Question about Jenn-Air JMC7000 Microwave Oven
Our Jennair model JMC7010 in the wall microwave cuts all power most of the time during longer duration times (more tah 5 minutes) After a minute or two the microwave turns back on with all settings lost. It appears to be some thermal cut out that resets. What can be done?
2 Suggested Answers
  • 10865 Answers
SOURCE: Jennair JMV8208BCS No instructions in box
Hello. the installation of wall mounting bracket is not too difficult. you will need a drill, some bits, and a scrrewdriver. you will also need an electrical outlet at that spot to plug in the microwave.
Jennair makes a bracket kit for each microwave. Call any jennair dealer, have your model # handy and they will get you the bracket you need, also ask specifically for the instructions.
Posted on Aug 12, 2009
Oster OM1201E0VG countertop microwave
It sounds like the thermal fuse may be defective, or the fan is not running, or the magnetron is getting to hot. If there are any heat issues the thermal fuse will cut power and reset in 5 minutes.
Mar 07, 2012 | Oster OGB61101 Microwave Oven
When you put something in microwave and push for time it will run for about 5 seconds and fan will change tone and it won't heat anything
HELLO.
TO MAKE YOUR MICROWAVE WORK AS REQUIRED BY YOU.TAKE THE RESET STEP
4 Perform a hard reset. Pull the plug out of the wall power supply, and wait a moment. Plug the GE microwave back into the wall power supply to reset any anomalies with the microwave's memory. You will need to reset the time of day if you perform a hard reset.
5 Reset the time of day. Press the "Clock" button, and turn the dial to set the hours. Press the dial to enter. Follow the same procedure for the minutes and a.m. or p.m. Press the "Start" button to start the clock.
Thanks.
Sep 07, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Lost power last night - now Microwave won't work - control panel is not lit - unplugged for 10 seconds and replugged in - socket has power
Hi, W/D here.
Leave unplugged for a longer time, say 5 minutes. I have done this twice on my own, and it has worked, but it took about 5 minutes.
--W/D--
Feb 09, 2011 | Jenn-Air JMV8166BAS Microwave Oven
The microwave unexpectedly turns off at random times during cooking. The clock face and everything dies. It is then a random amount of time (5-30) minutes before it comses back. It is not the circuit...
You could try a new plug just in case, next the fuse inside or thermal cut out could be @ fault, could be the cable transformer end as it enters the micro.....
Apr 19, 2010 | GE XL1800 1100 Watts Microwave Oven
Aug 12, 2009 | Jenn-Air JMV8208A Microwave Oven
Microwave clock and duration won't set
Good Morning,
Unplug the oven and wait 3 minutes then plugit back in and check to see that it operates normally. Do not run the oven empty - place a cup of water in it. Let me know if this helps and thank you for using FixYa!
Mar 30, 2009 | LG Microwave Ovens
Convection oven stops every 5 minutes and won't continue
to trouble shoot hold the door securely shut for longer than 5 min to see if it runs longer if it does the you should replace the interlock devise
Dec 25, 2008 | Sharp R-930AK Convection/Microwave Oven
JennAir Microwave worked one minute then won't the next.
If this microwave is more than a couple of years old, it's possible that the magnetron tube or a rectifier has burned out. You'll probably need to take it to an experience microwave service technician to get a diagnosis.
Jan 16, 2008 | Microwave Ovens
Oven combo, oven works but the micro has no power
The fix for my problem was to remove the oven/microwave combo unit, and press the reset button on the back of the microwave. Oh yeah, and to write a $75 check for a 10 minute service call.
You want to try the fix for yourself? You have to remove all of the face screws holding the unit in place. There are 4 on the microwave front and 6 in the oven, 3 down each side, inside the lip where the door is. You must remove the door to get to the bottom ones. You don't have to remove the screws holding the plastic insert in place between the micro & oven, but you might want to remove the metal lip on the bottom of the oven to help prevent scratches to the cabinet. After that's done, get a helper and pull the unit most of the way out, then rotate a little to the left. That will expose the reset button on the back, right side of the microwave.
Sep 07, 2007 | Jenn-Air JMC8130DD Microwave Oven
Jenn-Air JMC7000 Microwave Oven Logo
96 people viewed this question
Top Jenn-Air Microwave Ovens Experts
William Miller
William Miller
Are you a Jenn-Air Microwave Oven Expert? Answer questions, earn points and help others
