Question about Maytag M6X06F2A Air Conditioner
Maytag window air conditioner m6x06f2a f won't turn on. We just hauled out the window air conditioners and the above model one that we have won't turn on when you press the on/off button as in no power. It is in perfect condition- never been dropped or damaged. We took off the front panel and inspected the green circuit board? all points seem sodered down. We even pulled out the part behind it to check the fuse and it is fine. Lastly, we tested the cord (cut the plug/stripped the wires and tested in the electrical socket) and there is no power. At this point I need to know what could be the cause?
  • 86 Answers
SOURCE: air conditioner
1.wash cooling coil properly.
2.check blower fan motor speed
3.may be there is gas leakage in units
4.if copressure below then 300 psi then copressure not working properly.check compressure.pressure must be 600psi.
Posted on Mar 16, 2008
SOURCE: heat strip installation
It was quite simple, just installing the heat strip and my model only required removing the grill cover and mounting the element. The other optional installations didn't apply to my model.
thanks,
Don
Posted on May 27, 2008
dabeckham
  • 22 Answers
SOURCE: what is the amps for a Maytag window air
The label on the AC should tell you the ratings in Watts. Divide the watts by voltage to derive amps. Hence 7400 watts @ 240vac would be 30.8amps
A quick search on the internet shows that your unit pulls 618 watts while cooling and is designed for 115vac. So @110vac that is 5.6amps and @120vac that is 5.1amps... See why voltage is important?
Posted on Jun 15, 2010
  • 10 Answers
SOURCE: I have a model AR DL10 remote for a Fujitsu air
After changing the batteries you have to depress the RST button and if the remote has the abcd slide switch ensure it is set to A.
Posted on Jul 15, 2010
Testimonial: "THANKS"
  • 3 Answers
SOURCE: Owner's manual
Try Fedders-Airwell manuals, but look for model A6X06F2A instead of M6X06F2A.
Posted on Mar 26, 2011
I have a maytag Ac model # M3xo5F2b and im looking for an on off switch Can you tell me where to get one?
Google the model number with "parts" to try to locate the switch--maytag should not be too hard to find there.
Jun 15, 2012 | Maytag M6X06F2A Air Conditioner
What is the amps for a Maytag window air conditioner model#M6X06F2A
Jun 14, 2010 | Maytag M6X06F2A Air Conditioner
My m6x06f2a-f is leaking from the front water is coming out the outside of the unit ok . also how do you take the front cover off i removed the 2 screws on the side but can't remove the cover.
Lift the left and right side straight up till you feel each side pop out. Then it comes straight off. I can't find a manual, but this maytag would be a Fedders-Airwell air conditioner with the same model numbers but starting w/ an A instead of an M.
May 29, 2010 | Maytag M6X06F2A Air Conditioner
Owner's manual
May 01, 2010 | Maytag M6X06F2A Air Conditioner
Ac blowing hot air
call service tech to check compressor
Aug 11, 2009 | Maytag M6X06F2A Air Conditioner
Window air cond unit, several years old, doesn't blow as cold
The problem with window units and any service tech will tell you it cost more to repair than you can buy at Walmart or home depot. Unless you know someone who can charge it for you. Window units are a sore subject. A 200 dollar window unit might cost 200 dollars to charge system. SORRy rusty
Jun 13, 2009 | Maytag M6X06F2A Air Conditioner
My maytag m6x06f2a-f window AC wont stop beeping
We had the same problem and changed the setting to auto and the unit seems to be working properly now. Not sure if this solves the problem, but for the past 1/2 hour the unit has stopped jumping between 00 and the temp we set.
Jun 07, 2008 | Maytag M6X06F2A Air Conditioner
Maytag M6X06F2A Air Conditioner Logo
238 people viewed this question
Top Maytag Heating & Cooling Experts
gbob59
Bill Long
Are you a Maytag Heating and Cooling Expert? Answer questions, earn points and help others
