Question about Elite Sl 3000 Ul Sliding Gate Operator
How do I program a new remote for robo swing r900? Where can I find the dip switch settings in the operator?
3 Suggested Answers
  • 14 Answers
SOURCE: i have an elite robo swing r900 gate opener. gate
first check you battery and make sure it is putting out 12v dc then if you have a solar power system check the red and black wire comming from the panel and make sure it is putting out 24volts. if you panel is not putting out the volts it caused your battery to die so replace your panel and battery and all should work fine. if your using a trickel charger do the same check power its putting out and make sure its correct and also check the 120v ac comming in to the charger. Follow the steps it deffinatly sounds like a power issue.
Posted on Mar 13, 2010
blanchettohd
  • 143 Answers
SOURCE: How to set dip switches on remote for Chamberlain Liftmaster 1000
I would go with a chamberlain clicker on this issue. These remote are phased out and the 9 dips don't work well with them. Thanks BB
Posted on Sep 06, 2010
My harbor breeze ceiling fan remote has dip switches inside, but no reset or program switch. How do I attempt to reprogram?
The dip switches in the remote must match the dip switches it the receiver inside the fan motor. You can set them anyway you like as long as both are the same.
Sep 26, 2015 | Dryers
How to program remote control sku#33201048
I don't know what type you have but most have 4 dip switches in the transmitter & receiver. The dip switches inside the transmitter will be near the battery. Match the settings to the dip switches in the receiver.
Aug 11, 2015 | Televison & Video
Can I program a 10 dip switch remote to replace an 8 dip switch remote?
You should be able to, 8 dip switches gives you 256 addresses, the 10 dip switches gives 2048 addresses, just leave switches 9 and 10 in the off position and set the switched the same.
Jun 16, 2012 | FireFly 300mcd21k - 1 Button Keychain...
Liftmaster Garage Door Opener won't clear codes
This was a first generation learn button model. Antiquated by current technology standards. It was a two channel system. One channel for a dip switch remote, the second for a 66LM key pad. No way to erase the programming, however, by programming in a dip switch remote (61LM with the dip switches set to new positions, and a 66lm set to a new entry code) will purge the two channels of their previous memory, now set to the the new settings.
Jun 06, 2012 | Home Security
Need to program Hampton Bay Ceiling fan remote control CHO88T7030T, HELP!
Change the battery. This is the first step when troubleshooting a ceiling fan remote. The easiest fix to any remote control problem begins with battery replacement. A 9-volt battery is needed to operate all Hampton Bay ceiling fan remotes.
Check the light switch used for the ceiling fan. The light switch found on the wall must be in the "on" position. This allows the ceiling fan to be operated by remote control
Re-program your remote. If battery replacement fails to get your remote working again, try to reprogram the remote. Open the battery cover you will see 4 dip switches. These switches must be set to the same position as the receiver on the fan. Use the screw driver to move the dip switches either up or down.
Follow the previous step to change the frequency if the ceiling fan is randomly turning on or off. Other electronic devices such as garage door openers can interfere with the ceiling fans receiver, causing it to randomly turn on or off.
Sep 10, 2011 | Televison & Video
Remote will not operate fan or light. Replaced battery. Remote light glows red when pressed
Check dip switches in remote and dip switches on receiver in the canopy of the fan, make sure the settings match exactly. Make sure there is power to the fan. Make sure the fan and light are not manually set to off by pullchains that may be on the fan. If the fan does have pullchains, wire it directly in (bypass the remote in the canopy) and test the functions to make sure the fan and light are working. If it works without the remote, but not with the remote, and the dip switches are set the same and you have new batteries, then the remote and receiver should be replaced.
Feb 28, 2011 | Hunter 52" Ceiling Fan With Light And...
We installed a 27185 remote kit in a hunter fan, and factory settings. The fan light goes on and off by itself. I changed the dip switches( matched them to the remote to the controller), and the fan and...
I have had the same problem with the light coming on intermittently by itself. At first I also could not change the settings and have the remote work with the new settings. But I found out that when you change the dip switch of the receiver you must turn off the power using the wall switch or the circuit breaker and turn it back on before the receiver will use the new dip setting. I am still waiting to see if the light will come back on after changing the dip switches from 1-on, 2-on, 3-on, 4-off to 1-off, 2-on, 3-on, 4-on and the remote's jumpers from 1-jumpered, 2-jumpered, 3-jumpered, 4- no jumper to 1-no jumper, 2-jumpered, 3-jumpered, 4- jumpered.
Jul 09, 2010 | Hunter 27185 Remote Control
I have an elite robo swing r900 gate opener. gate door's are not closing, battery keeps beeping and it shows low battery
Nov 09, 2009 | Elite Sl 3000 Ul Sliding Gate Operator
Dip switch settings
I've had the same problem w/ light turning on/off. Called customer support and 3x waited 6 minutes to leave message and get no call back. Finally got a human and she told me to change code in receiver and transmitter. This was no easy task as the fan is very high up and the stupid thing needs to come down to adjust the receiver. Changed the setting and it worked for two days until it started back with the lights turning on at all hours. I noticed there's a toggle switch in the remote that is not explained in the manual. It says CFL on one side and INC on the other. The light will NOT dim if it's in CFL and tonight is the first time I've switched it to that setting. I'm hoping this is some kind of lockout for random signals going out of the remote...It would be nice to have a proper explanation in the manual. I should have gone with another Casablanca fan--Hunter products are lame.
Feb 03, 2008 | Hunter 27185 Remote Control
Elite Sl 3000 Ul Sliding Gate Operator Logo
120 people viewed this question
Top Elite Home Security Experts
John
jr3261
Are you an Elite Home Security Expert? Answer questions, earn points and help others
