable system on any car.
Whenever you shut a car off, turn off everything. That includes radio, AC, fan, etc. Otherwise you are putting a great strain on your battery when you next try to start it.
Jun 18, 2012 | 2001 Toyota 4Runner
Camera won't turn on
this is happening when the batteries are not well charged or if they are normal batteries they are not powerfull enough to open it ..so ..you will need wither a new battery that holds the power well ..or if uses like I said normal batteries..buy a few good alkaline ones and try to power it ...cause those cameras are sensitive when it gets to power and amperage ..so it need real good batteries..not cheap ones cause those will not power it ..but just came up says battery low ..and shut down ..Ive been there with a simple Lumix(panasonic) and had the same problem ...since I use only duracell it work s..
May 29, 2010 | Sony Cyber-shot DSC-S600 Digital Camera
My batteries went dead and camera shut off. Now I
if the camera wont turn on remove the memory card and make sure your pictures are transfered. Try using regular disposable batteries. Also when trying to turn it on try holding down the power button for 5 seconds. If it still doesnt turn on coud be a broken switch connection.
May 14, 2010 | Canon PowerShot A540 Digital Camera
Lumix DMC-tz4 Camera will not turn on . Battery appears to be charged, get just over 4 volts on multimeter. Any suggestions
Hello :
I recommend you to put a new battery , because it seems that your battery life is ended . When battery life is ended it can't be recharged any more . Maybe it shows some volts but there will not be any current flow in it .
Check the cords and the charger also please , just to be sure that they are fine .
good luck .
rate please !
Mar 19, 2010 | Panasonic Cameras
Nov 28, 2009 | Panasonic Lumix DMC-FZ18K Digital Camera
Like dotball said, It looks to me like the batteries have gone dead. First charge the batteries and if that doesn't solve the problem, try new batteries.
Feb 06, 2009 | Panasonic Lumix DMC-FZ20 Digital Camera
Panasonic lumix -fx01 digicam isnt responding
After posting on here I took my FX01 to a repair centre and was informed the motherboard had died. They couldn't give a specific reason for this, saying it could be anything relating to humidity, extreme temperatures, static, even just a slight knock, etc. Cost of repair was higher than purchase of a new camera so I grudgingly went for that option. I hope you guys have better luck!
Nov 14, 2007 | Panasonic Lumix DMC-FX01 Digital Camera
Panasonic DMC-TZ4 Digital Camera Logo
37 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
