Question about Pioneer PRO-720HD 64" Rear Projection Television
I have a pioneer pro-720hd tv and the picture has gotten fuzzy and there is a blue shadow that appears behind objects or people. What could be causing this?
  • 2,098 Answers
Hi Chris,
This kind of symptoms indicated of problem in its convergence. If the symptom can't be adjusted or cured through the convergence alignment in the menu, this is an indication that convergence circuitry inside gone bad. Here are some of the convergence problem.
Your unit used set of STK392-110 as convergence IC's which is mounted in the heatsink. Replaced this IC and some of the resistor around which is also gone bad (mostly low resistance resistor) and your unit will back to normal again.
But before you replaced the IC's and resistors, check first the board for bad solder joints(cracked/dried/cold solder) in this section. You must work in the brightest area or used table /portable lamp and magnifying glass because this is hard to spot.
If you don't have necessary tools and test instrument and can't troubleshoot the unit yourself, I would advice you to look for a qualified tv technician to isolate the problem.
Also, check if your unit is still under warranty/extended warranty period, avail it because the manufacturer will fix it for free. Opening the back cover will void the warranty.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Posted on May 26, 2011
I have a pioneer tv model pro-720hd. The picture just went fuzzy and everything has a blue shadow around it. What could be wrong?
Sounds like a problem in the blue HV convergence circuit, bad yoke or IC chip that drives the yoke coils.Could also be a bad blue CRT. Look at IC901, STK392-110 and releated components in the circuit, page 97 of service manual.
Look at the
Blue CRT DRIVE
ASSY (AWZ6603
Download Service Manual here: http://elektrotanya.com/pioneer_pro720hd_projection.pdf/download.html
May 27, 2011 | Pioneer Televison & Video
Blue shadows and a yellow and blue arc acroos the bottom of the screen
Tv have a problems known as a convergence problems it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board it is dead.The tv convergence board must require replacing 2 STK convergence ICS and some or all of it resistors too.To fix the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Mar 02, 2011 | Pioneer SD-582HD5 58" Rear Projection...
My tv is make humming soud and stop i will not see and picture, the screen is dark but the oudio still working, do you know what wrong with it?
I would say that your Projection light is busted, I'd recommend that you take it back if you have a warranty, if not then find the appropriate part by googling a company that can service those parts for you.
Nov 16, 2010 | Pioneer PRO-720HD 64" Rear Projection...
Why am I getting a blue ghosing shadow behind the objects on my TV?
Ur have a problems known as a convergence problems,it dead.The tv have colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures look alike.The tv convergnce board have dead 2 STK convergence ICS and some or all it resistors too.These parts must be replaced on the tv convergence board to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 08, 2010 | Hitachi 57F500 57" Rear Projection...
My Pioneer PRO-200 60 in. Rear Projection Television picture looks great however it appears to be dark and blacks all blend together on the screen.
The tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures look alike.The tv convergence board have dead 2 STK convergence ICS and some or all it resistors are dead.These parts on the convergence board must be replaced to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Nov 03, 2010 | Pioneer PRO-200 60" Rear Projection...
Pioneer Elite Pro-118 rear projection tv
ya mine did something close to the same. at the moment i covered the blue canon inside the tv now the picture isnt 2 of eveything. the tv comes apart easy from the front good luck mike
May 02, 2010 | Pioneer PRO-200 60" Rear Projection...
Blue Shadows
You need to install a convergence repair kit. The PT47WX42 Convergence repair kit at the following link is the correct one for your model. The kit contains both Convergence ICs and the six feed resistors, Plus the CD with instructions on how to do the repair.
http://www.tvrepairworld.com/
Jul 20, 2009 | Panasonic PT-53WX42 53" Rear Projection...
Blue shadows appear to be behind white objects
TV shows large red spot in middle of tv when dark show are on, you can see it more.  Now blue spots on upper right side too.  Spend way to much on this tv to have these kinds of problems only after 3 yrs.
Nov 16, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Pioneer SD-643HD5 64 in. Rear Projection
You need to replace convergence chips - they are behind the large black heatsink
May 22, 2007 | Pioneer SD-643HD5 64" Rear Projection...
Pioneer PRO-720HD 64" Rear Projection Television Logo
133 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
