I have a ts-5545 mitzubishi tv....i get sound..but nothing at all visually....can u help?
  • 2 more comments
  • DaCiple May 27, 2011
    the problem is w the tv. there is absolutely nothing visual..not even a backlight or input/channel indicator.
  • DaCiple May 30, 2011
    i dont know. how can i find out?
    its crt
  • DaCiple Jun 11, 2011
    sorry it has takin me so long t reply....i pluggd it in when i saw ur reply and it (th tv) came on..and has been workin since....but before that there were no lights frm th tubes at all....its just a matter of time before it quits again tho....it has done this before
  • 517 Answers
Good day!
If you have back light but no pictures try to play a dvd or recorded shows to determine the problem.
when the problem persist when you play dvd or recorded show the problem is in your Tv.
when the picture is in when the dvd or recorded show plays the problem is in your cable/aerial connection.
please try this first step and add a comment for any question
Posted on May 26, 2011
  • 1 more comment
  • Rossiel Gomez May 28, 2011
    may i know if your projection tv is crt or DLP?
    thank you
  • Rossiel Gomez May 30, 2011
    Please look inside. If you have three picture tubes inside the screen it means your TV is a CRT type, If your Tv don't have it then your TV is a DLP type Please reply thanks...
  • Rossiel Gomez May 31, 2011
    try to see the CRT tube if have a light.
    i need to know to start troubleshooting
Mitsubishi ts-5545, Black screen and Heart beat
A couple of things:
1) Either a bad power supply or a flyback 'supplies the high voltage to the 3 CRT's' .
2) The HOT 'High Output Transistor' is gone bad or the leads 'solder joints' have cracked and are not making a good connection.
time to get it into the shop or have a tech come to your residence to look at it.
Good possibility of getting it fixed.
A/V Media Guy
Nov 22, 2009 | Mitsubishi TS-5545 55" Rear Projection...
Turns itself off immediatley after turned on
mitsubishi projection TV turns off by itself after a couple minuts of viewing TV?
WD-62527
Apr 28, 2009 | Mitsubishi TS-5545 55" Rear Projection...
Has sound but no picturemodel ts 5545 mitsubishi
You need a professional.
Stop using the TV until it is repaired.
Continue to use it and your problems will multiply and grow more expensive.
Call the manufacturer to find you nearest authorized service center.
MR. TV Sales & Service Inc
Milwaukee Wisconsin 53405
(414) 762-8600
Established 1974
Mar 24, 2009 | Mitsubishi TS-5545 55" Rear Projection...
Are you able to view the TV's onscreen display menu?  If not, you have a problem with a video board and service is required.  If the menu does appear, you will have to check the cable/wire connection and make sure it is snug and in the correct location.
Mitsubishi VS-5071 rear projection turns on, has audio but no video
That is a VZ3 chassis, similar to Mitsubishi models Ts-4545, Ts-5045, Ts-5545, Vs-4543, Vs-4544, Vs-5043, Vs-5044, Vs-5047, Vs-6043, Vs-6047 and has common failures in the vertical circuit, specifically vert Ic401 which is a La7845 which is usually caused by defective C402 100uf 50v and/or open 1.2 ohm 2 watt R510 next to FBT.
If not that check C268 off Q215 on signal board 22mf/50v and Ic200 on signal module Cxa2025s. However the vertical failure is more likely.
Bill
Sep 10, 2008 | Mitsubishi VS-5043 50" Rear Projection...
Try pushing in input and menu together and holding them in on the set for 5 seconds to se if the led blinks a code. hen let me know what the light blinks if anything.
Feb 22, 2008 | Televison & Video
Mitsubishi TS-5545
This is the VZ3 chassis. Solder joints are famous at the yoke plugs, flyback and horizontal drive transformer.The blue convergence is the Convergence ICs need replacing. I will try to locate a manual for you.
Feb 13, 2008 | Mitsubishi TS-5545 55" Rear Projection...
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
Electro Med Services...
