Protect on a-97 amplifier (kenwood) - Audio Players & Recorders
  • 3 more comments
  • djevansy Aug 30, 2008
    how do i get the IC changed an if you could would You be able to tell me what this is
  • stuandlou Sep 25, 2008
    my amp flashes protect and then switches off after a short while does anybody have a diagram to allow me to repair this fault ???
  • mike00dj Oct 30, 2008
    i have the exact same problem... kenwood a-97 amp and when its turned on it goes into "protect" mode...
    ive read a lot of replys saying get the IC change and try different things, all of which i have done, except for change the IC
    will this be expensive or am i better off just getting a new amp/system
    thanks for your help
  • jose84 Dec 03, 2008
    'protect' on a97
  • Anonymous Mar 29, 2009
    what is the "audio amplifier IC" as i get this problem also tho i was told by the original owners they had to press somthing down for few seconds then it works??
    ninoninixion @hot mail. com
    Genius:
  • 1,550 Answers
The audio amplifier IC are damaged and need to be replaced.
Posted on Aug 16, 2008
SOURCE:
I just got a Kenwood system, i would like to know how to hook it up, it has, Kenwood power amplifier km207, kenwood stereo control amplifier kc 207, disc player dp-m 97, cassette deck ky-77 cw, stereo...
That's a pretty standard setup. RCA cables from the KM207 to the preamp (KC207), and RCA cables from all of the other components into the KC207. Speakers connect into the KM207
Nov 01, 2012 | Master DE Kenwood with Housing...
Hi I have a Kenwood HI FI System with an amp that says protect can you help,Thankyou
unhook all speakers to the amp and the power it up..if it still says protect..then the outputs inside the amplifier are blown...you will need to have a tech repair it
Jan 04, 2012 | Car Audio & Video
My 1800 watt kenwood keeps goin into protect mode as soon as i turn it on.. why?
disconnect load (speakers), check if it still goes in to protection if so then your output stage might be faulty
Apr 17, 2010 | Kenwood KAC-9152D Car Audio Amplifier
What shall do if my kenwood show me protect?
Hello. It could be helpful if you would give us the exact model number of the Kenwood product you have. Kenwood has made many products over the years. While it's unlikely, your Kenwood product could be the subject of a recall or repair for this problem.
If it is not, please start out by checking your speaker wiring. If you have a short or bad connection, this can cause the amplifier in your Kenwood product to shut down as a way of protecting itself.
Check your speakers as well. Make sure all of them work. Also check the impedance printed on the back of each speaker. Compare it to the ratings printed in the Kenwood manual.
If none of this helps, and you do not find a problem, your Kenwood product may require repair. "Protect" is how the microcontroller inside the receiver is trying to tell you that something is wrong and if the unit did not shut down, further damage could result.
Apr 17, 2010 | Kenwood VR-509 Receiver
My amp is a kenwood kac-9152d it goes in to protection mode soon as you hook up the power
In protection mode do you mean the light comes on and it plays music and stuff? If that's the case, that's what the amp is supposed to do. Protect itself from a power surge
Feb 21, 2010 | Kenwood KAC-9102D Car Audio Amplifier
How do i get my kenwood kac-8402 out of protection
first thing first open it up ull need to check ur heat sinks and capacitorsand see if any of them are blownd if there are blowend replace the bownd once. and try it
Jul 07, 2009 | Kenwood KAC-8402 Car Audio Amplifier
Amp goes dirctly into protect
ok well it could be two thing wrong your amp dont have a good ground or your amp is a smar amp and your subs must have to be hooked up so the power from the amp cn go to the subs so the amp can see that you do have subs hooked up to take it out of protect o and look at your fuses to to smal or to big will send it to protect to
May 19, 2009 | Kenwood KAC-9102D Car Audio Amplifier
The 'protect' is there to protect the main circuit board.
It is normally set off by the output stage going faulty and drawing too much power. The output stage is either made up of 4 large transistors or one very large Integrated Circuit. Either or will be attached to a big bit of aluminium, might be painted black and have fins or just raw aluminium. I've never heard of any system with a protection bypass. Be a bit like having a car where you can switch the brakes off with a button!
What happens if you disconnect all the speakers and any aux outputs?
If it stays on then the problem is with what you have attached to it.
Mar 29, 2009 | Audio Players & Recorders
My kenwood a97 hi fi amp has gone into protect mode a resistor is broken how do i get a diagram to identify the type i need
in my a-97 amplifier was the chip stk350-030 broken. I replaced it and it works again. The stk350-030 you'll find in the middle. Open the hood and cut the bottom (sound weird but its true)
Aug 01, 2008 | Kenwood Audio Players & Recorders
Kenwood Midi M-97/M Switch power on and after a few seconds i get a protect message appear on A-97 amplifier and it blocks use of the system. -Paul
this is prob because of a wrong connection between speakers connections + to + - to - check all speaker wires are correct with no shorting out between + & -
Steve
May 15, 2008 | Audio Players & Recorders
1,233 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
