LOST RED COLOUR
RED DIAGONAL LINES APPEAR. THEN THE SCREEN TURNS RED IN THE CENTRE AND THE TV TURNS OFF ALMOST STRAIGHT AWAY LEAVING THE LED BLINKING
  • 129 Answers
Good day.
Please check capacitors along the flyback section for leakage. Also, please consider loose contacts along the circuitry.
regards,
chris
Posted on Aug 16, 2008
Led lcd screen red
Go to menu on remote then to colour settings and see what it's set at
Jul 15, 2013 | Televison & Video
Sony trinitron xbr red diagonal lines appears then screen turns red and then shuts off. The red led light blinks 7 times. Please Help!!!
In cannot remember if this model of set uses on the CRT drive board a drive IC for the CRT colour channels, or if it uses descrete transistors. I have had component failure on this board that causes your description. The failure in your case would be with the red channel drive. Most of the time I had the semiconductors fail, and some of the support components.
Most of the time, a failure on this board is caused by some intermittant internal arching inside of the CRT. If this happens, the CRT is starting go defective.
Another cause of this fault is that the CRT is starting to go internaly shorted between the control grid and screen grid. As it heats up, the shorting becomes lower in resistance, and thus causes the pricture to go brighter until the protection turns it off. This would be with the red electron-gun.
With any failure with the CRT, the set is not worth to fix even if you can find a CRT for it.
Jerry G.
Dec 22, 2008 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Samsung lns4041dx/xaa tv takes a long time to turn on the red LED light blinks 3 times then disappears - then LED light comes on again repeats the process for about 7 - 10 minutes then the TV turns on. ...
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
May 31, 2017 | Televison & Video
Diagonal lines on a Samsung 46" TV
picture is ok /converg.-ok/;diagonal lines on screen; looks like waves.Appear on tv and video modes.I observed same problem on some another tv in my practic,but this case is worse.
Sep 09, 2008 | Samsung HC-P4752W 47" Rear Projection...
Panasonic plasma hdtv with crazy red coloring
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Mar 13, 2017 | Televison & Video
Too much green color
Problem solved. I tried playing DVD and the TV picture was fine. So I double-checked cable wires from cable box - one of the wires was loose (obviously it was the red color input). After tightening, the TV picture is good as new.
Mar 20, 2008 | Sony FWD-50PX1 50 in. HD-Ready Plasma...
Tv red screen
nice to have model number.
tap on crt board with a plastic handle see if it goes away.
otherwise it sounds like the tube is bad, you could also try to adjust the red brightness screen
Feb 01, 2008 | Televison & Video
Sony KP-51HW40 51 in. Rear Projection turns blue
Hello......
First reduse the G2 voltage for the blue c.r.t,and watch if the unit works for longer period (offcource blue colour will be not present).After reducing G2 voltage to blue c.r.t still behaves the same than c.r.t is faulty and you have to replace.
Pls count the red led blinking when it goes off,incase it goes to std by mode.
Gopali
Dec 14, 2007 | Sony KP-51HW40 51" Rear Projection...
Samsung TV
Hi.
Just read your list of problems The first fault (Diagonal lines & picture collapse from left & right) Sounded like either A poor connection or dry solder joint either on scan coils or scan coil plug / socket on main pcb.
If this were the case the engineer that called out should have spotted this & sorted it very easily. But you say it is still the same so what did he do ?
Did he give you a reciept with break down of what he did ? If yes please post it here for me to go over.
The sound problem you describe has thrown me a little so could you please post your tv model number on this page so I can see if this is a stock fault.
The static shocks you are getting is relatively normal & not a problem unless you are getting them off of speaker grilles or even tv casing if it is silver in colour.
I am UK based & have access to samsung technical but I will need your tv model number.
http://dysonmanuals.inc.io/
Chris.
Oct 30, 2007 | Televison & Video
Diagonal lines
Hi It's difficult to be sure without being able to see the lines myself, but what it sounds like is some stray RF is getting into your video signal. Although your cables are supposed to be shielded, this is a common problem. The first thing I would do is move the cables or cable you are using, in relation to any power cords hanging down behind your equipment while someone watches for the lines to change or dissapear, and is that has no effect, then if possible change the position of the VCR in relation to the tv, so that if for example it is under the tv, move it to the side, or farther away, and the lines may very well dissapear. That problem is due to a common interaction between the tv and vcr where there is not enough shielding, usually inside the bottom of the tv set. Hope this helps, good luck!
Feb 11, 2007 | RCA VR546 S-VHS VCR
Televison & Video Logo
57 people viewed this question
Top Televison & Video Experts
Electro Med Services...
