Question about Dell W4200 42 in. HD-Ready Plasma Television
The sound on my Dell W4200 is crackling some times even when the sound is on mute. Sometimes the sound is fine, other times no sound and other times the crackling noise. Any idea what problem may be?
  • 3 Answers
Hi There,
Crackling sound is often an indication of bad connections to the speakers. Are you listening with the built-in speakers or through an external amplifier?
If you are listening through an external amplifier or speakers, check all of the connections to make sure the cables are properly inserted, and wiggle the cables from each end and the middle to see if that reproduces the symptoms. Sometimes a cable can become damaged from being squashed or bent, and it may be as simple as replacing the faulty cable with a new one.
If you are listening with the built-in speakers the situation might be harder to identify and correct. Sometimes it is as simple as nearby wireless devices or radio towers causing interference with the speaker. You can try repositioning wireless devices such as computer routers, cordless landline phones or radios to see if that helps.
However, over time the solder used to connect the internal components can wear and sometimes break the connection. For this type of situation repair is usually the only option. If the warranty of your TV has expired you may have to take it to a local TV service center. Typically a loose solder joint is easy to identify and fix, so the repair bill should not be high.
Please post back with your results.
Posted on May 26, 2011
Access code to reset factory default settings
Hello:
To reset your Dell W4200 to the factory default settings, follow these steps:
  1. Press "MENU" on your remote
  2. Select "Setup" on the screen using your remote
  3. Select "Factory Reset"
If your TV is locked, you can use the default code of 3355 to unlock it.
Manual for W4200: http://support.dell.com/support/edocs/systems/W4200/
Mar 06, 2011 | Dell W4200 42 in. HD-Ready Plasma...
Crackling sound
Have you tried some headphones directly into the headphones socket? Does the sound still crackle? Usually 'crackle' is associated with dodgy leads and you will be able to hear the lead responding to movement by crackling more, a hissy sound often means that there is a fault with the socket and sometimes removing and reconnecting the jack into the socket a few times will help this. If it sounds like hiss with little pops it's usually electrical interference and could mean a bad earthing in the circuit somewhere
Jun 06, 2010 | Dell (8H390) Sound Card
LG 37LC2D HDMI no signal (picture or sound) + crackling on audio
i have the same problem. i think they just get old, i solved the audio problem by taking the cove off the back and disconnecting the speakers, i now just use PC speakers, works grand. i haven't solved the HDMI problem yet..
Apr 29, 2010 | LG 37LC2D Television
Sound crackles on dell inspiron 640m
You might have a bad connection on your sound card or sound module. If you are savvy enough, you can easily check these. If not, take it to an authorized dealer. Good luck!
Nov 02, 2009 | Dell Inspiron 640m Notebook
Technics amp crackle and ''hiss'' noise
in my car when I press the accelerator there is hissing sound,did check the air filter by disconnecting the plumbing but still the sound is present any idea what could be causing this sound.
May 25, 2009 | Audio Players & Recorders
Dell W4200 42 in. HDTV-Ready Plasma Snow and Horizontal Lines
go to the menu and try the plasma restoration first. that will take a few hours and you probably same the $350.
Nov 05, 2008 | Dell W4200 42 in. HD-Ready Plasma...
Snap, crackle sound from Sanyo TV
It sounds to me as if possibly ya Main IC Amp Chip & OR the Output Capacitors are failing... Sometimes it is a sign of a power supply on it's way out... Either way it's time for a repair shop quote. Either that or it may be the speakers crossovers... to check this, if you can, try another set of speaker... see if problem is still there. If it IS, then it IS most probably as I said above.. If NOT then it may be one or both of the "Crossover Network" in each speaker...
Sep 01, 2007 | Sanyo AVM-3659S 36" TV
Crackling from surrond sound
I have a SONY home theater4.gif system, HT-C800DP, there is a crackling sound when playing DVDs - it is almost as if the unit overheats. Is there any solution to this? Sometimes I cannot even finish a DVD as the noise gets very loud.
Thanks,
Cindy
Aug 14, 2006 | Sony HTD-C800DP System
Dell W4200 42 in. HD-Ready Plasma Television Logo
208 people viewed this question
Top Dell Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
CoppellTVRepair.com
Are you a Dell Televison and Video Expert? Answer questions, earn points and help others
