Question about HP Pavilion A520n (DW233A#ABA) PC Desktop
Pavillion a520n overheats and reboots. Fan on CPU runs during boot up then shuts off. Starts again when reboot occurs. Suspect thermal sensor not working. Is it in the fan or on the motherboard?
  • 21 Answers
On motherboard. Please, make sure all fans are connected into motherboard.
Some fans can't plug in into the board at all. So, you can ignore those fans.
When you go to Bios to check thermal condition, if a fan is not plug in, you can see 0 degree. 0 degree dosen't cause the shutdown problem. (That's why you can ignore)
Then check which fans are causing problem, first. (If you did and found the problem, go next.)
Replace fans AND clean those dust!
If the problem remains, then replace its case to steel one.
Well, usually a lifetime of CPU fan is pretty longer than others.
Just in case, one more thing, if the thermal condition is OK, then the shutdown problem is caused by something ales!
Posted on May 27, 2011
Continue reboot loo
There are a lot of possible reasons for this.
1. Fan is bad.
2. Motherboard has gone bad.
Do you still see the Compaq logo when you turn it on?
David
Jun 10, 2013 | Compaq Presario 700 470024-192 Notebook
Automatic shutdown after disuse for 1 hour
When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are clogged with dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make sure the vents are clear and dust free. Use a small brush and can of compressed air to do this.
Feb 19, 2013 | Samsung Chromebook Series 3 XE303C12
Hp pavillion dv4000 keeps shutting off
OverheatingWhen the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a small brush and can of compressed airto do this.
Jul 12, 2012 | HP Computers & Internet
Computer won't boot
Apr 26, 2012 | Computers & Internet
Samsung laptop purple light
Apr 18, 2012 | Samsung R540 Laptop
When I plug the unit into power, the CPU fan runs very fast but no boot, and then when I press power on the fan slows down and the PC boots normally. It shuts down in about 30 minutes with no sign of...
Sounds like you are overheating. One way to tell if it's overheating is you say it will run for about 30 minutes then shuts down. When it shuts down try rebooting to see if the boots successfully. If it fails to boot successfully right after it shut down then you are probably overheating. If you wait awhile to let it cool down for 30 minutes or so and if you reboot and it does it successfully you definitely have a overheating problem. If I remember correctly all those compaq sr series have loud and fast running fans. Computers overheat because of three reasons for the most part: 1) A fan has stopped working. 2) The Thermal Paste on the CPU and Heat Sink has dried up or is not thick enough to keep the unit cool. 3) Dust has clogged the fan vents and inside the computer. Fortunately for you desktops don't have to be completely disassembled like laptops to get to the fan, CPU and heatsink. Just pop the case and you'll see the components attached to the motherboard
Mar 18, 2012 | HEWLETT-PACKARD Compaq Presario SR5518F...
Shuts off and reboots then shut off in the middle of reboot.
these posts are endless here, truely
had to google it ah a DESKTOP
old Pentium 4 processor
circa 2003 , tiny HDD, and memory. old, Goodwill has 1000s parked.
well it can be many things,
did you remove all the cards first, (yes all)
does that hold up power? now?
it will beep, like that, if video car is pulled
and then pull memory, and it will give the ram missing beep codes
all this is covered in the great HP service books.,
beep codes and all
the power switch can be bad or the line cord. to wall. bad.
the power switch unplugs and you can short its 2 pins
to turn on PC< hold up now>?
hold up, means stay running,
you can strip it down, to just mobo and PSU
sure can,.
the CPU can overheat, sure can. and can be checked.
cpu fan works so is not that. im sure. and new thermal grease.
data sheet shows. (pull it,?)
nVidia GeForce4
GeForce4 MX
MX
440 440 AGP
AGP 8x
8x graphics
graphics card
card
Mar 12, 2017 | HP Pavilion A250n (DF253A#ABA) PC Desktop
Shut down during boot
Sounds like a cpu overheat situation. Check the cpu temps in the bios and compare the temps with the maximum operating temp of your particular cpu. It might need better/or/new cpu thermal paste applied to your cpu, and also check that your cpu fan is running and locked down tight (and not loose)
Nov 22, 2011 | PC Chips P23G Motherboard
Hi my HP Pavillion ZV5000 fan runs loudly after a period of time and then shuts off. Probably due to over heating.i also already have cleaned the fans. Is there any solutions?
When the CPU overheats then it will shutdown (i.e. thermal overload) and won't boot up again until it has cooled down.If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes this problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan. If the fan and heat sink is clogged withdust the remove the dust and make sure the vents are clear and dust free. Use acan of compressed air to do this.
Apr 02, 2011 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
Asus Pc power supply
sounds like heating problems. what i'd recommend is to go buy some thermal paste, remove your heatsink/cpu fan. wipe the bottom of the heatsink clean with a cloth, and do the sam with the top of the cpu. now apply the thermal paste (about 3mm cubic or whatever the packaging says) to the centre of the cpu, and secure the heatsink/fan onto the cpu. make sure your heatsink is on your cpu SECURELY. In my experience a pc that boots up, works a while then reboots out of it's own is having heat problems. especially if the pc wont boot/reboots quickly after the initial reboot.
Jan 07, 2009 | Computers & Internet
HP Pavilion A520n (DW233A#ABA) PC Desktop Logo
83 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
