Question about Diesel Watch Style # DZ4067
My DZ4067 functions in the non-English day of the week for 21 hours a day now. How do I change it back so the the day of the week is in English for 21 hours a day?
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 172 Answers
The "day of the week" wheel on your watch actually has 2 settings on it--one for English, one for another language (often French, but could also be Russian, Japanese, Korean, or any other language, depending on the intended distribution of the watch). You'll need to shift the day track over by "half a notch," so to speak, to get things back in alignment.
The crown you use to set your watch can be pulled out into 2 positions. If you pull it all the way out, you set the time. If you pull it half-way out, you can set the day and date. If you turn the crown clockwise, you advance the date. If you turn the crown counter-clockwise, you should be able to change the day of the week. However, instead of turning the day back a full day, stop when you get a day with the correct language on it. At this point, pull the crown out all the way and manually advance the time 12 or 24 hours until the day and date advance as they would when the watch is running. This is to check that you've correctly gotten the day track correctly oriented. You may have to repeat this process a second time to get it right.
Once you have the day back on track, adjust the date and time, and you should be good to go.
Diesel's own directions, which can be found here: http://store.dieseltimeframes.com/common/images/customercare/instructions/ENGLISH/Diesel_Core-Inst_ENG.pdf are pretty cryptic, but they do have a diagram that might help a little bit. You'll want to look at the section for "Day/Date Watch IS02, 507.2-3, 517.2, 2105, 2305, 2405"
Posted on May 26, 2011
How do I set the DAY of the week on my new watch, Akribos XXIV Women's AK560RD Quartz Multi-Function Genuine Leather Watch ?
There are three positions for the crown. You can pull it out all the way to third position and turn up or down Each of those turn one sub-dial. then you can push back one position and again up or down. Each of those turn another sub-dial hand.
Sep 17, 2015 | Watches
Set time on MSP74810W
Instructions for setting an MSP74810W watch.
Press the "Mode." button three times (the "Mode" button is the one next to the lower left of the dial when facing it).The first time you press you'll see the ST, or stop watch function, the second time you'll see the AL, or alarm function, the third time you'll be back to the time of day function but the seconds will be flashing.
Change the flashing seconds digits to read 00 by pressing the "Start" button (the "Start" is the button next to the upper right of the dial when facing it).
-To advance from the flashing seconds' reading to the hour of the day's digit/digits you press the "Reset" button at the lower right of the dial,
-To advance from the flashing hour digit/digits to the minutes digit/digits you again press the "Reset" button,
-To advance from the flashing minutes digit/digits to the month's digit/digits you again press the "Reset" button,
-To advance from the flashing month's digit/digits
to the day of the month's digit/digits you press "Reset,"
To advance from the flashing day of the month's digit/digits to the day of the week's abbreviation you again press "Reset,"
-To advance from the flashing name of the week's abbreviation back to the seconds' of the minute you again press "Reset," and from there you can go through the cycle again.
While the hour of the day with its A[M] or P[M] designation, the minutes of the hour, the month of the year's number, the day of the month's number, or the abbreviation of the day of the week's name is flashing press the "Start" button once, repeatedly, or hold it down to advance the number or letters to their correct designations.
Once all designations are correct push "Mode" so that none of the numbers or letters are flashing. Your watch is now set.
Apr 01, 2014 | Watches
How do I change the "day of the week" on my Tommy Bahama 1072 watch?
But the first notch, or first snap, is the secret and the key to setting the Day and Date! In the first notch position, you'll see that if you spin the Crown one way, it will change the Day. Spin it in the opposite direction and it changes the Date! Do keep in mind that you may have to spin the Day and Date a couple rotations because it most likely will alternate between English and Spanish. Just pick the correct Language for you and it's done! When the Day and Date are set, push the Stem in all the way and enjoy your Watch! If you still have the problem with your Watch changing Dates at Noon instead of Midnight, that just means you're on the wrong 12 hr cycle. (It's set for Twelve at Night instead of Twelve at Noon) All you need to do is pull the Stem all the way out, (second notch) and Spin the Minute and Hour hands ahead 12 hours. If it's Twelve O'Clock, spin it ahead until it's Twelve O'Clock again. Doing that will put the Watch on the correct 12 hour cycle. Granted, you may have to reset your Day and Date again since you just advanced it, but at least you'll be in the correct Time Zone! Happy Spinning! google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad);
Aug 16, 2010 | Watches
Need help adjusting the day to english
Usually pulling out the crown to the second position sets the time by turning in one direction and the day by turning it in the other direction. I some you will need to advance the time through 24 hour cycles till you get the proper day displayed and then set the date.
Jun 19, 2010 | Watches
How to change the date and week?
1. Pull the crown out one click.
A. Turn dial until function hand rests on "CAL"
2. Pull dial out one more click (should be all the way out)
A. hold down button "A" (top button) until the second hand completes one counter clockwise rotation (should be pointing at current month)
B. Press "A" button a second time and the Day/Leap year hand will move.
3. At this point spin the crown either backwards or forwards and watch as the Day/Leap year hand spins clockwise or counter-clockwise. The Date will adjust per each revolution.
Hope this helps as it took me using the correct movement number on the url in the previous post (for Calibre 8700 the movement number is "E870").
Mar 22, 2010 | Citizen Eco-Drive Calibre 8700 Wrist Watch
Day of week has jue yesterday min what does that mean instead of having mon, tues, wed
You have day ring in Dutch, not the English. Try to find out if there is English by slowly turning (changing) days.
Rate me, plz.
Jan 08, 2010 | Watches
Nelsonic watch with no instructions
Copy and paste this link. It will take you to Bulova's service centerwhere you can download instructions for any of their watches.
http://bulova.com/service/servicecenter.aspx
If you appreciate me finding this answer for you then please rank this solution as "fixya" or at least "helpful" as what I have found for you will solve your problem. :-)
Jan 09, 2009 | Bulova Watch
Setting month, date, and day of the week on non-digital watch
Try pulling the stem out. Turn the stem in the counter clock wise direction and see if that changes the date/day
Dec 21, 2008 | Watches
Setting day and date on timex watch
Pull the stem out part of the way not all of the way. This will allow you to change the date quickly without the day moving.
Nov 26, 2008 | Timex 27191 Wristwatch
Day in both english and french alternately.
retailer contacted rotary.
apparently there is quite a delay (hours) before the day eventually chages back to English. In other words it doesn't change immediately after 12pm but sometime early in the morning?
The moral of the story is that you should be in bed before 12pm and not to take any notice of the day on your watch since it will still be yesterday and in French?
Jun 11, 2008 | Watches
Diesel Watch Style # DZ4067 Logo
146 people viewed this question
Top Diesel Watches Experts
Ansel Alberto
Ansel Alberto
Jimmy Accardi
Are you a Diesel Watch Expert? Answer questions, earn points and help others
