Question about LG Washing Machines
LG washer dryer WD1485RD showing error code FE. Will not stop pumping water into machine/ cannot finish the cycle
  • adeross Aug 16, 2008
    thank you, this sounds 100% correct.
  • Anonymous Mar 22, 2014
    what to press to drain the washer
  • LG Master
  • 19,396 Answers
Try first unplugging power cable for two minutes, this can clear error code if there is no real problem with your appliance.
Posted on Aug 16, 2008
  • Ginko
    Ginko Aug 16, 2008
    If error is not clearing after resetting the appliance by unplugging power, then it means there is a real problem.
    Code FE means there is a problem with water valves.
    When this happens you also usually have cycling problems.
    Water valves are relatively easy to locate and replace. Remove top panel
    and get access to the two valves.
    You need to find out which valve is faulty before ordering replacement.
    You can order replacement by inputting your model number here.
    An alternative solution is calling the LG number printed on last pages of your owner manual, and having your appliance repaired from a LG technician.
    Check also your guaranty terms, if appliance is still under guaranty contact LG.
Why on an LG Front loader does the FE code come on and not on Rinse & Spin?
Here is the LG site for washing machine error codes, you can scroll down and find the FE code there:
http://www.lg.com/us/support/product-help/CT10000010-20150140270078-other-error-codes
The site shows the following:
The FE error code indicates the washer is overfilling. This is usually the result of a faulty water valve.
1. Close both water taps.
2. In order to drain out any trapped water, power the washer back on and press the Spin Speed button until No Spin is selected and press the Start/Pause button.
3. Once the washer has drained, restart the wash cycle.
Jan 26, 2017 | LG Washing Machines
Front load washer LG wm2140cw with error code up side down FE. Any ideas what this means? Will start to run then error code shows up and it stops.
A tE error code on the display of the washer indicates a heating error, usually caused by a faulty thermistor.
  1. Unplug the washer from the power outlet for 10 seconds.
  2. Plug the washer back in and press the POWER button and then the SPIN SPEED button until No Spin is selected. Press the START/PAUSE button.
  4. If the tE error code appears again, close the water taps and unplug the washer. The washer will require repair service.
Apr 06, 2015 | LG Washing Machines
LG front load washing machine WM2233H Error code is FE
I found this information on the internet. I hope that it helps.
" Getting fe code on lg washer.
"This means that the washer is overflowing. This is a built in fault that turns on the drain pump so that the water doesn't get so high that it gets into the floor. If water is continually flowing into the washer you will get this problem. If this is the case the water valve is most likely the problem. To confirm unplug the washer and if the water doesn't stop flowing into the washer the water valve is the problem.
Thank you,
Shawn"
I hope that this helps you out
Apr 21, 2011 | LG WM2233H Front Load Stacked Washer /...
I have a LG washer model WM2487 H*M suddendly water started coming out from underneath and also the front panel shows a light saying FE....I read that means something about is due the faulty water...
FE = Fill Error. Not a faulty water valve in your case. (FE codes if it takes too long to fill the machine, but if the water is leaking out, the valve is not the problem, the leak is) If you take the back cover off, you might be able to see where the water is comming from. Possibly the black rubber hose from the tub to the pump has a leak.
Mar 17, 2011 | LG WM2487HWMA Front Load Stacked Washer /...
Error code FE
From the manual ,FE means Water level is too high due to a faulty water valve. hence the possible leak
Dec 22, 2009 | LG WM2277H Front Load Washer
Our LG model WM2032HW intermittently show up with th FE code what could be wrong and can it be fixed by us?
FE error code means water is overflowing. The water is over 8 level.When FE is displayed, the drain pump will operate to drain water automatically. Otherwise the pressure switch assembly is malfunctioning. Check and replace if necessary. Part number is 6600FA1704X.
The pressure switch assembly shuts off the water inlet valve when the desired water level is reached. It then activates the drain pump when the water inlet valve is not deactivated.
Oct 18, 2009 | LG 4.0 Cu. Ft. 7-Cycle Front-Load Washer -...
LG washing machine keeps stopping and it says OE
The LG error code OE simply means “the pump is blocked”. Presumably the water isn’t being emptied properly. Check the exit hose, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Apr 11, 2009 | LG WM2042 Front Load Washer
LG Sense Clean DD error code "FE" front loader washer/dryer combo
my lg senseclean wash mashine shows the sign Cl on the display and the door cannot be open what does it mean?
Jan 03, 2009 | LG 4.0 Cu. Ft. 7-Cycle Front-Load Washer -...
FE error?
But does anyone knows what FE means?
Mar 05, 2007 | LG WD-3274RHD Front Load Washer / Dryer
Washing Machines Logo
266 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
