My tv model #27F500T is changing stations all by it self
    Guru:
  • 586 Answers
the stations are changing by itself on your TV because the channel button on the TV is partially stuck in, that is why it keeps changing all by itself. This same thing may also happen to the remote control of the TV if the channel button of the remote stuck in and pointed at the TV.
Use your finger to rub the buttons on the TV, especially the volume control button. Do same on the remote and most definitely problem should be solved.
Please give me a feedback if solution does not work for you.
Yours sincerely.
Elect_Comp
Posted on May 26, 2011
Why does the car radio change stations by it self
Sticking tuning buttons and their switches is quite a common fault.
Aug 03, 2014 | Metra 40-cr10 2007-2008 Dodge Caliber R/t...
Can not tune tv since change over
The KV-32FS100 only has an analog tuner (NTSC). Unless there is a low-power analog station still broadcasting in your area, you will not be able to watch OTA stations. (I've got one in my area that barely comes in.) If your local cable still sends an analog signal, you won't need a set top box to watch that subscribed service.
Otherwise, you need a set top box to watch TV. A digital to analog converter (the boxes that were available with the government coupon before the switch over) will give you over the air stations. The basic models only provide SD output; there are a few HD models available. Otherwise, you can use a satellite reciever, cable box (for digital cable service), or something like the Boxee or Sling with tuner. (There are a few different models of the Boxee; one added a tuner with a USB dongle. The newest model of the Boxee has the ATSC tuner built in.)
Note: OTA digital signal quality is either a strong enough signal for the tuner or no signal will be present. You need to point the antenna in the correct direction to receive the signal from your local transmitters. The type of antenna and its placement will also change the number of watchable channels. You can use antennaweb.org or tvfool.com to get more information. Antennaweb assumes an outdoor antenna but gives a conservative list of stations. If the signal is split to several devices, you may need an amplifier to get a watchable signal. (Sometimes amplifiers fail and you won't receive any stations, so test without the splitter or amplifier by using a direct cable to one TV.)
I hope this helps.
Oct 26, 2012 | Sony FD Trinitron WEGA KV-32FS100 32" TV
How do we set the picture to 1080 megapixels from 480i?
U can't just do it on ur own setting like 480i to 1080p when ever u want.No,u only get what ever the tv stations modes they set and send out only.Ur tv have the 1080p mode capability mean ur tv can pickup that 1080p mode.Dosen't mean u can change 480i to 1080p by ur self anytime u want,if the tv station is broadcating tv signal to u only in 480i u get only 480i.
Jun 23, 2011 | Mitsubishi WD-73827 73" HDTV DLP TV
Our 37" series 4 (450) LCD TV sound "garbles"
Hi my name is Roety,
I can help you with your issue ,
Make sure you have the latest firmware upgrade from Samsungs website!
Also weak signal can cause this if using air signal raise or connect a better antenna
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
Nov 29, 2009 | Samsung LA37A450 37 in. HD-Ready LCD TV
No picture cant use remote to turn tv on/off or change station.
Hi,If I am understanding the remote control is not turning tv right? here's the one you need http://www.newtvremotes.com/Mfrs/Hitachi/HitachiTV/CLU-3842WL.htm God bless you.
Oct 02, 2009 | Hitachi Televison & Video
My tv keeps on changing channels by its self..
Mine does that sometimes, except it just goes down one station and then stays there until I change it back. It's either the sensor going bad or one of the buttons is stuck.
Jul 16, 2009 | Apex Digital PF3230 32" TV
Trying to find remote or is there another way to get all stations on this t.v without the remote
You can try to buy a samsung universal remote, buy a samsung vcr which has a tv/vcr switch, and this will let give you control of the tv and also allow you to program the channels. Because the vcr acts as a tuner.
May 11, 2009 | Samsung LE40R73BD 40 in. HD-Ready LCD...
The stand by light comes on but when I press the power button nothing shows up on the tv. Opened the back of the tv and manually hit the power switch and the tv doesn't power up.
there is a short circuit in the main power suply or in the high voltage power supply; a diagnosis is needed to determine what part got electrical shock. this kind of problem is average in the service bench so i recomend to ask for an estimate if you want to keep this tv
Apr 14, 2009 | Televison & Video
Cant tune my Hitachi TV
please check web site for any thing in remote. www.remotes.com and give model name in search. hopr this will help. good luck.
Sep 30, 2007 | Televison & Video
Televison & Video Logo
110 people viewed this question
Top Televison & Video Experts
